Question about Weber Genesis Silver C Grill
How to replace burners - Weber Genesis Silver C Grill
    Problem Solver:
  • 9 Answers
Remove the propane tank, then remove the burner knobs, followed by the manifold. Then you can replace each of the three burners.
Step by step procedures are in your manual, which you can download at http://weber.com/help/manuals.aspx
Posted on Aug 12, 2010
Whirlpool electric Mod rf114px5 front burner overheated. Replaced switch mod # rf114px5b3. Now burner is not heating up enough. What to do?
If control has been replaced, possible that the overheating damaged the burner itself - try replacing it or swapping it with another known good burner from your stove. If replacement burner works then original burner is bogus.
Jul 24, 2016 | Whirlpool Dryers
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
The 4 range top plug in receivers for the heating elements keep burning out. I have replaced them several times. What can I do to have them last longer that 5 months.
Since the burner blocks keep burning out that to me would mean that the burners theirself are worn to and dont fit too well into the burner blocks and they too (the burners) should be replaced. The coil surface burners are pretty much universal and the part numbers for the least expensive exact replacement parts are
6 inch burner SP12YA
8 inch burner SP21YA
GENE
Oct 09, 2011 | Whirlpool Electric Range
I am in the process of replacing my burners on a Jenn Air model #7200063LP. The burners appear to slide into the gas feed tube on the front part of the grill and attached to the back part of the grill with...
Yes, there really is enough space. Remove the cotter pin(s) and while lifting up the end of the burner farthest from you, pull the burner up and out.
To replace the burners, do the above in reverse. Just be sure the burner tube slides over the burner orifice, properly.
Hope this helped you change the burners and Happy Grilling!!
Jun 06, 2011 | Jenn-Air Grilling
Charmglow grill, cannot get gas flow to multiple burners
There is no test for the regulator since they are factory set. Replace it that is your problem.
Aug 01, 2010 | Grilling
Kenmore Burner Hissing Noise?
You are on the right track. Check if you can clean the burner. It may help. If you do have to replace the burner, get the stainless steel replacement. It costs a little more, but it lasts 10x longer than the steel burner assembly.
Apr 26, 2009 | Kenmore 437 sq. in. Cooking Area Gas Grill...
Magic chef gas stove has flames coming from the bottom
Replace the burner. Quickly. Do not use that burner until it is replaced.
Apr 23, 2009 | Magic Chef 31000 Gas Kitchen Range
I need to know how to remove the stainless steel burners and replace them.
Call Weber to receive free warrenty burners. Have model and serial number found inside one of the doors on your grill. I just received them in the mail about a week ago and just replaced my burners today. Here is what I did.
Remove the grates and burner heat deflectors. There are 4 screws on the knob panel, 2 on the left and 2 on the right. Remove the screws and pull back about a inch or two. I found it helpful to open all the doors a bit to rest the panel on them. The burners should remove easily once this is done. Replace the burner tubes and be sure tubes have holes facing up on the one side for correct heat distribution. When placing the knob panel back on, make sure that burner tubes go onto the gas control knob correctly. Replace screws on the knob panel.
****Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.****
Apr 16, 2009 | Ducane 30400042 (LP)
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Weber Genesis Silver C Grill Logo
489 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Weber Grilling Expert? Answer questions, earn points and help others
