Question about Craftsman Garden
Craftsman mower keeps breaking primary mower belt
I have a 7 yr old Craftsman riding mower (917.273663 - 25hp Kohler with 48'' deck) and have replaced the primary mower belt twice this summer. It just broke again. Initially I thought the ''cheap'' replacement belts from Rural King were the problem. The Rural King Kevlar belts seem to disintegrate (crack and come apart in multiple places), so I decided to buy the OEM belt (174368) thinking it may be better as they are twice as expensive. Since it cost over $40, I decided to do a quick test before mowing the complete yard, which is 2 acres. After about 5 mins of operation, I was shocked to find the primary mower belt was extremely HOT to touch, so something else is going on. I then removed the deck, and also the secondary belt. I double-checked the 3 mandrels/blades and they seem to move smoothly (btw, the secondary belt is the original as well as the main drive belt). The flat and V-shaped idler pulleys also spun easily. I'm thinking the only thing left that is contacting the primary belt is the electric clutch, and maybe it's slipping ever so slightly when engaged/under load causing the excessive heat build up. Just another tidbit, a momentary loud squeal was heard whenever the electric clutch was activated for the past few summers, but I don't recall hearing it recently when the clutch was engaged. How do I check the electric clutch and is there a way to adjust it to make sure it's not slipping under load (with the engine off I can grab the pulley and rotate it although there is quite a bit of stiff resistance).
Thanks!
  • 3 Answers
Have you check the tensioners? The idler pulleys that are on the arms with springs on them. My reasoning is, if the arms are rusted, or stuck for some reason and not moving freely then the springs can't pull the belt tight. If that's the case, I could see where the belt could be slipping more than it needs to and prematurely wearing out. Just something to check. Good luck.
Posted on Aug 24, 2010
Primary belt rubs on bracket n keeps shredding/// new replace ment deck...just purchesed
Look under the the left foot rest,there is a belt installation diagram. It will show how to install the belt correctly. It is real simple to replace belt,but the belt must be installed on the pulleys,correctly or it will fail,every time. Sincerely,Brad Locke
Jul 27, 2015 | Craftsman Garden
Dont know wheter to get primary mower belt or secondary mower belt for craftsman gt3000 48 inch deck mower...?
primary belt goes from the engine to the deck the secondary goes on the deck and connects the blades together
Aug 24, 2012 | Craftsman 48" Cut Riding Lawn Mower Deck...
This is the primary belt-not the secondary.
take the deck off , some of these tractors can be hard to work on , but if you have the mower deck off. you have a 100% better chance of self repair
Oct 21, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
PRIMARY BELT SIZE
I WOULD SUGGEST HIGHLY YOU GET REPLACEMENT BELTS FROM SEARS . THE AUTOMOTIVE BELTS ARE IN ONE INCH INCROMENTS SEARS BELTS ARE IN HALF INCH .. GET YOUR MODEL NUMBER AND CONTACT YOUR LOCAL SEARS OR K MART . FOR THE PROPER BELT ! .. JUST THE WAY IT IS WITH CRAFTSMAN MOWERS ... SORRY ....
The belt that comes from the engine to mower deck keeps breaking. I've owned the mower for years and I have to buy atleast 12 belts per year. The problen is really bad now. A belt per cutting. I've...
I own a Craftsman rider, DTY 4000, 25 HP Kohler, 48" cut, 137 Hrs. It eats a belt about every mowing or two. Did all the stuff you did. Good luck from Sears. Had cousin who is owns a lawn & garden repair business look at it today. Says the prob. is this - The drive belt pulley (elec clutch) has too a narrow "V" and the angle of wear between it and the deck when the deck is in the lowered (mowing) position is too severe. If you notice with the deck in the fully raised position the pulleys line up perfectly. Then drop your deck and see how tightly bent the belt is downward and it makes sense as to why(my) belt would first roll over then break in a few minutes. The elec clutch pulley is sold as one unit PT No. 179334 $250.00, but I'm sure it would come with the same narrow V pulley. Waiting for word from my cousin. My last Sears Mower. Cannot even sell it in good faith.
Aug 07, 2010 | Craftsman 48" Cut Riding Lawn Mower Deck...
NO FORWARD NO REVERSE
I had the same problem so I looked under the mower and the belt that goes from the engine to the back of the mower was off so I pushed the clutch as far forward as I could and the belt went on it and it worked
May 29, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Belt Diagram needed on Craftsman Kohler Command 20 Hp RidingMower
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter your model #, click enter, then scroll down to the sudcomponent list and click on 'Mower Deck' if it's your blade belt you need to see or 'Ground Drive' for your transmission belt. Hope that helps. Dwain
May 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Shear pin keeps breaking on15.5hp kohler engine.
Did you ever solve your problem? I am having a very similar issue with my lawn tracotr.
Mar 10, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
521 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
