Question about KVH TracVision A7 Satellite Car Video TV Antenna GPS Receiver
Trying to hook up a satellite dish (Dish Network 500) in a motorhome. Have feed from sat antenna plugged to SAT 1 on back of receiver. Also cable from ''Distribution'' port on receiver feeding the SAT IN panel on the motorhomes control panel which selects whether I am using SAT, CABLE, ANTENNA, DVD, etc. Question is, what do I set me TV to? Satellite appears to be searching but I don't get an image on my tv.
  • 6,674 Answers
Try channel 3 usually on TV, or 4
Posted on Aug 01, 2010
I disconnected power from the tv to install carpet & im not sure if iam hooking it back up correctly
danny_burse
I am assuming when you say you disconnected power from the TV to install carpet, you disconnected the cables from the receiver to your TV. Depending upon your installation, you have a cable that comes from the dish located outside that is connected to a splitter and has 2 cables coming off the splitter. The 2 cables will connect to SAT 1 and SAT 2 on the back of the receiver. Your TV 2 connection either goes directly to your TV 2 or goes to a second separator, connected to the UHF/VHF connector. If you still have problems with the connections, please email me at ray.calo@dishnetwork.com and I will assist you further.
Ray Calo
DISH Network
Apr 21, 2011 | DISH Network 322 DTV Receiver
I have a 322 dish receiver there is just too ports to hook to and i have ant.+ cable and sat. to hook to it anyhelp would be welcome. thanks
Heychuck68102, my name is Mike Houston of DISH Network and I was going over yourpost and I see where you want to connect a cable wire plus you're satellite. Ifyou have a TV that will allow for a RCA connection you can run the RCA cable tothe top red, white and yellow inputs and run the antenna directly to theTV/Antenna IN. Then you will be able to connect the cable to the TV CH ¾ input.I will send a link to help with these steps, http://www.dishnetwork.com/SupportSection/how-to-set-up.
Apr 16, 2011 | DISH Network 322 DTV Receiver
Sat finder detects signal on 61.5 Sat but receiver does not display or lock.
Hi, Mary with Dish Network Customer Service. The 61.5 Satellite carries mostly High Definition programming. If your Satellite Dish is an older model, it is not equipped to bring that Satellite in. It is the part on the Dish called the LNBF (the eyes) that will pick up the satellites. Your receiver is a Standard Definition, you should be reading the 119 & 100 Satellites. I hope this helped but if you have additional questions, please let me know.
Dec 22, 2010 | DISH Network 311 DTV Receiver
My daughter sat on the dish network remote and now there is no sound. All other devices hooked to the audio receiver work (DVD and Radio Tuner), but not the satellite. Any thoughts?
dbuerck
I would check to see if the "Mute" button was accidently pressed when your daughter sat on the remote. If not, unplug the receiver from your electrical outlet for 10 seconds and plug back in. This will cause the receiver to reboot and re-acquire the satellite signal. After the picture returns, see if you are getting audio. I hope this helps.
Ray Calo
DISH Network
Oct 24, 2010 | DISH Network IR Remote Control
After programming my NEW Harmony One Logitech remote I can't get it to change channels on the Dish HDTV DVR along with a bunch of other problems.
To control a Dish Network PVR/Satellite, it needs to be set to respond to the default Remote Address (1).
To reset your Dish Network PVR/Satellite to the default Remote Address:
1. Press SYSTEM INFO on the receiver's front panel. The System Information screen displays on the nearby TV and shows the Remote Address.
2. Using the original Dish Network remote, press and hold SAT on your remote control for about three seconds, until all of the mode buttons light up, and then release SAT.
3. Using the NUMBER PAD, press the 1 button
4. Press POUND (#). If you entered the address correctly, SAT will flash three times.
5. Press RECORD. Make sure the Remote Address you see on the System Information screen is 1.
6. Press the SELECT button on the front panel to close the System Information screen.
7. Your Harmony remote should now control your Dish Network PVR/Satellite box
NOTE: Dish Network PVR/Satellite receivers sometimes have two tuners, allowing them to be used in more than one room on different TVs. Harmony remotes can only control a Dish Network receiver's main tuner while still in the same room with direct line of sight to the device.
What other issues are you having with the remote?
Dec 25, 2009 | Logitech Harmony One Advanced Universal...
Does the dish network 322 receiver require two lines from the satellite to the receiver?
It does require 2 lines form dish unless you have a switch installed such as a dp34 or you have Dish Pro plus LNB"S on your dish and you can use 1 feed to the reciver and use a separator to separate the signal into sat 1 and sat 2 (note: a standard splitter is NOT a separator) a separator is dish brand equipment.
Oct 15, 2009 | DISH Network 322 DTV Receiver
HDTV Converter hookup with sat. and antenna
Hi there Phil...... this switch from analog to digital has lots of folks scratching their heads. Fortunately I have some great news for you. The signal coming from the Dish network does not need a converter as it is already digital.
May 29, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Sat signal reaches only 1 cable outlet
you need to split the line at the receiver box. The signal from the Dish needs 18vdc to the receiver or you'll get NADA.. If I understand you correctly???
Mar 07, 2009 | RCA DISH Network(r) 311 Satellite System
Hi. I need help finding 119!
I looks like you are picking 110W with the LNB on your left if you are facing the dish.
Try to get 119W first if you connect the cable to the 119 LNB, once you find 119W that way, you will also have 110W.
Good Luck.
Feb 24, 2008 | RCA DISH Network(r) 311 Satellite System
Dish Network - Dish 500 Satellite 110 is not being recognized
Lonnie, You have a simple problem,the 119 satellite is lower in the sky than the 119 if you make sure the pole you are mounted on is straight and plum ,then simply raise the dish a few elevation degrees and turn the dish to the left.Your dish is aimed low and to the right.
Oct 18, 2007 | RCA DISH Network(r) 311 Satellite System
KVH TracVision A7 Satellite Car Video TV Antenna GPS Receiver Logo
410 people viewed this question
Top KVH GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a KVH GPS Expert? Answer questions, earn points and help others
