Question about Astar LTV-32ASB 32 in. LCD Television
Picture shuts off
Tv goes on see picture for second then tv goes blank.
    Problem Solver:
  • 9 Answers
Is there a dark patch when you see the picture, easiest way to check is on the tv tuner with no cable attached, this way you have a grey static screen, if there is a darkness across the screen when it lights for that breif moment, then it may have a broken backlight tube. Had the same problem with my 32" LG.
Posted on Jul 29, 2010
3 Suggested Answers
  • 77 Answers
SOURCE: Philips 42 in. Plasma shut down
The LED blinking 7 times is a code to tell the service tech what is wrong with the TV. From what I've read at other sites it sounds like there;s a good posibility that it is a power supply gone bad.
You probably should call a TV repair shop for assisitance.
Posted on Feb 01, 2008
  • 21 Answers
SOURCE: I have sound but no picture on my 32 inch LCDHD
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Posted on Sep 18, 2009
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
Thomson flat panel tv has sound but no picture (comes on for about a second then goes blank)
if you can see if the screen lights from behind when the picture apears for a second then the problem is probably the invertor or worse the screen
Jan 06, 2013 | Thomson Televison & Video
The picture goes blank after about 3 or 4 minutes. I have to shut it off and wait a few seconds and turn it back on. It does this 3 or 4 times and then it seems to stay on.
When the picture go black,tv still have audio?Yes,than those 1 or 2 long boards that call the LCD inverter boards are the problems are dying.If picture goes black and no audio at all?Yes,than the tv Tuner signal board have problems is dying.The tv Tuner signal board it is the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shojimmy.com,Ebay.com to buy those 1 or 2 refurbish long LCD inverter boards or the tv Tuner signal board for the replacement.
Mar 02, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
My picture goes blank
One of two things, the backlight inverter board is going bad (usually has open winding on the transformers), second, the 24vdc power supply section of the main power supply module is bad due to bad filter capacitors.
May 25, 2009 | Syntax LT30HV 30 in. HD-Ready LCD...
No picture yes sound
I was told that this problem could be the power board.
Jun 17, 2008 | Televison & Video
Sony KV36XBR200
Picture tube is bad, time to retire this one!.....T.
Oct 22, 2007 | Televison & Video
Astar LTV-32ASB 32 in. LCD Television Logo
184 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
