Question about Microsoft Internet Explorer 8
Exporting bookmarks - .url extension on every
When I export bookmarks in IE8 to the bookmark.htm file, all of the bookmarks end with the .url extension. That never happened with IE7.
    Brigadier General:
  • 7,191 Answers
This is a new feature in Internet Explorer 8 where all the different extensions of webpages (.htm, .asp, .com, .jsp, .pdf, etc) are denoted by a common .url extension.
When you open the list of exported bookmarks, you will see all the bookmarks or links have .url extension.
When you hover the mouse pointer on the bookmarks list (.url links), you will see the actual address/ link in the status bar at the bottom of the IE window. Also, if you click on the links, it will open the actual webpage.
Hope this answers your query. Thanks for using FixYa
Posted on Jul 31, 2010
  • 19 more comments
  • paula64 Jul 31, 2010
    Thanks for that answer but that's not really my problem. When I then import the bookmarks into a bookmark management program, I still have the .url extension and some of the names of the bookmarks are weird. Is there a way to get rid of the .url extension completely? I've gone back to IE7 since it was so annoying but IE7 keeps crashing. Thanks.
  • AliTech110
    AliTech110 Jul 31, 2010
    Many thanks for the feedback.
    As a workaround to this problem, you can use a bookmarks conversion tool to convert the IE8bookmarks to the format supported by your bookmarks management program.
    You can download and install the free bookmarks conversion tool from: http://www.magnusbrading.com/ftp/bmc32b2...
    In the program window, select the IE Favorites from the drop-down menu for "Bookmark Source" field. Then select Firefox/Firebird... from the drop-down menu for "Bookmark Target". Then browse the location to save the converted htm file and click Convert button.
    Now the converted bookmarks list will not show the .url extensions and wil also be compatible with other browsers and bookmarks programs.
    Thanks once again.
  • AliTech110
    Please refer to the attached image:
    Thank you for the reply. I don't seem to be able to load this software. Also, I export my bookmarks every day and then import them into a bookmark management program. Is this for every day use or just a one time application?
  • AliTech110
    Thanks for the reply.
    This program can be used daily or as often as required.
    Please let us know whether you were able to install the program on your computer? If you have installed the program, kindly run it by clicking Start button > All Programs > Bookmark Converter 3 > Bookmark Converter 3.
    Thanks again
    I download it but it won't install even after I try to extract the files. It says the folder is empty.
  • AliTech110
    I have downloaded and uploaded the setup file to another location. You can download it from:
    http://www.box.net/shared/5h94l2uzy4
    Thanks.
    I downloaded the converter but when I try to use it, IE stops working.
  • AliTech110
    The conversion process takes only a few seconds to complete. If the IE window becomes unresponsive, you can close the IE window before running the conversion program.
    Wish you all the best and thanks once again.
    It download but every time I try to open the program, IE stops working. I uninstalled and installed again and the same thing happens. Something must be incompatible with my sytstem.
  • AliTech110
    Kindly close the Internet Explorer and then try to use the converter program.
    Thanks.
    Still not working. I even rebooted and everytime I click on the converter IE stops working.
  • AliTech110
    It seems that this version of the program is incompatible with your IE browser.
    You can download and install Transmute converter from: http://www.softpedia.com/get/Internet/Bo...
    In the program window select Internet Explorer as the source and Firefox 1-2 as Target (see attached image). Then browse and select the location to save the html file and click on Start button. Also, close the Internet Explorer window before exporting the bookmarks.
    Thanks
    I'm confused. How could it not be compatible with IE?
  • AliTech110
    Kindly try to convert the bookmarks using Transmute conversion tool. Also, it is quick and easier to use.
    Thanks.
  • paula64 Aug 01, 2010
    It keeps sending me to a pdf converter tool.
  • AliTech110
    AliTech110 Aug 01, 2010
    This is ridiculous. It won't let me extract the files - same problem with the bookmark converter. What could be the problem? Thanks.
  • AliTech110
    You can download the Transmute setup files by clicking these links:
    http://www.box.net/shared/vt271vmkz0
    http://www.box.net/shared/2vmlzttcjb
    After downloading the files, run Setup.exe file.
    I'm still not sure it worked. I will have to get back to you tomorrow if that is ok. Thank you.
  • AliTech110
    Thanks.
How can I re-install but keep current bookmarks
In all Browsers, you can select EXPORT, usually from the FILE pulldown menu. If you export your bookmarks to a place on your hard drive and then copy to a memory stick, you can then IMPORT them when you are done upgrading the OS. Or you can export directly to a USB attached memory stick. In any case, export before you do the upgrade and then bring up the new browser, and import the bookmarks.
Aug 02, 2014 | Mozilla Firefox
How can I transfer my bookmarks to a new computer?
The simplest method to transfer bookmarks between computers is by "signing in" to Chrome on the first computer. All of your Chrome browser data and preferences (including bookmarks) will be saved into your Google account, and that will be available whenever you sign in again on any other computer.
Here's how to sign in: In the Chrome web browser, click on the wrench icon (upper right corner), then select "Sign in to Chrome".
Then enter your Google account user name and password.
All of your Chrome bookmarks, extensions and other preferences will then be saved into your Google account online.
Then on your new computer, install the Chrome browser, and again "sign on" with the same Google account. Your Chrome bookmarks, extensions and other preferences will be retrieved from your Google account.
See also these Chrome help pages:
http://support.google.com/chrome/bin/answer.py?hl=en&answer=165139
http://support.google.com/chrome/bin/answer.py?hl=en&answer=185277&topic=1693469
Alternatively, you can export your bookmarks from the Chrome browser on the old computer. Click on the wrench icon, select "Bookmark manager"; then select Organize > Export bookmarks. That will generate an HTML file. Copy that file to the new computer (e.g., by using a flash drive). Then on the new computer, install the Chrome browser, select "Bookmark manager"; then select Organize > Import bookmarks.
For more on bookmark export & import, see this helpfile:
https://support.google.com/chrome/bin/answer.py?hl=en&answer=96816
Hope that's helpful.
Dec 26, 2011 | Google Chrome
If I download IE8, do I lose my favorites I have with IE7?
No you should not They should be transported over to IE8 when you install it.
It may ask you if you want to transport them over to IE8. If it asks choose to do so.
Jun 20, 2011 | Computers & Internet
How do i import my bookmarks from firefox to safari
Hello. To import your bookmarks from your Firefox browser, choose "organze bookmarks" on the Bookmarks drop down menu at the top part of your firefox browser (or alternatively use ctrl+shift+B). This will open another window labeled "Library"; where all your bookmarks will be shown. From the "import and backup" drop down menu select "export HTML.."; a window pops up that will allow you to export/save your bookmark to a preferred location (Desktop, preferably). After which, open Safari, hit "File" then choose "import bookmarks" and just select the file that you earlier saved.
Nov 05, 2010 | Computers & Internet
Hi - My AVG scanner said that google chrome is corrupted - I would like to keep my bookmarks - so how can I go about repair - Right now it won't do much
If you can open Google Chrome you can go to the bookmarks and drag those to a new folder or your desktop. This will create a icon and when you click on it, it will open your favorites.
OR
  1. Click the wrench icon chrome_toolsmenu.gif on the browser toolbar. Mac users: If you don't see the wrench icon, go to the menu bar at the top of your screen and clickBookmarks.
  2. Select Bookmark manager.
  3. Drag the favorites into new folder or desktop.
Oct 21, 2010 | Google Chrome
Unable to access bookmarks from the yahoo toolbar
Some verions of Yahoo are now defuct, not that anyone will tell you. You need to get IE8 and open your browsing session from it.
Dont open with the old Yahoo version
1. Log onto the internet
2. Go to http://bookmarks.yahoo.com
3. Sign in with your usual email address and password
4. This will bring up a list of your bookmarks
5. Scroll to the bottom of the page and click on Tools
6. Click on "Export Bookmarks"
7. Make sure that all the bookmarks are selected
8. Below that where it say "Select Export Format" make sure it is set to for Internet Explorer and click "Export"
9. Save to the desktop
10. Open Internet Explorer
11. Then click on File, then Import
12. Select "Favourites" click Next
13. Browse to the "Bookmarks" file that should now be on your desktop and click Next
14. Your Bookmarks should now be in the favourites tab in Internet Explorer
Mar 04, 2010 | Computers & Internet
I have Windows XP and I am trying to copy my favorites onto a CD so I have a backup. I tried the import/export function but it is not working. Can they be copied to a cd or not?
You should be able to save you favorites to a CD. Try using the Import/Export Wizard again but, this time, save them to your desktop (don't try to export them directly to the CD).
I assume that you're using Internet Explorer. Open your Web browser then click File. Next, click Import and Export. This time when you get to the part where you choose a location to import the file, choose Desktop. Just click browse, when the window opens click Desktop then save.
After you have exported the file to your desktop, you should find a file on your desktop called bookmarks.htm. Next, copy (or send) this file to the blank CD. Once that's done, open the CD to see if the file was copied.
Hope this helps!
Apr 07, 2009 | Dell Computers & Internet
Backing up bookmarked sites in FF
Bookmarks > Organize Bookmarks > Import and Backup
You can choose to Backup or Export HTML. Save the backup/exported html file in your HD. Both can be restored later.
Hope it helps
Oct 20, 2008 | IBM ThinkPad T30 2366 Notebook
Open Questions:
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; nsapshr 10.0.3) Timestamp: Mon, 7 Jul 2014 20:45:22 UTC Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js
Jul 07, 2014 | Microsoft Internet Explorer 8
See all Microsoft Internet Explorer 8 Questions
Microsoft Internet Explorer 8 Logo
165 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
