Question about Acer Aspire Timeline AS4810TZ4474 Notebook
Acer 4810t wont turn on if battery is fitted. if i remove the battery it will work off the mains but as soon as battery is inserted it turns off.a battery indicator flashes orange 5 times when the power button is pressed when the battery is fitted.
  • clint_a_john Jul 29, 2010
    i do not know any1 with the same kind of laptop, i have just noticed that if i try to move my laptop while its plugged in and i move it, it switches off.
  • 358 Answers
First of all, disconnect your battery from back of the
laptop, then try and get a friend or a technician that
uses the same type of laptop, and try to swap the
battery just to check whether it works and charges
it properly. Also do the same thing with the
Adapter/Charger and charge it with it.
This is because, there are two diagnostic possibilities
here:
1.) It is either the battery that you bought is not good
and you need to return it quickly before its too late
or;
2.) The charger that you are using is bad, or not
supplying enough current to charge the battery
cells...and this might even damage the battery after
a while, or make the battery not to charge to its full
capacity and as well discharge quickly.
Try this out and let me know how it goes.
Hope this helps you out.
Goodluck and thanks for using fixya.
Kindly Let me know how it goes.
Hope this helps.
Posted on Jul 29, 2010
My battery will not charge. Have tried different batteries and chargers. Works fine on mains power. Any ideas please? Roger
sounds like to me you have a bad connection in the battery terminals. try cleaning the contacts with a Emery stick.
Nov 08, 2014 | Acer Aspire 3810T 4810T 5810T
Touchpad, mouse and keyboard not working
Try installing the touchpad driver from here http://www.helpjet.net/files-Acer-Aspire-4810T.html#ATouchpad
Once you are done restart your Acer and see what happens.
If this doesnt resolve the issue it may be a problem with the hardware in which case you may need a new touchpad. otherwise just use a mouse as a fix either temporarily or if it turns out to be to expensive to fix.
Aug 17, 2014 | Acer Aspire 3810T 4810T 5810T
My acer aspire r1600 wont turn on
takeout the battery and insert it back,turn on the laptop with an adapter inserted in the power jack and power on the laptop.if it still wont turn then then check the adapter with a multimeter whether it working.if the adapter is working then it a short circuit on the motherboard.
Sep 14, 2011 | Acer Aspire One Netbook 8.9" Notebook
Acer 4810t. how do I turn on the bluetooth
Check your Device Manager to make sure you computer has Bluetooth capability. If there is no Bluetooth in your control panel, you may have to install the drivers and use the software. You can download the drivers and software from here for the 4810T:
http://global-download.acer.com/GDFiles/Driver/Bluetooth/Bluetooth_Broadcom_6.2.1.800_Vistax64Vistax86W7x86W7x64_A.zip?acerid=634024298954715268&Step1=Notebook&Step2=Aspire&Step3=Aspire%204810T&OS=V10&LC=en&BC=Acer&SC=PA_7
Mar 27, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
My acer aspire 4810t says no bootable device
enter BIOS - you will see a mesage when you first turn on laptop tellign you to press a key to enter setup. Do this and make sure HDD is listed. if it is, you might have todo a recovery.
Turn on laptop, then immediatly press ALT + F10 keep finger on ALT and press F10 a few times, this will start the recovery process. some ask if you want to re-install windows or full factory reset. Windows install will only repair it - full factory reset will delete any data you have! so be careful
Feb 14, 2010 | Acer Computers & Internet
Wont start
Hi there, please explain what's you face. Also you can follow the steps.
1. plug on the the power cable. Is there green light are on in adepter? Is not then your power cable damaged.
2. if you r battery fully charged then turn on your laptop with out connecting power cable. If your laptop booting then system is perfect.
3. Try to plug on by a different Acer laptop users power cable. and see what's going. I need these information for further instruction. You just say "wont start" i don't want to give you any blind suggestion. so please let me know more about it.
Thanks.
Feb 11, 2010 | Acer Aspire One Netbook 8.9" Notebook
Touchpad wont work on mains power
In the acer power management in the control panel you can specify when the mousepad turns on and off, like when plugging and unplugging the laptop. You can also do this for the wireless and other settings.
Mar 23, 2009 | Acer Aspire 3610 Notebook
Acer Aspire 5580 wont power up at all
try to run it without the battery and see how that fares?
May 03, 2008 | Computers & Internet
Acer Aspire Timeline AS4810TZ4474 Notebook Logo
411 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
