Question about Kenmore 72059 Air Conditioner
Water leaking from back of unit
Is water supposed to leak from the back of this air conditioner?
  • 8,197 Answers
Yes water is asposed to leak from the A/C unit. It is the condisation from cooling the air.
Posted on Jul 29, 2010
5 Suggested Answers
  • 105 Answers
SOURCE: Water leaking from portable air conditioner
First, make sure the unit is level. If so, you have a blockage or kink in the drain tube. Careful inspection should reveal any blockage, & you may be able to poke it thru with a piece of coathanger wire. Don't use excessive force, any block should be easily freed.
Posted on Jul 15, 2007
dcp2
  • 63 Answers
Sounds like the drain line is blocked you would have to take this unit apart in order to check this. I would use a can of air to blow out the leakage. Also make sure the unit is level
Posted on Jan 25, 2008
james3751
  • 614 Answers
SOURCE: My air-conditioner is leaking a lot of water onto the floor.
You may jst have a stopped up draon or drain pan. If you can get to thesmall whole that it drain out of. **** it out with a shop vac. If you have one. Russ
Posted on Jul 26, 2009
  • 4736 Answers
SOURCE: I have a Kenmore C120
Interestingly, your Kenmore Portable AC is manufactured by Delonghi. Occasionally, what you are experiencing happens when the humidity level is high and the air intake filter needs to be cleaned.
That also means that you will need to drain the tank, at least once.
You know where the drain plug is, so you can either carefully take it outside to drain or put a low sided container, capable of holding 1 1/2 quarts of water under the drain plug. If you drain it inside, turn the Master ON/OFF Switch to OFF and unplug the unit, before attempting to drain it.
Hope this helped you to solve the problem.
Posted on Jul 13, 2011
I have a Kenmore Portable ac unit and its leaking from the back in the middle of the vent. I drained the unit,but it starts leaking again within minutes. Is there something wrong or could it just be too...
All portables, alllll, you have to put unit in
window with a slight tilt, as the unit runs
it creates condensation that condensation
is the water leaking out the back it's supposed
to do that, I have seen people hook a hose up
an let it drain in a bucket.
even your car a/c leaks water
Jun 03, 2014 | Heating & Cooling
Water leak from Electrolux Kelvinator EPK09CRN2A portable air conditioner
You'll have to open it up and check for a displaced condensate collector. This may look like a funnel with a drain tube that is supposed to go to the tray
Nov 28, 2012 | Electrolux E23CS75SS Air Conditioner
Has water leaking out of the back of the system?? Is it suppose to have a drain hose to it??
It has to have some way to get rid of condensation. There should be a hose fitting or nipple located on it somewhere.
Jul 20, 2011 | Amana AP077R Portable Air Conditioner
My unit is leaking tons of water only when a/c is on for a while. It leaks out of base and I have to drain tank every day. Help!!!
It is supposed to "leak" water into it's reservoir and it needs to be dumped when it gets full. That water is the humidity that the a/c is pulling form the air inside your home. As long as it's going into the reservoir and not leaking onto your floor then it is working properly.
Jun 24, 2011 | Windchaser PACR10 Portable Air Conditioner
Own this unit for one year now and it is just starting to leak from the back of the unit. What can I do?
Leak water?
That is what it is supposed to do
The water will drain outside
May 27, 2011 | Heating & Cooling
Leaking water
mcdevito75 here, The portion of the a/c unit that goes outside the window is the evaporator and suppose to leak water, check the drain hole in the unit floor on the outside portion of the unit, reach this drain hole thru another window or have your local a/c repair shop look at it, they come to the house.
Jun 21, 2010 | Samsung AW0893L Air Conditioner
Leaking
Please check the water container for leaks. Normally,
it does not leak, since the water is supposed to evapo-
rate due to compressor heat. The water that the aircon produces goes to a containing pond near the compressor. So that if there is a leak, it emanate from
this area. May this tip help you.
Jan 10, 2010 | DeLonghi PAC C100 Air Conditioner
Excessive Leak
Remove the plug and tilt the AC slightly downward on the outside so the water will flow outside where it is supposed to go. Thanks, Sea Breeze
Aug 29, 2009 | LG Heat cool Window Air Conditioner
Mothers AC unit
That has nothing to do with the water. Sounds to me like it needs cleanning, (the water is not drainning toward the back of the unit) ,,(dirty filter, which its trying to **** air anywhere it can even thru the drain hole, or not enough slope, leanning toward the back so gravity can flow the water to the back of the coil! Thank you-very-much!
Aug 28, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Kenmore 72059 Air Conditioner Logo
52 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
