Question about Dell OptiPlex GX150 PC Desktop
How do i set up my bios because i mess it up and the tower wont detect my c drive or hard drive
  • 110 Answers
It is possible to reset it to defaults. Enter the bios again, move to the very right menu, and select Restore to defaults.
Posted on Jul 29, 2010
How do I fix a problem were a tower computer won't see the slave hard drive.
It sounds like both drives are trying to be the master on the cable. Have you tried setting both drives jumpers to the CABLE SELECT setting. This allows the BIOS to individually identify them and you specify in the BIOS which is the primary boot drive.
Mar 22, 2016 | Dell Computers & Internet
HARD DISK NOT DETECTED, WHEN STARTED SOUND COMING FORM HARD DISC
Most likely, hard drive failure.
If a portable, re-seat the drive, then reset the bios defaults, and see if the hard drive is detected.
If a desktop/Tower, re-seat the cable connections to the drive and the motherboard, reset the bios and see if the drive is detected.
If the "Noise" from the drive is a grinding sound, a repeating Click, or a laser sound similiar to a star wars movie then almost guaranteed drive failure.
Jul 31, 2011 | Samsung (SP0822N) 80 GB Hard Drive
Stuck on the IBM Thinkpad screen. Tried to click on F12 to open in a different mode... but it just says Preparing Boot Device List.
it sounds as if you have a hard drive failure, or the BIOS settings are messed up for some reason. Try going into BIOS by hitting F1 or F2 or F10 or Delete... or maybe your laptop has a special button for going into BIOS, and find the Boot Device Options to see if your hard drive is the first boot device. Also, you may want to check the Standard BIOS Settings and the PC configuration settings. The names of these settings depend on the BIOS version you have, but the bottom line is that you need to find a list of devices recognized on your laptop, and see if there is any entry for a primary hard drive. If there isnt a primary hard drive, find an option that does auto-detect of hard drives and run the detection sequence. If nothing comes up then your hard drive is probably dead or damaged, and you'll need to get hands-on help to deal with the problem.
Jan 13, 2011 | IBM ThinkPad A21m 2628 Notebook
My computer wont detect my hard drive. can seatools detect it?
Check if the BIOS is able to detect it then only you would be able to detect it using any utility. Alternatively you can check for the jumper settings also. Try making it slave.
Jun 18, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
Hard drive goes on blue light go around once pc
Tried to boot the computer in bios. Check if the harddrive is detected in bios. If not detected. Shut down the system,take out the power cable.open the tower and disconnected the hdd IDE cable and connect it to a differnet IDE port. Restart the system and boot in bios check if hdd detected. If still not detected possible issue with hdd. Try connecting on different computer if still issue persist replace Harddrive.
Aug 18, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Computer wont boot
Your hard drive has failed, and thus your laptop cannot read it. Or someone intentionally formatted your PC, and now you have to reinstall Windows.
Or someone messed with your bios settings. When your computer boots up it should say a key to press to get into bios settings, if you can't see it just look in HP's support section of their website, and it should tell you there. When you get into bios settings, make sure the hard drive is at the top of the 'boot list' so it detects the hard disk first. If it still doesn't work, then you have to try reformatting/reinstalling windows, or get a new hard drive.
Mar 11, 2009 | Compaq Presario C700T Notebook
Emachines desktop Wont boot.
A simple and effective task (well most of the time) is to reseat components on the motherboard. This can include unplugging the components, including but not limited to:
Hard Drive and Optical Drive Cables
IDE/SATA Connectors
System Ram
AGP / PCI / PCI-E add in cards
Note - Never mess with the processor unless you feel qualified to do so.
If after reseating all the components, the computer still does not boot, try setting in your BIOS to start up from the CDROM and insert your recovery disc into the drive and see if the recovery detects the drive. If it does, its most likely the boot header in the file system has gone kaput. You could attempt a re-installation of Windows by choosing the repair option, however, this is a last resort thing, and if you cannot do this either, then you might be in the market for a new computer.
When a new computer is bought, you might want to buy an external USB Powered enclosure for your hard drive so you can plug it into the new tower and recover all of your documents.
I know how the failing computer feeling feels like........ So good luck!
Aug 30, 2008 | E-Machines eMachines Desktop PC
Detecting hard drives
try bios settings it may be set for a particular hard drive not yours and not on auto detect set for auto detect
Aug 02, 2008 | MSI K9A2 CF-F V2 AMD 790X AM2+ Phenom FX /...
Hard Drive - Adding 2nd Hard drive
Try re-setting the CMOS setting, use the jumper to reset.
-mrsolution
Jun 11, 2008 | Dell Dimension 2400 PC Desktop
I have a dell tower that has windows 98,when i turned the tower on,it is saying the primary disk drive 0 cannot be found.what does that mean,and what can i do to get it to work?
Your hard drive is not being recognised by the motherboard. Try this...
  1. Unplug your computer from the power supply.
  2. Remove the side cover on the case.
  3. Unplug the 2 cables from your hard drive. (it will be at the front of the case and look like a block of metal with 2 cables going into it)
  4. The plugs will only go back in one way, so be sure you have them the right way around before trying to reconnect them The power plug has 2 tapered edges on the top and the IDE cable (the thick one) has a notch. Both will match up to the hard drive. On some older driver/IDE cables there is no notch. In this case, the red wire will be closes to the power plug.
  5. Reboot and see if it is detected now.
If not, post back and we can try something else.
Apr 16, 2008 | Computers & Internet
Dell OptiPlex GX150 PC Desktop Logo
97 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
