Question about Tetra Dynatec Pump: 1100 Pump
In order to clean my dynatec 1100 pump I dismount it all. unfortunatelly I drop the cover a small part broke. I would like to know where I can buy a new cover to fix my pump
  • 2,926 Answers
1-800-423-6458, 7:00 a.m. to 9:00 p.m. EDT, or email from the website;
http://www.tetra-fish.com/contactus.aspx.
Tetra does not list the housing parts seperate for purchase, and you'll have to contact them directly for availability.
You may also try to use a plastice epoxy/ahesive to repair the damaged cover. I'm not sure how bad the damage is, but if you have the broken piece, plastic epoxy's work very well.
Posted on Jul 28, 2010
What could be causing a Hobart WM-5H to not drain at the end of each cycle. It does not drain at the the end of the day either when the main switch is in the OFF position.
clogged tubes,and/or locked pump motor,need to ceck pump (on the very base of the device) for clearence and normal function,it can get a little tricky,u must have a minimal experience in mounting dismounting
most dish washers i have cleaned had small pieces of boness stucked in the pump,of course i got some that were needed to replace pumps or other switch,relay,board...
I got lucky with others,after removing the grids on the bottom I could stick a couper wire in the pumps entrance and release the rotor without having to dismount the device
best regards
Oct 28, 2014 | Hobart Dishwashers
Broke timing belt
If the timing belt broke, your car won't run. Fortunately, it's not too expensive to replace, and as long as you are at it, may as well replace the water pump. Usually they have to dismount that in order to get at the timing belt. Generally that is that case, but it all depends on how each car is set up.
Oct 03, 2013 | 1996 Toyota Camry
Wat to do when rocker ams fall off
Why did it fall off?? Not know what size engine, I'll assume a 5.0 v8. If the rocker arm fell off then I would assume the rocker arm support gave way. You could be lucky and no other damage was done, but in order to see if things broke in small pieces you'll have to remove the valve covers and see what's missing and what's not. You'll have to drop the oil pan and clean all the metal out of it and you'll have to flush the engine oil system to remove all traces of metal shards. It could be considered a winter project if you're a DIY'R. If you take it to a dealer, you may as well buy a crate motor for it and if you take it to a local shop, PLEASE, PLEASE, make sure you can trust him. But even at a shop if done the correct way, at least $2000.
Jan 16, 2013 | 2003 Lincoln Aviator
Tail lights dont turn on
1. Replace your car tail light. You will need working gloves to protect your hand during the process. Of course you will also need a screwdriver, cleaning cloth, wire brush, and a good set of tail light bulbs.
2.Understand that different models of car have different set of tail light covers. Naturally, these covers will require different un-installation procedures. So, determine if you can dismount the cover from the outside or you will have to dismount it from the trunk of the car.
3.Determine how to dismount the tail light cover, carefully detach it from the car. You can use different sets of screwdrivers for this. Be careful not to break the tail lights cover. The important thing is you must be able to expose the bulb in order to extract it.
4.Remove the tail lights cover, unscrew the bulb from its socket. Sometimes you will have to press a little and twist the bulb in order to extract it from the socket.
5.Extract the bulb, bring it to your favorite auto parts and accessories store and find the exact match of your tail light bulb. Be sure to get the correct match because if you use other types of bulb, your tail lights may not work properly.
6.Reinstall the tail light bulb, clean the aluminum casing of the tail light. Wipe the socket and wiring with a dry cloth. You can use wire brush if there are corrosion around the tail light casing.
7.Put the good bulb on the socket. You might still need to apply a little pressure on the socket before you can install it fully.
8.Reinstall the tail light bulb, replace the cover of the tail lights and secure it tightly.
9.Test to make sure your new tail lights are working. Start the engine and apply the brakes. You can ask someone to see if the tail lights are really working.
resource: http://www.wikihow.com/Fix-Car-Tail-Lights
Aug 27, 2012 | 1998 Buick LeSabre
I have a 2004 Sharp R-1214 1100 Watt Microwave and the card like removable 3 x 4 inch plate broke (almost like cardboard) and it covered the vented opening. I don't have a users manual so I don't know the...
That's the waveguide cover you're talking about. It covers the opening in the side of the cooking cavity where the microwaves enter. The oven will work without it, but if you don't have the cover in place, food particles can get into the waveguide and cause problems. You can buy a replacement here.
Feb 07, 2011 | Sharp R-1210 Microwave Oven
How do you replace the fuel pump in a 95 saturn sl1?
FUEL PUMP-REMOVAL:
1. Relieve the fuel pressure. (in order to relieve fuel pressure: 1. remove fuel cap. 2. remove fuel pump relay from the relay panal located under the center console. 3. start engine and wait for engine to stall, then turn off the ignition key. 4. Position a small screwdriver in the fuel pressure test port and carefully depress the valve to allow any excess fuel to bleed out of the fuel line.)
2. Remove the cable from the negative battery terminal.
3. Remove the fuel tank.
4. The fuel pump/fuel level sending unit assembly is located inside the fuel tank. Its held in place by a lock ring. Using a brass punch and hammer, carefully tap the lock ring couterclockwise and sperate the cover from the tank. ***WARNING*** Don not use a steel punch-a spark could cause an explosion.
5. Pull the fuel pump assembly out of the tank. Be careful when manipulating the module out of the fuel tank. it will be necesarry to angle it in various positions as you extract it.
6. Remove the O ring from the opening.
7. Inspect the filter on the lower end of the fuel pump. If its dirty, clean it with solvent and blow it out with compressed air. If its too dirty to be cleaned, replace it.
8. The Fuel pum cannot be disassembled except for removal of the fuel level sending unit. In the event of a defective fuel pump, replace the eniter assembly as a single unit or module.
Hope this Helps!
Feb 07, 2010 | 1995 Saturn Sl
Dismount door panel VW Golf
To remove the external door handle is not nessecery to dismount the door panel. Just follow my instruction: Open the door. Above the latch you will find small round plastic cover 1 inch of diameter.Remove it.There is screw T35 or T40 head/judish star/.Unscrew.Than slide the handle to the right about 1cm.Carefully pul out left side.That is it.
Jan 14, 2010 | 2001 Volkswagen Golf
I have a Bosch washing machine (Classixx) which has been problem-free since I bought it just 6 years ago. Today I tried to clean the drain pump to check for debris / fluff. I've never done this before, and...
look for a small hole in the cover with a wire you can press the release tab.. remove bosch pump cover 1) insert wire in small hole in cover 2) while pressing in on wire twist cover 3) remove cover 4) with the handles of plires twist off pump cover Let me know if it helps or I can go deeper into it.
Sep 26, 2009 | Bosch Washing Machines
Yamaha 1100 Drag Star 2001 Custom motor starter,
These parts are fairly reliable. Rather than buying new, you should be able to pick one up from a motorcycle breaker who will post it to you. I would expect to pay about £60-£100 tops in the UK (Depending on mileage). ANy Yamaha dealer will be happy to order you one new, but they are a hell of a price!
Aug 04, 2009 | 2001 Yamaha XVS 1100 Dragstar
Where is the oil filter on my yamaha V-star 1100
On the right side of the bike (right side when ou are sitting on it) just above the rear brake lever behind a small circular plate. remove the plate and the oil filter is inside (you will easily see it). Warning---on these bikes you have to drop the front exhaust header and right floor board in order to change the oil filter unless you install a after market oil filter relocation kit. If you plan on changing your own oil it is highly recommended to install this relocation kit.
Apr 25, 2009 | 2006 Yamaha V Star 1100 Classic
Tetra Dynatec Pump: 1100 Pump Logo
27 people viewed this question
Top Tetra Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Tetra Garden Expert? Answer questions, earn points and help others
