Question about Echo Rapid Loader, Trimmer Head
Vibration on a Echo edger
Shoot!
Ever since I lent my edger to my uncle, the puppy's been vibrating. Any ideas?
2 Suggested Answers
plink_plonk
  • 1807 Answers
SOURCE: Excessive Vibration in Echo PAS-230 edger accessory
Sounds like the Edger blade is unbalanced/off centre/unevenly worn or loose.
Posted on Jul 27, 2013
I have an Echo PE-2400 edger. It runs fine but vibrates like crazy at full throttle. It does this without even having a load on it. Can someone please tell me why it does this?
Something is out of balance. If it is an edger with metal blades replace the blades. If it uses 2 strings install new trimmer line winding equal amounts on both spools.
Aug 30, 2013 | Echo Garden
Jul 27, 2013 | Echo Garden
My MYD edger breaks off the adjustment rod any fixes
I've broken two of them. I had a lot of vibration, and the blade was bent. I'm replacing the rod and the blade to hopefully fix the problem. If it breaks again, and I still have the vibration, I'll look at replacing the belt and possibly the pulleys.
Feb 10, 2013 | Mtd Garden
Vibration at highway speeds when echo light is on, 2011 Honda Accord?
is the vibration in the steering wheel (front wheels need balancing) or through the seat/floor? (rear wheels need balancing).
if the vibration is speed specific the abovewill be true, if you are sure its connected to the eco light then this is becuase the car is not firing all cylinders to save fuel. I would get it tuned at a dealer if the vibration is really that noticable
Jan 06, 2013 | 2011 Honda Accord 3.5
2005 toyota echo two days before i wash engine. then engine working not smoothly some vibration and not going smoothly what can i do?
Sounds like you got the ignition system wet. Remove the coils, and dry out the spark plug wells. It would be a good idea to apply dielectrig grease sparingly to the inside of the plug boots.
Sep 24, 2011 | 2005 Toyota ECHO
Toyota Echo A/C Vibration
change the a/c compressor's bearing or service the compressor.
Jun 30, 2009 | 2001 Toyota Echo
Vibration that I hear and feel in shaft after trimmer warms up
Sounds like the drive shaft may be broken or weak in one spot. When it heats up, the metal becomes softer, causing the vibration. Have you had the drive shaft off recently?
Jim
Jun 14, 2009 | Husqvarna Garden
Electric lawnmower
Need to check blade and replace.Blade is out of balance causeing vibration. If you continue to use cener shaft bearing will also wear out and cause vibration. Buy new blade and if vibration is still there return blade.Mower is not worth bearing replacement. Buy new mower.
Please take time to rate .Thanks
Mar 28, 2009 | Electric Garden
Echo Rapid Loader, Trimmer Head Logo
117 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
