Whirlpool Duet HT Front Load Washer Model # GHW9250MW1 Washer will not start at all. There is nothing on the display screen, its completely blank. The only button working on the control panel is the END OF CYCLE SIGNAL button which activates the CONTROL LOCKED/UNLOCK feature. I have checked the belt, inlet valve screens, trap at the discharge pump, power outlet, water supply and all are okay. There is no corrosion on any connectors. I replaced the door lock module last year. I have re-installed the back, front and top panels. Any suggestions on where to look next?
  • peterfj Aug 06, 2010
    I just installed a new CCU (motherboard), then plugged the cord into the outlet, and heard the "click" from the CCU indicating that it works. Included with the new CCU was an instruction sheet directing me to press the Pause/Cancel button twice, in order to avoid the washer from starting in the pump cycle. When I did this, the display went dead, just as it was before. Removing and replacing the plug from the outlet does nothing, nor does pressing and holding the END OF CYCLE SIGNAL button. Have I just blown the new motherboard, and the $400 I just paid for it? What can I do now?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To resolve this issue press and hold the END OF CYCLE button for 10-15 seconds so that the controls reset itself. After this if still the issue is not resolved then you'll have to replace the control panel as everything else appears to be working fine. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 29, 2010
  • 2 more comments
  • peterfj Jul 29, 2010
    Thanks. Just tried what you suggested, but no response from that either. Is there a fuse on either one of the circuit boards, or elsewhere in the machine, that could be blown?
  • Rylee Smith
    Rylee Smith Jul 29, 2010
    Unfortunately it does not have any fuse, if you have already tried the reset procedure after unplugging and replugging the unit after 10 minutes then you'll have to replace the control board. However, prior to replacing the board when you open the screws try to blow air with the help of hair dryer so that if there is any moisture in it then the issue is solved.
    What is the trick to removing the control knob.... do I pry it off from the front or remove the small circuit board from the back?
  • Rylee Smith
    Thanks for your reply, please check this repair manual for your Whirlpool Duet. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
My whirlpool duet sport front load (HT) washer is not working.
it sounds since this machine was named "duel sports" that is going to play with your heads some crazy games but nothing to worry about its going to grow up eventually,meanwhile just sit back amd injoy the game after all why did you adapt a "player"
Jun 12, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet ht will not agitate or spin
Front load washers don't "agitate". Did you mean it doesn't tumble during the wash cycle? I need more information. Complete model # and a more detailed description of the issue.
Mar 16, 2014 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
My Whirlpool GHW9250MW1 knocks very bad especially on the final spin cycle. Do I just need to get a new washer?
Before junking your washer, remove the rear panel and be sure the large pulley is tight. If it is, the spinner support is likely broken on the tub assembly. That repair is major and very expensive. Check the pulley with fingers crossed....
Kelly
Mar 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My duet ht front loading whirlpool washer goes through a complete cycle then during the spin and drain ( the last cycle) it displays a f6 notice and will not complete the cycle, you cant get the wet...
Hi
Thanks for using FixYa. Error F06 in your washer indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: My whirlpool duet ht washer shows an L20 error mes...
L20 is not a valid error code.
Unplug for 40 minutes and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT Front Load Washer- won't start
remove the plug of the machine from the power outlet and plug it after 10minutes and then check .
if the frontpannel screen shows any error codes or any lights flashing check out this link
http://www.applianceaid.com/frigidaire_frontload_washer5.html
also check out this link for more help
http://www.applianceaid.com/frigidaire_frontload_washer.html
thanks.
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
