Question about Mitsubishi Televison & Video
Tv would shut off when watching Iwould have to turn back on and it would work. Now when I turn on I get only a blue screen
  • jas0321 Jul 29, 2010
    model#ws-55613 the sound does not work
  • jas0321 Jul 30, 2010
    model ws-55613 you havnt given me an answer yet
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please post a comment with the model no# of your Mitsubishi TV and also please let me know if the sound is working fine so that I can further assist you.
Thanks
Rylee
Posted on Jul 29, 2010
  • Rylee Smith
    Rylee Smith Jul 30, 2010
    Thanks
    for accepting the solution and sorry I missed your last comment. It seems to be
    an issue with the circuit board that has gone bad and should be
    tested/replaced. Also check the 9v regulator and the capacitors as if they are
    bad it won’t work.
My TV will not connect to the cable box unless I unplug it and plug it back in!!
Hey Cc.
I have the same problem sometimes... I got a new power cable and new box from the cable co., it has worked well so far..(over a year!)
Sep 15, 2017 | Televison & Video
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
Tv screen has turned blue and I can't watch tv
i think by accident you have changed the input when you went to change the volume. look for a button labeled " input" or "video" select on the remote and scroll through the various choices. you should get your picture back.
Jan 21, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Screen turns blue then shuts off.
I already replied but once again..
Symptom shows Blue CRT (picture tube) in your TV might defective and need to be replaced. Its high tech repair issue, so contact tv tech person if you don't have enough knowledge about tv repair.
Sep 05, 2008 | Toshiba 51H84 51" Rear Projection...
Tv turns blue the shuts off.
symptom shows Blue CRT (picture tube) in your TV might defective and need to be replaced. Its high tech repair issue, so contact tv tech person if you don't have enough knowledge about tv repair.
Blue screen sony
blue crt shorting use crt restorer to lift short or replace picture tube /crt
Aug 19, 2008 | Sony KP-46WT500 46" Rear Projection...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
TV shut off will not stay on.
Sounds as though you have a video problem. It may be the convergence chips. The TV is shutting down do to a default in the circuit ( the set knows there is an error of somekind so it shuts down to protect itself). This is a problem that needs a pro trouble shooter since it could be in about any board. Sorry I couldn't help more
Ed
NC Electronic
Mills, Wyoming
Jan 07, 2008 | Mitsubishi VS-55707 TV
Black has turned blue and shutting off
That usually means the x-ray protect circuit was triggered. The set is going into protect shutdown for some reason. It may be a valid trigger to a lame problem or a fault in the detection circuit itself. I would hang a scope on there and just watch to see if there is a strange movement in voltage values, and if so, troubleshoot it from there. The blue picture is a result of a convergence problem. If you don't know much abou TV repair, I would suggest taking it to a Toshiba authorized servicer for proper diagnosis.
Jan 29, 2006 | Toshiba 32A43 32" TV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
