Question about Refrigerators
Water in door runs when ice maker fills up and runs when finished filling glass replaced filter and filter housing / seat
  • Refrigerators Master
  • 3,083 Answers
The water level is sensed and turns off a valve, usually by a solenoid. Most likely the valve is worn. Here's how another FixYa tech answered the same question:
Solution #1 posted on Dec 21, 2009
water in door runs when - noavatar_s.gif jackfrost555
Rank: Guru Expert
Rating: 94%, 425 votes
Good day,
If the fill pipe that fills the ice maker is in it's proper position, then it is a defective water fill valve located in the bottom rear of the machine.
After harvesting the cubes the ice maker mechanism continues to rotate and turns the water valve on for 7 seconds. If it does not shut off smartly then it can cause the well to overfill, and flow water into the bucket.
Do not let this go. A small leak could turn into a major overflow, even overnight causing serious problems to the machine and as I have seen the entire house.
Good luck and hope this helps.
Posted on Jul 29, 2010
  • hotrodmarkd Jul 29, 2010
    thanks but maybe i said it wrong the problem is in the door not the ice maker . when the ice maker fills it leaks in the water in the door were you get water in the door and when you fill a glass it leaks and dont shut off all the way is it still the fill valve on the back bottom of the ref? thanks
2014 Kenmore side by side refrig. Water comes out of the door fine. Will not make ice.Tried the reset button on the left by the bucket, took top of door apart to see if mechanism was froze up.
Hello Rhonda Cornett,
Okay... water at the wall is connected... good...
but now you have TWO solenoids at the ENTRY POINT...
It would have been nice to know if there is water in the tray...
or if it EVER WORKED... but whatever.
If you are NOT getting water in the ICE TRAY...
you need to check that wire is connected to ITS OWN SOLENOID... (ELSE: solenoid might be bad)...
You might be able to TEMPORARILY REVERSE the water valves
to see if the door service still works with the SUSPECT VALVE..
Still works ... Ice maker trouble...
Fails solenoid trouble (bad valve) replace!
Then restore EVERYTHING... (take pictures ahead of tampering).
That click (or thump) you hear whenever you fill your water glass.
Every ice-maker I've ever tampered with has an on/off switch..
Fill controls... and firmness settings of some sort...
Check'em all out before getting DRASTIC.
Not the correct ICE MAKER PARTS
(illustrative purposes only)
appliance part houses (sears = pricy (IMLTHO)).
Water Filters Lawn Garden Appliance Parts
Jul 08, 2016 | Kenmore Refrigerators
How do I "Prime the Water Supply System" refereed to in use and care guide that came with my new Kenmore French Door Bottom Freezer, #253.70413411. Cannot find instructions in the manual only reference to...
Assuming you followed the water line installation directions and you have water available to your new refrigerator/freezer here is the rest of the "priming" info you requested. (basically it tells you how to run a bunch of water through the system by filling cups or glasses to remove any debris and/or air...
Automatic Ice & Water Dispenser
Priming the Water Supply System
1. Begin filling the tank by pressing and holding a drinking glass against the water dispenser paddle. 2. Keep the glass in this position until water comes out of the dispenser. It may take about 1½ minutes. 3. Continue dispensing water for about three minutes to flush the system and plumbing connections of any impurities (stopping to empty the glass as necessary).
Ice Maker Operation & Care After the refrigerator is installed properly and has cooled for several hours, the ice maker can produce ice within 24 hours. The ice maker will fill the ice bin from the rear. You must dispense some ice to force the ice forward in the bin. This will allow the bin to fill completely.
Turning the Fresh Food Ice Maker On and Off Ice production is controlled by the ice maker's On/Off icon on the control panel. Press and hold the "Ice Off" icon for three seconds to turn the ice maker "ON" or "OFF". The ice maker is turned off when the LED above the "Ice Off" icon is illuminated.
Using the Ice Maker after Installation Before making ice for the first time, be sure to prime the water supply system. Air in new plumbing lines can result in two or three empty ice maker cycles. Furthermore, if the system is not flushed, the first ice cubes may be discolored or have an odd flavor.
CAUTION
For proper dispenser operation, recommended water supply pressure should fall between 30 psi and 100 psi. Excessive pressure may cause water filter to malfunction.
NOTE The water dispenser has a built-in device that shuts off the water flow after three minutes of continuous use. To reset this shutoff device, simply release the dispenser paddle.
IMPORTANT On occasion, unusually small ice cubes may be noticed in the bucket or in dispensed ice. This could occur in normal operation of the ice maker. If you start seeing these more frequently, it may be an indication of low water pressure or the water filter needs to be replaced. As the water filter nears the end of its useful life and becomes clogged with particles, less water is delivered to the ice maker during each cycle. Remember, if it's been six months or longer since you last changed your water filter, replace the water filter with a new one. Poor quality household water may require the filter to be changed more frequently.
IMPORTANT Your ice maker is turned on at the factory so it can work as soon as you install your refrigerator. If you cannot connect a water supply, set the ice maker's On/Off icon to Off and turn off the water supply valve; otherwise, the ice maker's fill valve may make a loud chattering noise when it attempts to operate without water.
Hope this helps. Randy
Mar 02, 2015 | Kenmore Refrigerators
Samsung RS265TD Ice maker does not fill with water. After I press test button and the ice maker cycles I manually fill the tray with water and it will eject on next cycle etc. Good water supply on thru...
Hello
Either the fill solinoid is bad or the inlet tube at the ice maker is frozen.
Try running a hair dryer to remove any ice that may be blocking the water from coming into the ice maker tray.
Jul 28, 2011 | Samsung RS265TD
Not making ice after changing filter.
Hi and welcome to FixYa I am Kelly.
A new filter can take several cycles of the ice maker to fill the filter up with water before. The average filter is around 30 oz and the average ice maker fill cycle is 3.2 oz. The new filter did not have any water in it. The water in the door has a resercoir so the air in the filter will still make the water work until you get air. Drain abour 3 tall glasses from the water in door. The ice maker should then work properly. The filter filters water for water in door (inside) and the ice maker so if you have water inside the door you should have ice UNLESS one of the inlet water valve solenoids has failed. Also make sure the Freezer door / light switch functions properly. The door switch is supposed to stop water and ice functions with the door open.
I would like to know if it starts making ice.
Thanks for choosing FixYa,
Kelly
Jul 26, 2011 | Jenn-Air JFC2089HE French Door...
Water overflows from icemaker & freezes in the freezer. Makes three ice cubes in a day & the water is extremely slow to fill glass from freezer door!
If both the water in door and ice maker are experienceing slow water problems the common point is the water supply itself.
This can be caused by:
1. Water supply shut off valve is partially closed or blocked with debris.
a. TURN water supply OFF
b. Remove the water line from the rear of the refrigerator ABOVE the in line filter (if one is installed)
c. Place the removed line into a bucket.
d. Turn on water supply and check flow. It should fill an 8 Oz glass in about 8 seconds.
If it passes this test then the water supply is fine. If it FAILS this test either cflear the obstruction in the line or replace the water supply valve from the house connection.
Test 2 (Water supply is OK
Reconnect water supply to external in-line filter (If installed) or water valve assy connection.
Your unit has a Verticle filter that if it is clogged will cause slow water flow.
Test water thru the door for the same amount of water flow. It should fill an 8 Oz glass in 10 seconds or less.
If it does ot do this then the VERTICAL internal water filter is clogged. (5 months or 500 Gallon change interval)
REPLACEMENT filter is PN LT500P but there are several like / suitable aftermarket replacements for the LT500P number.
As for the ice maker freezing up. There is only one cause for this and that is the water valve assy itself is bypassing water when it is supposed to be closed. The only remedy for this is to replace the water valve. They are not repairable.
The valve is available through sears parts direct:
http://www.searspartsdirect.com/partsdirect/part-number/LG-Parts/Refrigerator-Parts/5221JA2006D/0046/795/Model-LSC26905TT/3204/0165000?keySuffixId=NA&productTypeId=x&searchModelNumber=LSC26905TT&subCompDesc=Ice/water%20parts&brandDesc=LG&modelDesc=REFRIGERATOR&blt=11
Thanks for choosing FixYa.
Kelly
Sep 19, 2010 | LG LSC26905TT Side by Side Refrigerator
I Have a FRS22ZRGD1 Double door fridge freezer combo , the ice does not get any water . I have water to door to fill glass. I replaced water filter a pure souce type. I replaced solinoid valve still no...
For all of you having problem of not getting any water to ice maker the water line running from solinoid valve to ice maker , mine was plugged solid with ice- try blowing through it once you have line removed from solinoid valve. I know they say you can removed the ice with a blow dryer but I tried that the ice was too far down to melt it .I took the line loose from the back of the fridge and un attached retaining screw and pulled plastic insert through cavity of fridge and ran hot water through it. Now it works fine.
Apr 17, 2009 | Frigidaire FRS26ZSG
No ice or water from in-door dispenser
When you first hook water up to the refrigerator you have to fill a tank in the fridge. Open the water supply behind the ref. turn the control on the front of the ref to water and hold a glass under the spout as if you are filling a glass . You may have to wait 3-4 minutes forthe tank and lines to fill with water before you get any to come out into the glass. The water my be discolored at first so run a few glass full through before drinking . hope this helps
Bobalix
Apr 16, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
WATER RUNS DOWN FREEZER WALL
SRCTE,  Are you certain that you installed a NEW water valve?  To isolate the problem between the ice maker and the water valve.  Remove the ice maker from the refrigerator.  Inspect the water fill tube for being stopped up with solid ice.  If so, clear the solid ice with a hair dryer blowing hot air into the end of the water fill tube.  Insert a long screw driver into the end of the water fill tube to break loose any remaining solid ice up in the tube.  Inspect with a flash lite to verify the water fill tube is clear and open.  Leave the ice maker out of the refrigerator overnite and operate the refrigerator as normally used.  After 6-8 hours, open the freezer door and inspect the end of the water fill tube; if the water fill tube is clear of solid ice then you have a bad ice maker which must be replaced.  If on the other hand the water fill tube has ice protruding from the water fill tube then the water valve is defected and must be replaced again.  If the water valve is replaced you may desire to install an external in line water filter. Hope this helps you.  Henry
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Feb 06, 2009 | Refrigerators
Ice maker not workin
ok as far as the water in your door goes sounds like the micro switch is getting a little gummy and sticking this happens when people dump ice in sweet drinks and some splashes up locate the switch and spray a little wd 40 on it as to you ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure yuo hold the plastic insulation so you don't get bit if the ice maker starts cycleing remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didnt fill replace the water valves if the icemaker doesnt cycle and yuo may have to kinda twistm the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Jan 18, 2008 | Whirlpool ED2FHEXN Side by Side...
Fridge freezer door ice maker
the ice maker controls the seloniod the icemaker wire arm must be all the way down .just because the seloniod test good doesnt mean the valve seat isnt stuck the water valves open by your house water pressure if your filter is dirty this can also lower the pressure if the icemaker module is bad this also can cause it if you pull the front of the ice-maker off you will se a bunch of holes if you get a piece of 10 Gage house strip about 1/4 inch off either side and insert it into the holes marked t and h that will test cycle the ice maker they will be close together don't get shocked if the ice maker cycles and doesnt fill and the ice maker fill tube isn't frozen replace the water valve if the ice-maker doesn't cycle replace the brown motor module
Jan 09, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
