Question about Vacuums
How do you get cover off dyson dco7 to replace electrical cord?...I can get the torx screw out, but the cover seems awfully tight and I don't want to break the cover
I would use a toilet plunger.
Posted on Aug 28, 2008
How to replace the cord in dyson's dc07
Things You Will Need
  • Dyson DC07 power cord
  • T15 Torx-bit screwdriver
  • Small can
  • Camera or cell phone with camera
  • Flat-head screwdriver, 3/4-inch or smaller
  • Needle-nose pliers
Tips
  • Do detach the black wire that goes to the motor as it does not require removal.
Warnings
  • Do not work on the power cord when it is plugged in.
  • Do not force the plastic-covered connectors from the switch or you could break the male ends. Pull them off firmly but gently to avoid breaking the terminals.
  • Do not apply too much force to the plastic arms that hold the housing in place. The plastic arms are fragile and may break easily.
References
1 - Unwrap the power cord from the Dyson DC07. Detach the handle of the vacuum cleaner by pressing the release button. Pull the handle from the hose. Slide the hose down the wand and push the button at the bottom to release the hose from the machine.
2 - Press the button at the top of the dust bin handle to remove the canister bin assembly from the Dyson DC07.
3 - Lay the machine on with its back with the power switch facing upward. Locate the Torx screw directly beneath the switch actuator. Remove the Torx screw, turning it counterclockwise. Place the screw into a small can so you do not lose it.
4 - Remove the switch box housing held in place by the Torx screw just removed. Carefully pry upward on the two plastic arms that clip the housing in place. Take a picture with your cellphone or camera of the open housing to make it easier to reinstall the wires where they belong in the channels and spaces provided.
5 - Center the needle-nose pliers on the female connectors from the power cord attached to the switch. Apply equal force to pull them from the male ends of the switch. Also detach the two wires that connect together within the housing, identified by the clear plastic connector between them. Depending on your machine\'s manufacture date, the wires might have different colors. For example, they may be white and brown, all white or one could be blue. Disconnect a total of four wires -- two from the switch and the two connected together. Leave the other wires alone.
6 - Trace the electrical cord on the machine until you reach its protective cover where it enters the Dyson DC07. Lift up the cord protector to remove it from the vacuum. The cord protector has slotted sides that fit within the plastic. Slide the cord protector from the power cord.
7 - Remove the plastic covers that protect the female ends on the power-cord wires that connect to the switch. The new power cord does not come with these. Insert the tip of the flat-head screwdriver through the top of the plastic connector with two internal ridges. Lift upward and away to pull the wire free from the connector. Repeat for the other wire. Push the female end into the plastic connector until it snaps into place. Repeat for the other power-cord wire.
8 - Thread the new power cord through the cord protector. If you have trouble pushing the wires through, reach in with the needle-nose pliers to pull both wires through the rubber protector.
9 - Reconnect the two separated wires back together by inserting the male end into the female end of the other wire. Reconnect the two wires from the power cord to the switch. Reinstall the switch housing on the machine. Align the wires in the channels provided to keep them from being pinched or pulled out when you reassemble the housing. Look at the photo you took earlier as a guide, if necessary. Insert the wire that goes to the motor in this channel and the white wires connected together to the left of the switch in the area provided.
10 - Put on the switch housing cover and secure it with the screw you removed earlier. Reassemble the vacuum in the reverse order you dismantled it.
Aug 27, 2014 | Dyson DC-O7 Bagless Upright Cyclonic...
How do you remove dyson dc04 absolute start switch
The switch is in a cover held on by screws and tabs. Remove the hose and wand to gain access to the screws and tabs. After removing the screws, push on the tabs to release them and the cover will come off the front of the machine. Be very careful removing parts so you will know how to put them back together.
Jul 10, 2014 | Dyson DCO7 Animal Bagless Upright Cyclonic...
Dco7
you need to lie the dyson out on the floor/table and you will see some screws underneath holding the rotating brush in place, remove these with a torx bit and you will see how it lifts up to allow the belt to be replaced, just keep track of how things sit to make it easier to put back together
Mar 02, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Dyson DC 25 power switch replacement
It a fairly straightforward procedure. Remove the accessory hose to expose 4 torx screws from behind that hold the front switch cover in place. After removing the screws, gently pull the front switch cover and carefully pry two plastic tabs apart using a small screwdriver that "snap" cover in place. The switches will be exposed. The electrical connectors each have a tiny lock button at the base of the terminal that you need to push to remove. Otherwise they won't pull off easily. Assembly is reverse with one note: You'll have to hold the plastic cover and push buttons together so they don't fall out as you place the the cover back on. Once you get it on, the plastic tabs will hold until you install the torx screws. Be sure to retest the push buttons to make sure there was no binding in reassembly.
If I may add one more thing- I believe all DC25's carry a 5 year warranty and switch failure is covered. I replace these routinely. If you call Dyson, they will likely refer you to an authorized repair center for replacement at no charge.
Regards
Feb 16, 2012 | Vacuums
How do I take about my Dyson DC11 to replace the retractable power cord assembly
While it doesn't require a collection bag, a Dyson-brand vacuum cleaner can still suffer the problems of wear and tear that are prone to any vacuum cleaner--for example, a frayed power cord. If the power cord of your Dyson vacuum cleaner has become frayed, change it immediately to avoid a dangerous electrical mishap. You will need a replacement cord from an electronics service center, along with a few common household tools. You do not need electrical skills to complete the task.
Follow this steps on how to replaced the power cord assembly:
1 Unplug the Dyson vacuum cleaner's power plug from the wall outlet. Press the button on the top front of the plastic collection cover. Lift the cover off the front of the vacuum cleaner and place it aside.
  • 2 Trace the power cord to where it enters the back bottom of the vacuum cleaner. Remove the screws from the panel surrounding the power cord with a Phillips screwdriver. Remove the panel. Aim the beam of a flashlight inside the compartment so that you can see where the wires at the end of the power cord wrap around two screws on the motor assembly. Loosen these screws with a Phillips jeweler's screwdriver.
  • 3 Pull the power cord out of the compartment and dispose of it properly. Strip a 1/2 inch of insulation from the ends of the two wires of the replacement power cord. Run the wires into the compartment along the path of the original power cord--pushing the wires into the grooves inside the compartment.
  • 4 Tie a knot on the cord on the inside of the compartment to prevent the cord from being pulled out.
  • 5 Wrap the exposed end of each wire of the power cord around the loosened screws. Tighten the screws. Replace the panel and reattach the screws. Stand the vacuum cleaner right side up. Place the bottom of the plastic collection cover into the bottom front slot on the vacuum cleaner. Push the cover back on the front of the vacuum cleaner.
  • Jul 13, 2011 | Vacuums
    Dyson Animal vacuum plug and cord heat up while in use.
    if you have ANY electrical item where the plug and cord heat up during use, STOP USING IMMEDIATELY. this is something that should NEVER happen and is a fire risk.
    DO NOT plug it in again until it has been checked by a qualified electrician.
    i cannot stress the importance of this.
    this SHOULD NEVER HAPPEN and SHOULD NOT BE USED
    Mar 02, 2011 | Dyson DCO7 Animal Bagless Upright Cyclonic...
    My dyson dc07 filter catch has snapped off and it's stuck
    you need to take off the little vent that goes around the filter. this is hard. you take off the cover for the hepa filter (under the dustbin) there are three catches. you take off the two torx style screws under the vent and then you work the vent until it has come off. i still don't know how i did mine. then you can use a flat head screwdrive and hammer to put the latch in or out
    Nov 18, 2010 | Dyson DCO7 Upright Vacuum
    Dyson dco7 top cover how dose it come out dyson dco7cleaner upper motor cover purple
    Hi its Darran at Dyson.
    The post filter on your DC07 should never need to be replaced. If you think there may be a problem with this, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
    Kind regards
    Darran
    Dyson Customer Service
    Feb 20, 2010 | Dyson DC07 All Floors Bagless Upright...
    How do you remove the electrical cord for a dyson
    remove the cover right above the canister. there is a couple of screws in the front holding it in. i think they are T15 torx. that will give you access to your switches and your cord
    Jan 02, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
    Dyson DC04
    If it is at the on/off switch, you can carefully prise the yellow button out to reveal a torx headed screw. Remove the screw then the housing for the switch can be pulled out which should reveal your loose wire.
    Brian
    Nov 05, 2007 | Dyson DCO7 Animal Bagless Upright Cyclonic...
    Vacuums Logo
    56 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
