Question about Konica Minolta DiALTA Di183F Copier
Close 2nd side cover thats wwhat my printer shows and we cant use it any ideas
E.studio232. How do I respond to "close side cover" message?
The side cover is located under the bypass unit...
U need to close it properly...
Aug 28, 2015 | Toshiba Office Equipment & Supplies
Kyocera FS-C5100DN shows Error message "close front cover" what to do??
it is in the left front of the machine the cover you open to change toner should have a actuator that pushes the switch that could be broken off or 1 of your toner cartidges may not be set correctly remove all of them and close the cover if it says install toners do that 1 at a time see if it keeps saying install cartriges until all are installed or you see close cover message after 1 is installed that would be the 1 not installed correctly causing your close cover message
Mar 29, 2017 | Kyocera FS-C5100DN Color Laser Printer 23...
Dialta 152, plase advice the old of this copier. error messageexist; closed 2nd side cover (manual feed); while it's closed,I bought this macine from the auction,I wonder if the side cover it comes with...
yes there should be a side tray that when in the up position shows the manual feed not in use when the tray side cover is down then show manual feed open you can put some paper in the manual feed but if the tray part is not there it is not going to hold the paper to well ;
I would default the machine to take paper from the first draw
Feb 12, 2011 | Konica Minolta DiALTA Di183F Copier
I had a paper jam and I had opened back cover to clear it. Now when I close it still says Back cover open. Close the back cover. What should I do? There is a black color flap inside the main back cover...
Just fixed the same problem. My solution was as follows: When you open the back cover there is another plastic flap/cover inside that drops. Across this 2nd cover there is a plastic rod running parallel with a plastic finger that sticks up perpendicular to the rod which I believe guides the paper into the roller.
On my machine this rod came out of line, placing it about a quarter inch to the left which affected the sensor and the guide. If you look closely, you will notice a small groove on the rod that needs to be in a specfic slot on the 2nd cover. Good luck
Jun 08, 2010 | Brother MFC-7820N Printer
The printer is showing Cartridge Error 1203 on
I found if you cover a copper contact on the color cartridge the error clears and the cartridge works. Looking from the contact side for the color cartridge 2nd row contact 2 from the left. I found if I use an ohm meter from 2nd to 3rd contact I measure 119 ohms. I believe that is a shorted cartridge.
Regards, polysandy
Apr 22, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I changed the cartrige an now i cant get it to close
Please follow the link given below to download the user guide for your Lexmark X4270 printer and look for the information that is required:
http://www.lexmark.com/publications/pdfs/2007/4200/en.html
Apr 03, 2009 | Lexmark X4270 All-In-One InkJet Printer
Caution 2nd side cover is open
Hi Andeawo, It sounds like while moving the copier, you may have broken or bent a door interlock switch or the door actuator that depresses that switch. On the door that showing ajar, look for a small pin (could be plastic or metal) and see if it's bent or broken. If that appears fine, slowly close the door and look for a small hole where that pin would go through and depress the interlock switch. Once located, look to see if the switch is misaligned or broken. I'm thinking that one of these 2 items is the culpret.
Been a copier tech for 12 years and have seen my share of both. Let me know what you find...
Sep 29, 2008 | Konica Minolta DiALTA Di183F Copier
Error mesage
No solution, but I have the same problem. THe printer starts up fine, I hear no grinding noises or other "funny" nioses, and then displays no error message... UNTIL I ask it to print. Then I get a message that says, "Pls (please) Open Cover".
I open the cover and it says "Please Close Cover".
I close the cover and it says, "Please Open Cover"
and this happens forever!
Does anyone have any ideas? Can anyone help me?
Stefan
Mar 05, 2008 | Brother MFC-8440 All-In-One Laser Printer
Konica Minolta DiALTA Di183F Copier Logo
81 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
