Question about Maytag MER5765RAS Stainless Steel Electric Kitchen Range
Re-installing maytag mer5765 oven door
Had tech over for dishwasher recall. Wife asked how to clean glass in the door. He opened it, moved a latch on each side & the door came off. He put it back together. Today my wife took off the door, took it apart to clean the glass's & put it back together again. Now, both of us cannot get the door installed. It just doesn't work...where should the latches be?
SOURCE: MAYTAG (AMANA) OVEN DOOR
I finally got my door back on, I had to wedge a butter knife in the hinge to keep it open, then I could put it back on the pins and slide the metal cover/locking thinge over it. Was a pain in the ass.
DANGdoor
Posted on Dec 02, 2007
josh1856
  • 105 Answers
SOURCE: Admiral electric range with self cleaning oven
There is an automatic lock feature on this unit that after 1 hour will unlock itself.
hope that helps!
Posted on Jan 30, 2008
huuum
  • 750 Answers
SOURCE: oven lights will not turn off, Maytag gas double oven range Prec. touch 750
Hello bohlke75,
Welcome
You said, After cooking in the upper oven today, my wife noticed that both oven lights were on. I tried to turn them off but the oven light button just beeps when activated. I individually tried the plunger switches on both doors but that did not work either. You also unplugged the stove with the hope it would cancel the lights but they came right back on when i plugged it back in. You assume it is something in the touch pad since both lower and upper lights are affected.
Did you leave the plug out for 5 minutes or just do it quickly?
if it only happens on one door then the plunger switch is bad!
if it's both doors then you have a button or control problem. Service can give you a true diagnoses with out the cost of swapping parts randomly!
If it was the plunger you may have been able to get away with a do it your self repair!
Let me know how you do
Thank You,
Huuum
Please remember to leave a rating!
Posted on Oct 16, 2008
SOURCE: maytag cre9400ccw self cleaning 1998?
repace the selector swich.
Posted on Dec 07, 2008
SOURCE: Clean Oven Door Glass
Using a long stick/tool, attach a cloth to the end. Remove the drawer and look up at the oven door. There are 2- 3 openings that are big enough for you to reach the mess. Make sure that whatever you are using to clean the glass will not stay stuck inside, so make sure its attached securely. I used the end of back scratcher with a thin cloth attached to it. After a few attempts, I was able to completely remove the stain that was caught between the two panels. AND... I didn't need to remove any screws or dismantle the door. This could void your warranty.
Posted on Feb 17, 2009
How to unlock a Maytag double oven
Hi Mary,If the door locked after you started the oven!
Press Cancel/Off key to start a latch reset, wait 20-30 seconds and open door, or turn the power off at the circuit breaker or fuse box for one minute, then turn the power back on.
If the oven has a manual latch handle!
Allow the oven to cool, approximately 30-90 minutes, move the latch arm to the left to unlock the door.
If the latch arm will not move after cooling to room temperature, or is stuck in between full right and full left positions, schedule service.
Is the oven door locked due to power failure during Self-Clean? If the oven door locked due to a power failure during a self cleaning cycle!
Select the "Self Clean" option, then select "Cancel". Wait a couple of minutes then try to start the cycle again.
If you started the oven clean cycle by mistake!
Press Cancel/Off key. The oven will need to cool to approximately 200F(95C) before the oven door will open.
Was there an error message!
Follow directions in the display, and refer to the Error Code Symptom, or:
Reset power to the oven!
  • Power the oven down by turning off the circuit breaker(s) or fuse(s) or if you can, unplug the oven for one (1) minute.
  • Turn the power back on turning on the circuit breaker(s) or fuse(s) or plugging it back in.
  • Monitor the oven for one (1) minute to ensure the error code does not display again.
  • Verify the ovens operation.
Kind regards
David
Dec 04, 2017 | Maytag Kitchen Ranges
I have a Kenmore Elite double oven, model 790.48123801.(4 years old). My wife attempted to operate the self-cleaning feature and 29 seconds later an F90 error message appeared, the oven began to beep
Oven door latch error code. The oven door latched but the control board did not receive a signal that the door was latched.
The only time that the latch is used is during the cleaning cycle.
KENMORE ELITE Walloven Parts Model 79048123801
How to unlock Kenmore oven
Oct 18, 2014 | Kenmore Kitchen Ranges
We have a wall mounte singe maytag oven. When I go to set the oven temp. the panel reads"door" and I am unable to set it. I have opened/closed the door and put the lock lever on and off, but to no avail....
Hello there:
Here is all of the possible error codes for the door and what they mean and what to look at
DOOR Bake or Broil
· Defective latch switch
· Shorted wire from ERC 10-pin connector, pin 10 to ground
· Door latched Replace latch switch if defective.Replace wire from 10-pin connector if defective DOOR Self-Clean
· Open wire from ERC 10-pin connector, pin 10 to ground
· Door not latched Replace latch switch if defective.Replace wire from 10-pin connector if defective LOCK Not in Self-Clean
· Oven temperature sensor resistance too high Check oven temperature sensor resistance, wire harness and connections, replace defective component
Sep 28, 2010 | Maytag MEW6527DDS Electric Single Oven
My Maytag Quiet Series 300 is not cleaning my dishes very well at all. My glasses always have grit left in them (even with Jet Dry), my coffee mugs have film left in the bottom of them and now even my...
First problem: The film on dishes and glasses. Try another detergent. Manufacturers removed all the phosphates from dishwasher detergents and there are many complaints. I have had good luck with Finish Quantium tabs. Also have purchased Cascade industrial from Sam\'s online (still has phosphates).
Other problems you are experiencing with the 300 I have also. within 18 months of ownership the control board went out twice. The lower rack rusted through, the silverware basket had the bottom fall out, the door latch broke, now the control board is going out for the third time. I am not hard on a dishwasher. I have had models last 25 years before.
My final fix for my Maytag 300--I have ordered a new dishwasher, it will be delivered Wednesday. It isn\'t a Maytag.
Oct 16, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Self-cleaning oven door won't open
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
May 15, 2009 | Ovens
The door opens hard on my dishwasher
Check the runners on the side and check to be sure that there is nothing blocking the bottom outside of the door.
Mar 16, 2009 | Maytag 24 in. MDBH950AWS Built-in...
My self-clean Maytag electic stove (7 to 8 years old) will not clean because when you set clean on the touch pad the automatic door locking device moves to lock the door, and does pull the door in briefly,...
I fixed the problem simply by pressing the clean button when the oven was warm, not cold.
For some reason not explained in the instruction manual, the oven door safety locked properly and automatically when the oven was warm. I don't know why, but I'll take it!!
Dec 07, 2008 | Maytag Kitchen Ranges
Whirlpool glass top oven self clean latch won't engage.
Door latch mechanism is out of adjustment and needs to be adjusted
Nov 14, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Maytag stove will not open after cleaning
is the oven completly cooled down? the latch is hat sentisive the oven must be cool before the latch will open this can be from 15 min to 2 hours after the clean cycle is complete
Aug 25, 2008 | Maytag MEW6630D Electric Double Oven
F9-4 when cleaning upper oven
its related to the self clean ltach motr, if you pull hte unit out and drop teh rear panel, approx halh way down on theright side( when behind unit) thers asmall lock mechinisn mavbe 1.5 round, with a connecting rod 2 wires and a witch, well that motor sometimes as it heats looses connection with the switch. the switch is monitoring door positoin so if it loses contact it thinks the door is open and will trigger a code. the entire latch is replacabel (FRont to back comesa sone assy latch motor swittch and rod. 2 wires connect it and 2 screws(by front latch secure it. if youtry to replaceit your self i giveyou the heads up to lie a yard stick on top of latch before removing old latch (thos will keep the insulation in place) andthen when installe ing new latch also use hte ayrd stick ontop to keep insulation inplace!!!!!
Feb 24, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER5765RAS Stainless Steel Electric Kitchen Range Logo
120 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
