Question about Car Audio & Video
My car starts and tumbler it turns off andstarts again, they change my air flow meter have not try but i went home and start the engine i had to hit gas to make it run, will try tomorrow would this help the change they made me
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
SOUND LIKE THERE IS A VACUMN HOSE OFF OR BROKEN
SPRAY STARTING FLUID AROUND THE ENGINE WHEN THE ENGINE SPEED UP THE DIRECTION WHICH YOU SPRAYED IS WHERE TO LOOK FOR THE LEAK
Posted on Jul 30, 2010
Car loses power (engine still on) and engine splutters and shakes then turns off when idling
Probably the air flow meter probably dirty can of comprest air take it off spray it
Oct 29, 2017 | 2000 Renault 181
Suzuki wagon r+gl check engine light keeps flashing and wont start after battery change
the engine (there are more than one engine)
has a distributor.
"have spark at coil down to dizzy but no spark at plugs"
this can mean only 2 things.
1: spark wires are dead. all 4, kinda hard to believe huh?
2: the dizzy is way off time. so time the dizzy and now spark
lands on each wire term.
if not a dizzy engine, post exact version of engine and country.
Apr 14, 2013 | Suzuki SX4 Cars & Trucks
1985 toyota camry unplug mass air flow sensor engine will start plug back in engine dies
There is a switch in the airflow meter that keeps the fuel pump relay closed as long as there is airflow. With the meter unplugged, the pump should not run except when the key is turned to start. It would seem to me that you have a wiring issue. Try jumping the fuel pump relay so the pump runs whenever the key is on. (Remove the relay and jump the pump wire to the accessory wire--see top left diagram.) This defeats the safety feature but will keep the pump running.
Oct 30, 2017 | 1993 Toyota Camry V6
2005 hyundai xg350 problem starting
TRY DISCONNECTING MASS AIR FLOW METER WHEN IT DOES IT AGAIN IF CAR STARTS RIGHT AWAY THEN POSSIBLE MASS AIR FLOW ISSUE
Sep 12, 2012 | Hyundai XG350 Cars & Trucks
1984 BMW 733i engine idles rough then yesterday engine turns over but will not start , acts like its not getting fuel . Charged battery then tried again noticed backfire from air-flow meter (3)x , this is...
No, get a new fuel pump relay...it is the seven pin tall one under the plastic cover it cost about 30-120.00 $ get it from Autohausaz for cheap
Cheers
Sep 06, 2010 | 1984 BMW 7 Series
I have a 98 mercedes c230 it sometimes surges at idle if you hit the gas it clears up and loss of power i have replaced both oxygen senors,replaced the fuel pressure regulator and the manifold becaused it...
It's like faulty air flow meter, first start engine is the engine running rough disconnect electric socket from air flow meter is the engine running better than before replace air flow meter. if not need to be diagnose to find the fault code is this information helped you?
May 18, 2010 | 1998 Mercedes-Benz C-Class
Key tumbler loose. Starts car but wont turn off
most likely its the ignition cylnder (tumbler)
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Nov 13, 2009 | 1996 Ford Taurus
Car Audio & Video Logo
20 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
