Question about Orion STV2763 27" TV
No Aux Channel but I have the yellow and White plugs in the front!
I cannot change it to the aux channel to play my Nintendo Wii. I lost the remote and i am using a different one. Is there anyway to get the aux channel back? Please help me.
have a wii, no remote to tv and cant find aux ch. to play it??? help!!
  • 186 Answers
Certain Universal remotes have extra menu and input buttons. Take a look around and see what you can find.
Posted on Apr 24, 2008
2 Suggested Answers
SOURCE: No Aux Channel but I have the yellow and White plugs in the front!
Take out the channel up button and use a small, long object (like a pencil or pen) and repeatly press the button under until AUX comes up.
Posted on Jun 19, 2008
What channel does my tv need to be on? and what button do i press on my dish network remote to get me to the wii screen
Usually it depends on how you connected to the TV/satellite box- for instance, I have mine set on channel AUX 1 since I have connected my Wii to the TV using the component cables (the red yellow and white cables) to the port AUX 1. If you've hooked it to the Dish box, then it would be whichever accessory you connected is the channel to select in the dish system, but on the channel that your dish is hooked up (it's situational!)
Jun 25, 2011 | Nintendo Wii Console
Wii help
Hello :
1:Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console.
Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
Yellow = Video Input
White = Audio Input Left (or Mono)
Red = Audio Input Right
3:Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
I hope this will help .
Mar 23, 2010 | Nintendo Wii Console
I need to know what channel to operate my wii on. I have a toshiba tv that is about 8 years old.
Try changing the TV inputs to VIDEO or AUX, using the remote or a button on your TV. If there is not a way to connect the Wii to the TV using the 3-cable system (Yellow, Red and White), then you might have to use a VCR or DVD player to plug the 3 cables into and then transmit the audio and video from the Wii using the regular cable line of VCR or DVD Player on TV channels 3 or 4. If your Wii has a regular TV Cable jack on the back, connect that to the jack on the back of you TV and select channel 3 or 4.
Jan 05, 2010 | Nintendo Wii Console
What channel should the tv be set to?
Tv needs to be set to channel 3 or you need to change the input on the tv if you are using the rca jacks on the tv. The other way to hook it up is if you have an rf modulator. You can get the at walmart or radio shack for 20.00 dollars.
Dec 10, 2009 | Nintendo Wii Console
Input select sttting
Normally, your TV or VCR is probably set to display the television channels you watch, through a standard cable input. In order to play your Nintendo using the A/V cables, we need to tell your TV or VCR to switch from the normal tv channels, and instead display the signal coming in from the A/V cables of your Nintendo system. There is no one particular way to do this, as it varies between brands, but below is some information that may help.
Quick Tip: Grab the original remote control for the TV or VCR you have plugged your Nintendo into, and look for a button that could be labeled:
  • TV/Video
  • Input Select
  • Line or Line In
  • Source
  • AUX (auxiliary)
  • EXT (external)
  • any other button that seems to indicate it would switch between the TV signal and the game system.
If the above tips did not help, it is possible your Input Select is a little more difficult to locate. Here are some other common ways to access an Input Select:
  • A button on the front of your TV or VCR located behind a door or a hidden panel, or located on the original remote control that came with the device. If you are using a universal remote, it may not work when pressing the "input select" button. If it does not work, try to locate the original remote.
  • A high or low end channel. Try channel surfing through every channel, even the ones that do not normally broadcast a TV show. Many times the input select is a high channel such as 90, 91, 92, 93, 99, or even 999. You should also try low channels such as 0, 00,001, 1 or even 2. For some televisions, you may need to manually select these channels by using the keypad on the TV or remote control.
  • Found within an on-screen menu. Search the menu for words such as Input, Setup or Source. Select one of these words, and another menu will usually appear that asks you to select between TV and either AV, AUX or Line. Select AV, AUX or Line to display the Nintendo game.
If you are still unable to find your input select, you may want to consult the operation manual that came with your TV or VCR, or contact the manufacturer directly.
Nov 19, 2009 | Nintendo Wii Console
How can I re-connect wavebird remotes to my Wii?
Well you should but new battery's or you you could just change the channel and put the same channel on the controller it will work
Jul 10, 2009 | Nintendo Wii Console
This Rockster guitar from Psyclone Essentials, PSE6300B, is bad.
For use with RB (The Beatles version of RB, anyway), the instructions that come with the Rockster guitar are completely wrong. Unplug the wireless USB remote from the Wii. Insert a Wii remote into the guitar and use it as you would expect. Works just like it is supposed to.
Jun 05, 2009 | EA Sports Tiger Woods PGA Tour 08 for...
I have no color
Are you using the default video cable (Red, White, Yellow) for video and sound? Make sure the Red and White are connected to the audio in for video 2 and that the yellow is connected to the video in for video 2. It might also be labeled composite video on your TV. If you are using the Red/Green/Blue plugs labeled component or Y/Pb/Pr then that might your problem with the black and white video.
As for the controller sync problem, you should press the red button next to the SD card slot on the Wii and the red button under the battery door of the new Wii remote in order to sync the two.
Mar 30, 2009 | Nintendo Wii Console
Connection keeps gettin lost
Try changing your wireless router to channel 1.
Jan 10, 2009 | Nintendo Wii Console
Orion STV2763 27" TV Logo
662 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
