Question about Raymarine Boating
Raymarine ST60+ Wind, *Raytheon ST60 Depth, Raymarine ST4000+ Auto Pilot connected in series (seatalk). When initially switched on, the Auto Pilot first displays "4000 WHL", then "STANDBY", & then "STLK FAIL" in rapid succession. At this point nothing works on the Auto Pilot. When the yellow Data wire from the STs is connected to the Raymarine C120 Display, the Raymarine GPS stops sending information to the display. An additional 12v supply was added to accomodate the STs. What does "STLK FAIL" refer to? I could not find it in my Owner's Handbook. How do I make the ST4000+ work and connect all the STs & the GPS antenna to the C120 Display? Currently my charts, GPS data & Radar are all I can get to send to the C120 Display.
2 Suggested Answers
  • 5 Answers
SOURCE: Raymarine C120
You need to download the latest software version from raymarine.com which turns on nmea2k.
Posted on Jul 24, 2008
St4000 auto pilot makes 180 degree turn for no good reasonn
It has been a while since I set up my auto pilot, but Raymarine has a very good set of on-line manuals and it would be a good idea to go through the setup procedure again. There is a sensitivity setting that adjusts the responsiveness of the AP in relation to changes in the helm. If it is set too sensitive, the AP will make big changes when the helm slightly moves.
Jan 09, 2014 | Raymarine Boating
St60 Wind Vane Ducer E22078: Where is the best place to get a replacement paddl...
Go on www.raymarine.com and search for a dealer in your area and they will be able to help you. The wind service kit sells for less than $30.
May 17, 2010 | Raymarine St60 Wind Vane Ducer E22078
The self-closing valve on our 13 year old ST60 speed transducer now only closes sometimes when the blank or impellor sensor is removed. We suspect that a spring is missing. We need a raymarine spare part...
Spring not available must buy housing and replace or if it is sleeved, buy housing and slide in new sleeve there are two different types, one has a removable sleeve with flapper
A long shot would be Raymarine tech support 800-539-5539
I can sell you the part 847-746-0100 technicalmarine.com
Feb 20, 2010 | Raymarine St60 Plus Package, Includes...
S1 pilot, on install burnt out seatalk circuit
You are still OK, if it smoked out of box, call Raymarine and yell and they should send you a replacement course computer. Also, there are two SeaTalk circuits, so maybe one still works? I have a replacement brain in stock if you like. 847-746-0100.
Jan 23, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
My Raymarine ST6001+ says no signal. All other instuments are getting good GPS signal. I have have changed compass but nothing changed. I have a Course Computer 400 as the main autopilot controller. Can...
if the ST 6001 shows "no data" and alarms, the course computer is most likely bad. Control head failure is very uncommon, hower you should look at the brain box (T400) and move the control head to the other seatalk terminal (there are two) you may have just one failed SeaTalk port and can use it as is, otherwise, Raymarine will still fix (this week) 847-746-0100
Jul 11, 2009 | Raymarine St60 Plus Package, Includes...
Raymarine ST6002 Smartpilot Alarm Message ''Seatalk Fail 2''
Very possible that the Wind instrument has a defective Seatalk interface - it happened to me. You could try your Wind in another boat, just connecting it temporarily to the Seatalk Bus - if it jams those it is the problem
Your autopilot should have a separate Course Computer such as the 100, 400, S1... somewhere. Some models have two SeaTalk busses, and the recommended installation is to use one bus for the 6002 control head alone, and the other bus for instruments etc, so a SeaTalk fail on the instrument bus will not disable he Autopilot. I retired my boat this way (after the dealer took the one-bus shortcut).
The real solution is to have the Wind instrument fixed. The cheapest work-around is to cut the yellow SeaTalk wire between the 6002 and the Wind, so that the Wind instrument gets power but does not affect the data bus. That should let the AP and Wind each work normally and independently (no Wind-angle mode on the AP).
Raymarine have a forum you should join for more info and help.
Sep 05, 2017 | Raymarine Boating
Wiring of seatalk instruments
OK, you are confused. Seatalk is a bus system, using 3 wires , (power +, power-, and Data.) red, bare and yellow repectively. So Red and Bare are 12V and ground. Since the 125 shows a green light, it is getting power and outputting data. but is it seatalk?? to make a 125 Seatalk, you must hook red and green together to 12 V, so check that first. if green is grounded or not connected, that is the problem (or one of them)
Next divide system to its' simplest terms, so hook the GPS straight to the display ST60, and see if it works red to rd, yell to yell and bare to bare (sometimes black) One by one hook the others into the chain until they all work or failed device takes down Seatalk network. If you are missing 12V on a seatalk leg, check 5A fuse in course computer. If you have a pilot, you have a course computer, unless it is ST4000 wheel pilot, and then the brain is the display (course computer is built in to ST4000 display)
Sep 01, 2008 | Raymarine RL70CRC GPS Receiver
Sea talk failure
Remove all wiring from 4000 head, hook up only 12V, if seatalk fail continues, it is the head. if seatalk fail goes away, hook in instruments one by one until the bad head is found. Seatalk is 12V red, Ground Screen(bare wire) and Data yellow (pulsing voltage). good luck 847-746-0100 John Barry
Jul 14, 2008 | Raymarine A65 Combo GPS...
Raymarine Raychart 520 Interface to PC
you will need to hook up direct. Seatalk wont handle a waypoint download, but the chartplotter will accept the data directly into the NMEA in port. All other data, like wind depth and latlon are handled by seatalk
Mar 27, 2008 | Raymarine Raychart 520 Plus GPS Receiver
Boating Logo
218 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
David Burbee
David Burbee
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
