Question about Sharp Actius RD10 Notebook
Sharp Actious RD10 notebook power supply pin out diagram
Anyone have a diagram or be able to tell me the pin out and voltage -watts etc?
    Problem Solver:
  • 28 Answers
You will get a better response if you pay for the expertise we have to offer!
Posted on Jun 24, 2008
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ...
    • 9 MIN
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • 3 MIN
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    How many amps a fuse in breville mixer
    Not knowing the model of the mixer you are talking about, or where you are in the world and the voltage you are running at, I can't tell you. But I can tell you how to figure it out. Simply do this:
    You obviously know what your main power supply voltage is, either 240 volt or 110 volt
    You can look at the mixer and there will be a data sticker with the wattage of the motor on it
    Watts divided by volts = Amps
    Therefore, if you have a 500 watt mixer on a 240 volt system 500/240 = 2.083 so use a 3 amp fuse
    a 750 watt motor on 240 volts 750/240 = 3.12 so use a 5 amp fuse
    a 500 watt motor on a 110 volt supply 500/110 = 4.5 so use a 5 amp fuse
    etc etc etc.....
    Hope this helps
    Jul 26, 2011 | Microwave Ovens
    How to find a battery for my Sharp Actius RD10
    The p/n is printed on the battery label. Just search that part on ebay or google, you'll probably get a lot of results. You could also send an email to sharp if you don't have the original battery to obtain the P/N
    Dec 30, 2010 | Sharp Actius RD10 Notebook
    I am replacing a motherboard with a G31-M7 TE and find that my existing power supply has a 20 pin plug consistant with the old motherboard but the new one has a 24 pin socket. Why is this and do I need to...
    New motherboards have a 24-pin power connector. Here is a diagram of both plugs:
    You can see that the two are almost identical. The extra 4 pins on the 24-pin connector provide extra connection points for a few voltages. Newer boards and processors need more current, and the extra pins were added to prevent overloading.
    Adapter cables are available to go from your 20-pin power supply plug to the 24-pin motherboard connector. Here's one from TigerDirect, and other vendors have them as well. If you're not making other changes than replacing the motherboard, you shouldn't need more than this adapter.
    If you are upgrading your processor along with the motherboard, you should probably replace the power supply too. Older power supplies are often in the 300-watt range, and this is too low for reliable operation with new processors, motherboards and video cards. A new 500 or 600-watt supply is not expensive, and would give you the 24-pin power connection the motherboard needs.
    Hope this has helped. Thanks for using Fixya!
    Nov 20, 2010 | Biostar G31-M7 TE Motherboard
    I don't have the manual for 277498-011
    As for the Power Supply 99% sure it is an ATX which as long as you get the same Watt as the existing you will be okay. Make sure you look at your existing connectors to see if you have a 24 pin or 20pin motherboard and 4 pin or 8 pin additional power plug (black and yellow wires) and the new power supply has matching connectors....older ATX supplies have only 20 pins, but there are converters from 20 to 24 pin available.
    Watch for the new power supplies and your drive connectors as some of the new power supplies have limited ATA plugs...if you have a lot of ATA devices you might need SATA power convertor plugs or ATA splitters to get all you ATA devices up.
    Sep 11, 2009 | Compaq ( 277498-001) Motherboard
    M2N MB LED is on, fan comes on for 2 seconds only
    It's a bad power supply. Couldn't be a bad Power On switch, because it turns on for 2 seconds.
    You have to have Ram to get the computer to function, besides the processor. All you will see is the BIOS Setup screen.
    Been using the same power supply?
    The power supply has bad Electrolytic Capacitors in it. These bad 'Caps' in turn make a weak voltage rail. You have three main voltage rails inside a computer power supply.
    The 3.3 volt rail, the 5 volt rail, and the 12 volt rail.
    With a weak voltage rail, the processor won't have enough power to run.
    ALL the lights, (Lamps), use less than 1 Watt.
    EACH fan uses 2 to 3 Watts.
    Processors use 55 watts to 125 Watts. Depends on the processor.
    Jul 25, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
    I misplaced the power supply for my visioneer 4400usb scanner. Can anyone tell me the voltage output to the scanner?
    Power supply
    Input voltage/frequency 100 Vac, 50/60 Hz (Japan)
    120 Vac, 60 Hz (North America)
    230 Vac, 50 Hz (Europe)
    Output voltage/watt 12 V DC, 15 watt maximum
    May 24, 2009 | Visioneer 4400 Flatbed Scanner
    Sharp Actius RD10 Notebook Logo
    246 people viewed this question
    Top Sharp Computers & Internet Experts
    Jason Harris
    Jason Harris
    Ricky Ostrom
    Ricky Ostrom
    Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
