Question about Dishwashers
Whirlpool adp6000ix keeps coming up with a err 3 code is it hard to change the sensor or element?
4 Suggested Answers
SOURCE: WHIRLPOOL DISHWASHER, ERROR CODE 4,
I have the solution! Had error 4 and had the repair guy come....he said its caused by too many suds...if you are using tablets that have rinse aid as well as rinse aid, it causes to many bubbles, these get sucked down the two little outlets (located at the bottom of the dishwasher door, easy to see if you open the door completly) and make the water level in the base seem higher than it actually is which triggers the over flow button. Now to fix it is SUPER hard....NOT! Just pull out your dishwasher, and tip it back slightly. The water stuck in the base will trickle out...not much but will take 5-10 mins. Then turn it on, run on a rinse cycle to be sure its all gone! Easy Peesy. I called whirpool about this, and why they could not tell me how to fix it is beyond me......they told me to press and hold the start button...i dont think even they know how to fix it! So...I got to do this under warranty, now hopefully you get to fix it for free and we all win. Yay!
Posted on Oct 08, 2009
jfarrell531
Well done Kazbarr worked a treat I am still waiting for Whirlpool to get back to me with an answer!!!
Posted on Mar 03, 2010
SOURCE: my dishwasher is coming up
I just had the same thing, same model. After cleaning the filter out, the problem remained. I then read on another forum that it helps if you tilt the machine backwards for a few minutes (which involved pulling it out of the cavity in the kitchen). Did this and it now seems to be working. Hope this helps you.
Posted on Aug 13, 2010
Im getting error PF when trying to start my whirlpool carbio. Also getting error code f25 what does this mean?
There is or should be a booklet on the inside of the machine between the tub and on the front panel. Tells you what the err codes mean. First thing to check on these machines is the drive belt pulley located on the bottom of the machine. I went through a lot of headache and confusion trying to run diagnostic modes and watching how to videos to get my machine to start going through the cycles until the end. The lid lock keeps coming on and off so you think it's that and try fixing it to no avail. And on and on trying to find the err code in diagnostic. I finally gave up and when I was loading it on to the truck to take it to the scrap yard I notice the drive belt has come off and cut completely through the guard. Causes problems the err codes don't catch. The belt pulley comes loose causing this. Start there. Trust me on this one.
Jan 01, 2017 | Whirlpool Washing Machines
Whirlpool dishwasher ADP6000IX error3
see page 6 on this user manual for description of error 3.
Sep 21, 2012 | Whirlpool Dishwashers
Whirlpool adp6000ix not cleaning properly
I would suggest getting a de calcifying agent and putting the washer through several cycles. Sounds like the dump valve may be getting plugged up.
Sep 06, 2012 | Whirlpool Dishwashers
Can or how do you test an oxygen sensor 2000 Hyundai Accent to find out if it is working properly? I keep getting error code P123. I have changed the oxygen sensor, but still keep getting the same err
There are two oxygen sensors. Change the other one. Make sure you are installing the correct sensor in the correct location. One is before the cat the other is after the cat. (upstream and downstream)
Apr 23, 2012 | 2000 Hyundai Accent
ADP6000WH/ADP6000IX--Whirlpool Dishwasher.(new) My problem--Water not getting hot--i have it connected to the cold water--should it heat the water ?
9d561c5b-7c7e-4515-8a01-fbfa8f762c34.jpgerror 3 not heating..on wix6000 /or / ADP6000WH
same boards .
rip out the the main mother board with all the black boxes ,and the transformer on it,,there is 1 black box its the biggest of them all ,next to the fuse with the blue cover on it ,with care take the black cover off with a screw driver carefully, not to damage the lower half of the internals,the lower section must not be damaged all ,once the cover is off you will see a copper coil on one side and on the other a set of breaker points ,at the end of the points ,get a screw driver and push in the outter point inward just a fraction,and bingo it will work again,of coarse its a temp solution,you will need to get a new breaker box from tandy or dick smith or simlar place to keep it going long term ..
hope this helps guys and gals ,please take extream caution when working on such dangerous power sourses ,and always make sure the power cord is removed before and repairs or tweeks..
cheers
Sep 30, 2010 | Whirlpool Dishwashers
Hello - I have a Compool 3600 system and recently I started getting an ERR 1 message on my control center. After doing some research, I ordered a replacement temperature sensor (TS5L with red and green...
With the information that you gave above I come up with this.
1. You got an error 1 message which indicates a bad WATER TEMPERATURE sensor.
2. You installed the sensor and you got the same message
3. To test it you removed the sensor and got an error 3 instead.
This is what identifies the problem.
The sensor that you swapped must have been the FREEZE TEMPERATURE sensor and not the WATER TEMPERATURE sensor.
The error 3 code only comes on when the FREEZE sensor is diabled or disconnected.
Solution: Trace the TEMPERATURE sensor and replace this sensor. The original freeze sensor is probably still good if you still have it.
Check out this manual and refer to page 38 "problem solving"
http://www.pentairpool.com/pdfs/cp3600OM.pdf
Refer to page 18 for the low voltage wiring diagram to find and trace the water sensor
Sep 22, 2010 | Pentair Pool & Spa
F05 error code comes on
Water Temperature Sensor Error - Check the Water Temperature Sensor,Heating Element and Element Relay.
If during the water heating step in wash cycle,the water temperature sensor(NTC) value is out of range,or the heating element circuit has failed,the F05 error code will be displayed - Check connections to
the Sensor,Heating Element and Relay.
Apr 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F5 error code
when F5 comes up on the Duets it means "water temperature Sensor Error". what you need to check is the sensor, (which you have indicated has been changed), the heating element and the element relay. check all the connections to the Sensor, element and the relay first. hope this helps.
Nov 07, 2009 | Whirlpool Washing Machines
WHIRLPOOL DISHWASHER ADP6000IX
your not alone. i to have this error 4 and so do hundreds of others.it means low water level even like mine your water level probably isnt low.what happened to mine was the sensor got a layer of fat and oil scum buildup on it and couldnt detect the water level so i cleaned it and worked good for another month. then same problem.solution- dishwasher had an "accidental short due to water leak" wich insurance covered and bought me a new dishwasher (fisher and pikel) now no more problem
Jul 30, 2008 | Dishwashers
Kitchenaid glass top electric range
I have the same problem...stuck key err F2E0
Can any one please tell me where is the sensor? I mean which part of the oven have sensor, is it inside or under the button control panel?
May 27, 2007 | KitchenAid KESC307 Electric Kitchen Range
Dishwashers Logo
283 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
