Question about Coleman Heating & Cooling
Coleman EB23B heat pump: Air Handler Humming Loudly, Blower Runs
Coleman EB23B heat pump: At the air handler, inside house, humming/buzzing starts the instant the fan knob on thermostat in turned on (while in Cool mode and Cool ''Off'' also). Blower starts in a second or 2 but the hum is instantaneous with turning on at thermostat. Blower seems to run ok but hum continues and ceases only when blower turns off. Replaced the run capacitor on blower but no change in hum as described above.
Blower motor had big clumps of dust on back and is likely dirty inside but squirel cage spins easiliy when pushed by hand.
There was a clogged pan drain pipe that was overflowing (the cutoff float switch was submerged and did not turn off the unit as intended. I cleared the drain and it now drains).
Why is this thing still humming/buzzing? Is the fan needing cleaning, is it going bad? Something else maybe?
    Novelist:
    Champion:
  • 246 Answers
If you're mechanically inclined - and you seem to be - with all the stuff you've already done - you should be able to 'fix' this problem - if you decide to after reading what I have to say.
First of all - the humming you hear is most likely your 'fan relay.'
The fan relay is nothing other than an electrical coil that is enerigized by 24 volts from the thermostat. Once it's enerigized - it snaps together a set of points (usually copper) which completes a circuit sending 115 volts to your inside fan motor.
These 'fan relays' are notorious for 'buzzing' especially when they are wore a little. If it was me - I'd change it out to keep from having to deal with it at a bad time, i.e. 4th of July - Labor Day or just a lazy weekend.
If you decide to do this yourself - just be sure you have all voltage off before you mess with it. The relay is easy to find - just trace the line voltage wire - from the relay to the motor or vice versa. It (the line voltage wire) might go to a terminal block (although I doubt it) in which case you just need to determine which wire on the terminal block goes to the fan motor. In any case the relay will probably be black and it will have 4 wires going to it. 2 of the 4 wires will be the low voltage (24V) and the other 2 will be the line voltage (115 volts).
When you remove the relay just be sure you label all your wires so you can replace them on the new one just like they came off the old one. Usually the low voltage wires will go to the terminals marked 'coil' and the line voltage wires will go to terminals marked line but not always. The low voltage wires may go to numbered terminals that has a picture of a coil and the line voltage wires will go to numbered terminals that show an open wire connection.
Try and get an exact replacement but if you can't - have the parts man explain to you (if need be) which are the low voltage terminals and which are the line voltage terminals.
You'll probably have to go to an Air Conditioning Supply House - I doubt if Lowes or Home Depot will have the relay - but hey - it's 2010 - they might have it. Might be worth a try.
Also - if you have a buddy or relative in the AC business you might see if he/she would go by and pick you one up. Some AC Supply houses sell 'wholesale' to everyone but most - sell 'retail' to the general public.
So, if you can get it wholesale it will save you a few bucks.
Last thing... since I'm not there to look/listen to the buzzing - there's a small chance it could be something else - but I doubt it. Also, sometimes if you just 'tap' the relay with a screwdriver or pliers it might stop the buzzing - although I doubt it will stay quiet - it'll probably start buzzing again - but - then again - it might not.
Hope I've helped - and it's something different - get back to me.
good luck!
Posted on Jul 29, 2010
Goodman air handler ARUF036-00A-1A does not blow air in heating or cooling mode only hums/buzzes, what could it be?
Looking at the wall thermostat, you will see the fan switch that has two settings: fan auto, fan on.
You will need to place the fan switch in the fan on position for testing purposes.
This will make the indoor fan run continuosly, and never cycle off.
In the fan auto position, the fan will turn off when the thermostat temperature setting has been satisfied.
Remove the air handler access panel.
Is the air handler fan operating?
If the fan isn't working see if you can listen closely if it is humming, or can touch the motor to see if it is hot.
If it is humming and has a bad capacitor, you can tell this without having an electrical tester by spinning the fan wheel by hand.
Be very careful... making sure your hand won't get cut by the fan wheel spinning when it starts up.
If the fan spins and picks up full speed, replace the defective fan capacitor.
It is the shiny silver metallic cylindrical object with electrical wires attached to it.
Make sure you write down where those wires attach and turn the power off before removal as they carry 240 volts to the fan motor.
If you find that the fan wheel doesn't turn freely when you try to spin it by hand, the bearings have seized and you will need to find another fan motor of the same size, shaft length , speed , and horsepower to replace the defective motor.
Keep in mind that a humming sound in the air handler COULD be from the transformer instead of the fan motor.
The transformer is a black cube shaped device with electrical wires attached to it.
If the 24 volt transformer goes bad, your thermostat will not function and nothing will come on.
Dec 01, 2014 | Goodman Heating & Cooling
What causes my AC to sometimes stop cooling & can hear a buzzing from the motor?
The blower motor probably needs very badly to be cleaned, lubricated, or replaced, Michael.
Aug 06, 2014 | Heating & Cooling
WONT RUN OR KICK ON HUMMING
Without more information, If you have a split system heat pump and hear humming from the indoor air handler, it generally means that the blower motor has failed.
Jan 30, 2011 | Heating & Cooling
RUUD heat pump system does not cool properly.
With a heat pump system there are always going to be a back up heat strip inside the Air Handler.
If you detect a faint humming in the Condenser call your local service company and ask them to come and replace your capacitor in the condenser. The humming is from the contactor engaging but not being able to start the compressor due to not having the required Microfarads to start it.
Let me know if this helps
May 07, 2009 | Heating & Cooling
Heat pump is humming loud>
When the heat is not on. Go to the T-stat and turn the fan to the on position. With the blower now running is it making the noise? If so you probably either have something in there such as the filter that was mentioned, a piece of paper etc. or one or more of the blades on the blower wheel is vibrating. Don't let the condition persist w/o having it checked out or you may turn a simple fix into a costly one.
Jan 22, 2009 | Heating & Cooling
Air Handler Blower Unit Humming
More then likely it's the transformer. It may be getting weak. I've seen them hum/vibrate almost new and last for years. It's more an annoyance than anything.
Jan 18, 2009 | Heating & Cooling
My new Amana compressor Central Air-Heat Pump hums very loudly
When it hums, is it running? Or does it not run when it hums? I'm assuming it runs when you say you have to turn the therm off to get the noise off.. If it's humming and not running, you have big problemo friend..
Dec 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Wiring diagam for goodman heatpump and air handler to thermostate
On your t-stat you have Y, W1, W2, R, O, G, B or C or X. Y is your cooling circuit and will be the same in the air handler and heat pump unit, use the yellow wire for this circuit. W1 and W2 are your back up elec. or gas heat. Depending on how many kws or heat strips you have and t-stat wires you will put the white wire to W1 in both the t-stat and air handler. W2 is for your second stage back up heat if air handler calls for it, this will be a tan or brown or black t-stat wire and goes to W2 on t-stat and air handler. R is half of your 24v control power from the transformer and is the red wire and goes to the t-stat, air handler, and heat pump. O is for the reversing valve in the heat pump that switches it from heating and cooling. You guessed it the orange wire connect to t-stat and heat pump. G is for the blower and is the green wire to the t-stat and air handler. B or C or X is known as the common which is the other half of control circuit from 24v transform it is the blue wire and goes to the t-stat, air handler, and heat pump.
Oct 09, 2008 | Goodman Heating & Cooling
The fan for my air conditioner will not turn. When we cut the system on it makes a humming sound and the light go dim for just a moment and this goes on repeatedly. No heat or air. We have a dual...
If the humming noise is coming from the attic it would indicate that the blower motor on the air handler is trying to start but the rotor is locked.
If the humming noise is coming from the outside unit and the fan runs but the compressor does not your compressor has a locked rotor.
If the blower motor is the problem the outside unit should still start as normal but you would have no cooling due to no air movement.
In ether case it sounds like you need to call a service tech to diagnose your system.
May 03, 2008 | Heating & Cooling
Heating & Cooling Logo
347 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
