Question about HP Compaq Presario F750US
THE DVD DRIVE DOES NOT READ WELL - HP Compaq Presario F750US
  • 808 Answers
Lense problem<!-- from fixya rte -->
Posted on Aug 16, 2010
  • 358 Answers
Try this quick fix :
What I suspect here is that you tried a bad CD or
DVD disk inside your drive, in that case, get a very
good lens cleaner to clean your drive first.
If that doesn't work,
Get a screw driver and trace the screw holding the
CD/DVD Drive to your system at the back of your
laptop, then unscrew it and remove your drive. If you
cant do this by yourself, just try and get a good
technician to do it for you. Then clean the interface
connecting the drive to your laptop.
After this, power up your system normally without the
drive connected.
Then shut down properly, and reconnect the drive,
making sure that its firmly connected.
Then power on again and check it in the system
BIOS if its now detected, then save and exit, then
boot your system properly again.
If it doesn't work after this, then I'm afraid you might
have to get another drive.
Hope this helps you out.
Posted on Jul 29, 2010
Ok i asked before if my drive will burn both dvd and cd. the answer was yes. but when i installed the drive and ran my dvd creator program. it said this drive is dvd read only.
Hi mikey7420 ,
The drive name itself is the clue to know whether it can burn dvds or not.
  • In your case it's a CD-RW (read and write or rewritable) and DVD-ROM (Read only memory and not read and write or rewritable as in the case of CD)
  • Perhaps the one who told you did not understand your question properly , and understood it , in the sense that it can read CDs as well as DVDs , as far as Dvd-ROM drives are concerned many shopkeepers who are especially new working in the shop just make a guess and answer our question which could lead to this misunderstanding or incorrect information being passed on.
  • So the next time you buy a DVD drive which should have a read and write functionality as well , then look up for a CD_RW,DVD-RW drive.
  • Also remember that DVD-RW drive can by default read and write CDs as well , but it's not true for CD drives..
  • So usually a DVD-RW drive can read and write Cds as well as DVDs but a CD-RW drive can either read or read and write a DVD depending on whether it's a DVD-ROM or DVD-RW.
Hope this helps.
May 11, 2011 | Philips CDD 5101 (CDD5101/33)...
Cannot read the dvd disc
Your problem could be the DVD itself (make sure that the disc is not scratched or dirty) or the DVDD drive. If the drive will read other discs then the problem is the actual DVD. If the drive will not read anything else then it is time to replace the drive.
May 05, 2011 | Computers & Internet
What is the advantage of having a super multi dl drive
This drive recognizes almost all formats of CD & DVDs available in the market
The drive can read and write the following media
1. Write CD R / CDRW / Read CD , CDR, and CDRW
2. Read & Write DVD +R, DVD -R, DVD +-R, DVD RW / Dual layer DVD.
Normal drives will be specific to only DVD +R or DVD -R or single layer.
Jan 27, 2011 | Acer (KV.16X04.007) DVD Drive
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
My dvd drive doesnt reconise disks when they are in the drive
2 things that u have to check
1) Is your DVD disks damage so u cannot read it?
2) Is your DVD drive spoil so cannot read your DVD?
To check condition 1), u may try insert other "good" DVD to make sure your DVD drive may read it. If your DVD drive can read other DVD so this mean your current DVD disks are damage.
To check condition 2), u may try load your DVD disks using other laptop. If your DVD show readable on other laptop, then this mean your current DVD drive is spoil or may have poor lens sensibility. Try to clean your DVD drive or replace a new 1 if necessary.
YBC (/\)
Oct 02, 2009 | Acer Aspire 3050-1733 Notebook
I can read data cd but cannot read data dvd
Are you sure that the drive you are trying to read the DVD with, is actually a DVD drive and not a CD drive? Check on the front of the drive draw, it should say DVD on it. If not you will need to purchase a DVD drive to read DVD's. Nik.
Jun 30, 2009 | Computers & Internet
Combo drive not reading DVD
my combo drive also not reading dvd :(
Dec 23, 2007 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Dvd writer doesn't read or burn dvd/ but only read CD-R plz reply to ka_s5@hotmail.com
have you installed the softwares to burn DV/CDs? maybe you hadn't installed the softwares yet. normally samsung uses NERO. check the installation kits.
Oct 31, 2007 | Computers & Internet
How do I read the disc on a computer?
• Windows XP Install in-box software. Select DVD mode by the mode switch. Connect USB cable between Camcorder and PC. The DVD Camcorder appears as external DVD-RAM drive in Windows Explorer. DVD-R disc is read from the camcorder “ drive”. • Windows 98SE, ME, 2000 Install in-box software. Select DVD mode by the mode switch. Connect USB cable between Camcorder and PC. The DVD Camcorder appears as two external drives such as a removable drive and a DVD drive in Windows Explorer. DVD-R disc is read from the DVD drive.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
HP Compaq Presario F750US Logo
41 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
