I have a Technics Stereo Amplifier SU-G90 ...the source keeps switching to tuner on its own...what do u suggest..?
  • 3,083 Answers
The chances are the microprocessor has some lint or dust impeding the signal and switching modes. Either this or a switch is triggering for some reason. It's also possible that the cpu has a heat problem and causing the switch, and you can check that by spraying cold spray (freon) on the suspected component after it switches...just to see if it switches back. If it does, the IC is bad. You can blow the electronics out with some compressed air, and then use alcohol to clean dusty areas or legs. Toluene is the best liquid to use, but it's been outlawed for consumer usage. I've saved many a processor due to dirt between microprocessor legs, even back in the old days.
If you can get hold of a schematic, you can trace the line feed from the mode switches to the microprocessor, and sometimes you can do it without one, however, then you have to identify the tuner output, which can be cumbersome, also. In other words, one will have to figure out what is causing the problem, and unless you can spray a switch with contact tuner, you have to use a meter, or hope to get lucky with a good cleaning.
If you elect to have it serviced, get an estimate (high and low). It can be a bit high, if it's tricky.
Good luck, and hope this helps.
Posted on Jul 29, 2010
Does a technics stereo amp su-g90 have a stereo to play music
This device does not have an internal tuner. It is simply an amplifier. The buttons on the front labeled TUNER - TAPE - PHONO - DAT/VCR 1 - VCR 2/TV are selector buttons for additional components that hook up to the respective connectors at the rear of the unit. If you want to play a radio with this device, you must buy a tuner and attach it to the tuner inputs in the rear of the unit.
Oct 03, 2016 | Technics Audio Players & Recorders
Where can I get a free manual
go on panasonic website or google the manual you want.i use manuals lib
Jul 02, 2014 | Technics Audio Players & Recorders
On my Technics SU-G90 where do I connect the subwoofer
Some amps have a single RCA socket for a powered sub. If it has not got one of these then the amp has no output for a powered sub. If so then you can only use a none powered subwoofer, which will connect via the speakers of the amp, see the subwoofer manual for how to do this.
Feb 18, 2014 | Audio Players & Recorders
SUV500 2-Channel Amplifier: Hi! can I connect another technics cd-player,sl...
yes you can connect another cd player to the DAT input of your amp.
input connections like DAT, TUNER, CD, AUX etc (except phono) is just to differentiate between what sources are connected, the amp cannot tell what source is connected and will output the sound no problem.
as for the remote operation, if the 2 technics cd players are switched on at the same time they're going to do what you command from the remote together but you'll obviously be listening to 1 at a time.
May 17, 2010 | Technics SUV500 2-Channel Amplifier
Technics SU-G91 OVERLOAD PROBLEM
THe amp has detected a problem and shutdown to prevent further damage. This unit has 2 amp pacs inside and one or both have failed. If you can solder, you can fix this yourself. The main amp pac is an SVI3206 and can be purchased online for about $60.
Keep me posted.
Dan
Oct 17, 2008 | Audio Players & Recorders
Technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Jun 24, 2008 | Audio Players & Recorders
 Grubhead
Grubhead
