When printing 4x6 recipe cards on the food network the cards print in very small type - it used to print normal size - then one day it started printing smaller ?? thanks alex
  • 4 more comments
  • alexhustrei Apr 24, 2008
    i dont think it is the printer i tryed it with another and it did the same - 2 different hp printers
    on the food network recipe i typed (print full page) - then set the printer to print on 4x6 index cards - it has worked fine that way for months - then went to tiny print ???
    can anything be done - what equipment is to blame ???
    where is the answer?? how do i get it ??
    hp 5600 series
    i just print the cards from the explorer tool bar
    i will try it thanks
    alex
    Genius:
  • 1,665 Answers
Posted on Apr 24, 2008
    Genius:
  • 3,422 Answers
After you Choose "Print", make sure "Pages from 1 to 1" is checked (not 'All') in the printer dialog box. If you don't, it may try to print out 3 pages.
*IMPORTANT* In your printer setup, remove the header and footer info
and set the top and bottom margins to the lowest setting to insure all 3
cards print out.In a HP printer, minimum top setting is 0.25/bottom 0.46.
Goodluck,
Please don't forget to rate the solution
  • 1 more comment
  • Priya darshan Apr 24, 2008
    the problem is only with the settings and nothing else.If possible try uninstalling and reinstalling the drivers.
    Please don't forget to rate the solution..
    I mean please don't forget to rate the solution no.2
  • 13,433 Answers
Try reseting the printers settings into defaults, its in the menu if your printer has a lcd screen that is.
also if that doesnt solve the problem some settings have been changed on the pc side, would need to figure out what exactly has changed or who has changed them.
  • 1 more comment
  • Ekse Apr 24, 2008
    I think your printer is fine. can you provide me with the make and model of your printer.
  • Ekse Apr 24, 2008
    I see you have tryed with two difrent printers and the same problem happened, Then its clearly on the pc side, the software you are useing to print the settings have been changed somehow. Which program are you useing?
  • Ekse Apr 24, 2008
    Alex, you shoudnt rate a solution untill the problem is solved. Well Good luck to you.
I CANT PRINT THE CORRECT SIZE
Hi!
fixed the 203 dpi new head in zebra 105sl printer then 1 week print is correct size to 4x6 inches label but after 15 days its not comming full page print.
pls help to get soultion
thanks / Khokan
Jul 15, 2012 | Office Equipment & Supplies
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Mar 19, 2011 | Office Equipment & Supplies
What is the maximum paper weight allowable for the HP LaserJet 2840 printer? I am printing recipe cards but 4x6 or 3x5 cards are too heavy and the printer won't take them.
Handle a variety of business needs. Spend less time loading
paper with an input capacity of up to 375 sheets. A 125-sheet
multipurpose tray and a 250-sheet paper tray offer easy
access to a variety of paper finishes, sizes, and types,
including labels and envelopes, at weights of up to 47 lb
(177 g/m2) and HP laser glossy and photo papers up to 70 lb
(220 g/m2).1
Jun 08, 2010 | HP LaserJet 2840 All-In-One Printer
When I print pictures on the 3210 HP all-in-one, they come out very small even though I choose the 4X6 in paper size for the photo tray. I've tried everything I can, but the pictures keep printing wallet...
First thing that comes to mind is that a 4x6" print could print four wallet sized photos; be shure your are not printing more than one copy.
If you are trying to print more than one,it will print the actual picure you have and leave space for the number of other nonexistent prints selected.
See page 75 of the Manual. for directions on how to set up photo printing.
If you have photoshop, you can resize your documents using the menu item, Image / Image size, (Alt + i then i again)
Set the resolution to 300, then the document size width to 6 or 10 inches.
This will guarantee that your document is full size, (though the printer should be able to resize it to fit on the page no matter what).
Give these a try. It's really a shot in the dark, but it's my best guess.
Cheers.
Richard.
Oct 13, 2009 | HP LaserJet 3200 All-In-One Printer
Instructions on printing a 4 x 6 card or photo on my HP 4280 All in One printer. How to I set up the printer?
At the printer:
1. Remove any paper from the input tray
2. Put a few sheets of 4x6 (10 or so) in the same tray
3. Adjust the paper holder bar so that the 4x6 paper stays straight in place. The holder bar was holding the 8x11 paper in place.
On the computer:
Open a picture
Seect [File] [Print]
Select the photo printer from the list
Cick on [Preferences]
See the paper type? select photo paper
See the paper size? Select 4x6
Quality (Best)
[OK]
[PRINT]
Sep 28, 2009 | HP Office Equipment & Supplies
My HP C7200 printer won't print from the photo tray
If you using a mac: After choosing the Photosmart C7200 to print your file on the print preview, change PAPER SIZE to 4x6, then lower down, change from PREVIEW to PAPER TYPE/QUALITY, more options will open underneath, on SOURCE, change from MAIN TRAY to PHOTO TRAY. You should also change the PAPER TYPE to some kind of PHOTO PAPER (whichever one your using, but the standard seems to be HP ADVANCED PHOTO PAPER)
Jan 27, 2009 | HP C7200-69016 Network Adapter
Printing photos
Of course you can use 4x6 photo paper
you have select the paper size from page setup as 4x6
and put the paper in the tray after adjusting the tray size
Dec 27, 2007 | Samsung CLP 300 Laser Printer
Reprinting photos
try using a ruler to check if you have the correct paper size.
open up HP Solution Center verify the printer settings..
use borderless printing, paper size 4 x 6.
Dec 27, 2007 | HP Photosmart C6180 All-In-One InkJet...
MFC-5440CN 4X6 PRINT
mabey try using windows, not linux, make sure you have driver and other software on CD.
Jul 21, 2007 | Brother MFC-5440CN All-In-One InkJet...
135 people viewed this question
jasbo
jasbo
