Question about Car Audio & Video
How do i stop my jvc stereo from resetting, because every time i turn off my car every thing gets reset
    Scholar:
  • 96 Answers
There is a constant power wire and a switched power wire. The constant must be hooked up to a constant power (one that doesn't lose power when the car is off). Either the YELLOW or RED wire will be the 'constant on'. Or you can hook that one directly to the battery. The other power wire from the deck should be hooked up to the switched power (or plugged in with a fuse that turns on with the car). Voltometer is your friend here.
Posted on Jul 29, 2010
Jvc car stereo warning wiring chk then reset unit
MISWIRING OR CHKWIRING is displayed when there is a DC offset voltage detected at the speaker terminals ('+' and '-').
This is normally caused by connecting a '+' or '-' speaker wire to either GND or Vcc (+12V).
1. Collect cable not being used and make sure they are tapped off and reset
2. Remove a connected cable one at a time and press RESET
3. If after a cable removal and reset the error goes away, last cable removed was fault. Examine cable for short.
4. If you remove and reset all cables except for (RED, YELLOW, and BLACK) and you stilll have error, the short is internal of unit and requires service
Apr 18, 2014 | JVC AM FM CD DET FACE CAR STEREO
Cant reset car stereo
my name is larry i have a 1999 gmcyucon and it stuck in 4 hi,
Feb 19, 2014 | Cars & Trucks
How do i eject a cd from the JVC KD G510 car stereo. A CD is already in there but i can't figure out how to get it out and put a new one in
A malfunctioning stereo may least allow feature buttons to perform extractions of CDs. Depending on how the stereo was installed, the car would have to be powered on to attain stereo functionalities. Second, CDs have to be inserted with the readable media side facing the appropriate lenses to achieve results. A wrong insertion of the CD into stereo compartment may require forceful extraction. Observe the type of stereo to ascertain CD extraction also known as reset buttons. Usually a tiny area, the reset button allows inserting an object that forces the car stereo to eject stuck disks. Every mean to eject stereo disk have to be performed while the car is turned on to utilize the source of power. An unsuccessful attempt to dislodge CDs in stereo compartments would require auto electrician's consultation. An unsuccessful dislodge attempt usually requires acquiring a new stereo in replacement of the malfunction.
Feb 02, 2011 | JVC KD-G510 CD Player
Roatating Demo Screen
hold down the SEL button until it says demo, then turn the vol dial to the left , it will then say demo off. This should fix your problem.
Apr 30, 2009 | JVC KD-G430 CD Player
JVC head unit problem
Do you have a "RESET" button on your stereo? Check your owner's manual to find it. I have a JVC unit in my car and the reset button is a small hole behind the detachable face. Take the end of a pencil or a pen and insert it in the tiny hole and hold for a few seconds. This should reset the stereo so you can get the CD out. Hope this helps...
Aug 28, 2008 | Car Audio & Video
Car stereo jvc kd-avx33
"Reset 08" means the unit is not connected properly. Check the connection/connector.
Dec 18, 2007 | JVC KD-AVX33 Car Video Player
CD Player
I'm currently having the same problem. Take the face plate off. Use a pin to reset the stereo. It'll probably stop working again, but at least you'll be able to get your cd out and take it somewhere to have the stereo fixed or replace. (STAY AWAY FROM JVC!)
May 20, 2007 | JVC KD-G200 CD Player
Car Audio & Video Logo
64 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
