Question about Whirlpool AD40USL Dehumidifier
My humidifier clicks the circuit breaker off when it swtiches from normal running to actual dehumifying mode. It's a Whirlpool AD5oUss1
2 Suggested Answers
SOURCE: Dehumifier blows out my electrical switch in my electrical panel.
You definitely have an electrical short in the unit and should stop using immediately. Have it checked out by a licensed electrician. It is a very real fire hazzard.
Posted on Jun 07, 2010
My husband saids run the dehumifier on low setting to take out dampness in the basement? I said no, run the dehumifier on higher setting like 50 or 60 to take more water out of he basement? What should...
Actually, your husband is correct. The settings reflect the amount of humidity you want to remain in the house. I really don't think you want to leave 50 to 60% humidity in the house.
35% removes the greatest amount of humidity.
Hope this helped answer your question and thanks for choosing FixYa.
Sep 16, 2011 | Haier HDN655E Dehumidifier
AhhMy dehumifier runs but dosen't collect water.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 31, 2011 | Whirlpool AD50USS Dehumidifier
The amp blew in the DD50PC Delonghi and we need to replace it. What is the amp?
rmbm521 - I would like to help you, I have been offering solutions to humidifier problems for some time. But, I have never heard the term "amp", as would apply to a dehumidifier. In most general electrical terms "amp" or "amps" is the amount of electrical draw or use that an electrical appliance uses. It's short for "ampere".
I don't know where you heard it, read it or who told you that. But, they may have been referring to the circuit breaker , that's in your home's circuit breaker panel,. The one that feeds the outlet, the dehumidifier is plugged into. If that's the case, was your dehumidifier tripping one of the circuit breakers in you circuit breaker panel? If that's the case, they meant, the circuit breaker was not rated high enough to carry the load of dehumidifier, when it was in operation.
Hope this helped you. Please let me know. Thanks.
Jun 16, 2011 | DeLonghi DE50P Dehumidifier
I have an ad50 dsr1 whirlpool dehumifier. Has been great for a couple years but now when turned on it instantly trips GFI. After further investigation I found the wires on top of the compressor are...
heatman101
Jun 02, 2011 | Whirlpool AD50DSL Dehumidifier
Unit will start and run for 5 seconds, then will blow a circut breaker on 20A. circut. This is a model AD75USTO Serial # QU2660438 AKA Whirlpool gold energy star
Hopefully, it's not a problem inside the unit that's causing the circuit breaker to trip. Is there another electrical appliance plugged into the same outlet or on that circuit that is ON and draws 15 amps of power? If so, that's the problem. If that's not the case, turn the circuit breaker OFF and remove the outlet cover, so you can inspect the receptacle and it's wiring. A loose wiring connection or a broken or cracked receptacle could be the issue. If you don't find any damage reassemble the outlet and turn the circuit breaker back ON. Instead of plugging in the dehumidifier, plug in a lamp or something similar and turn it ON. Leave it on for more than 5 minutes to see if the circuit breaker trips again. If it does, you'll know the problem is either with the outlet receptacle or the circuit breaker. If doesn't, plug in the dehumidifier (Make sure the Master ON/OFF Switch on the unit is in the OFF position, before plugging it in. Then turn the Master ON/OFF Switch to ON and set your controls. If the circuit breaker trips again, the problem is in the dehumidifier. You will need to call Whirlpool Customer Care, as it's an internal electrical issue.
In case you have misplaced your Owners Manual, I have included a link to it, that you can download and print for future reference. http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%201188927.pdf
I hope what information I have provided to you, will help you trouble shoot and solve the problem.
Apr 16, 2011 | Whirlpool 75-Pint Dehumidifier
I have a Whirlpool AD75UST humidifier that stopped running, almost like it blew a fuse or something. Does it have a fuse somewhere? Any other possibilities? Thank you!
Have you checked the receptacle it's plugged into, to see if it's still working? Use an electric lamp to check this. If the lamp doesn't work, the circuit breaker in the home's main panel has been tripped. Unplug the dehumidifier and reset the circuit breaker. Then plug the dehumidifier back in. If it trips the circuit breaker again, there's an electrical problem within the dehumidifier.
In answer to your direct question ... some dehumidifiers have a reset switch. It's probably on the back of the unit, above the water collection tub. if all else fails consult your Owners Manual's Trouble Shooting Guide. If you have misplaced it, you can download it from the Whirlpool Appliance starting at their home page.
Hope this helped head you in the right direction to solving your problem.
Mar 01, 2011 | Whirlpool 75-Pint Dehumidifier
Jun 07, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
I have a LG LHD45 EL dehumifier, stopped working suddenly
Check the glass fuse on the circuit board inside the power supply at back of unit (have to take off cabinet)
Dec 03, 2009 | LG LHD45EL Dehumidifier
Humidifier does nto turn on.
It sounds like the Dehumidifier has a problem somewhere on the circuit board. You could try and find a local humidifier repair shop in your area otherwise it may be cheaper to purchase a new replacement instead of having it fixed. Good luck.
Tech - 101
Jun 23, 2008 | Whirlpool AD40USR Dehumidifier
Adjusting dehumidifier on furnace
This model furnace does not come with a built in humidifier. Humidifiers are normally an optional add on. If you have a by-pass type humidifier it is none adjustable. Water level is normally float controlled and operation is control by blower circuit. When ever the blower runs the humidifier operates when in the heating mode.
Jan 24, 2008 | Dehumidifiers
Whirlpool AD40USL Dehumidifier Logo
61 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike Squire
Mike
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
