Question about Kenmore Oasis HE 27062 Top Load Washer
My washer is showing the "ld" code ,how do i fix it?
  • 171 Answers
LD stands for long drain.  unit has decided it is taking too ling to drain the water out.  check the drain hose for any obstructions.  if you feel capable, you can also take off the water pump and do the same.  may also be a bad water pump.
Posted on Jul 29, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
How do i clear code sc322 on nashua aficio 2016
Code SC322: Laser synchronization error
The main scan synchronization detector board cannot detect the laser synchronization signal for more than 5 consecutive 100 ms intervals.
Causes:
• Poor connection between the LD unit and the BICU board
• Damaged cable between BICU and LD unit
• LD unit out of position
• LD unit defective
• BICU board defective
Error Codes Ricoh Aficio 2016
Jan 04, 2015 | Office Equipment & Supplies
Cabrio washer code Ld
Top load washer Ld is a long drain the drain pump is connected to the tub remove the water pull the basket there in a round cap covering the drain port removed screw and cap look for and obstruction go to youtube video will show you how to remove basket
Aug 31, 2014 | Whirlpool WTW6200S Top Load Washer
My washer shows an "ld" code after stopping in the
I have looked and looked and can't find an error code "ID" for any Maytag washing machine! Are you sure that is what is being displayed.
Jun 05, 2011 | Maytag Washing Machines
My washer is showing :LD"
Sounds like the strainer/filter is partially blocked causing Long Drain, remove the access panel and unscrew filter cap to clean, hopefully nothing is jammed in the pump.Hope this helps
Jan 20, 2011 | Washing Machines
The code LD is showing
ld it a long drain check drain pump
Aug 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
THE CODE LD IS SHOWING UP AND WASHER IS NOT OPERATING
Press stop, cancel twice to reset. The Ld error is when it takes longer than 5 minutes for the washer to drain and reset the sensor. You probably have a partially plugged strainer or drain line. To check the strainer, remove the kick panel at the front bottom of the machine. The strainer is ibetween the drum and the pump, being connected to the drum with a rubber hose. Open the strainer (caution, water!), and clean. If you did not find much in the strainer, clean the drain hose. Dump the contents of the drain hose into a bucket. If possible, run an empty losd with dth drain line pointed outside.
This should fix your issue!
Best regards, --W/D-- feel free to rate this solution...thanx!
Clothes washer won't drain - digital display shows LD
looking at the tech sheet for this, it appears to be a standard whirlpool top load but with electronic controls, correct? normalling with this type a lid switch is the issue but the electronics would have a different code for this, LD is Long Drain for this model. suspect a transmission but this should help you troubleshoot. go to www.servicematters.com and click technical reference - tech library - tech sheets, enter model minus 110.prefix. this will show tech sheet with diagnostics. this book can also be found inside your console.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
Ld and ob codes
LD code means your pump is cloged with lint or small piece of clothing such as a sock. I had the same code on my washer and sure enough i found my pump cloged with lint from a blanket my wife washed. hope this helps. sorry I cant help on the other code.
Jan 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Open Questions:
See all Kenmore Oasis HE 27062 Top Load Washer Questions
Kenmore Oasis HE 27062 Top Load Washer Logo
55 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
