Question about Jenn-Air Dishwashers
JENN-AIR Model number JD3B10AWX. Bottom of dishwasher is dirty, I want to clean it. I have removed six screws holding plate down, but cannot find any way to remove spinning blade. I think there's a filter underneath that I can clean or replace. Questions: 1. How to remove spinning blade? 2. Am I going about this correctly. Thank you
    Problem Solver:
  • 6 Answers
We have been having issues with our model where there is dirty sand deposited inside of glasses and dishes.
You need a torque wrench for a triple square torque screwJENN-AIR Model number JD3B10AWX. - 82782a1.png to unscrew in the bottom filter to take it off.
I would say about 4-5 layers of items to remove- but remove these and clean them out as well as the top blade which should pop right out. Food particles can get stuck in there also.
Posted on Aug 25, 2010
Screws falling out of track
Add some lock tight to your screws and reinstall......Hope this helps.
Jul 04, 2012 | Jenn-Air 24 in. JDB2100AWS Built-in...
Jenn-air dishwasher jdb1090aws wont drain
Most common issue on this model is the drain motor itself. More times then not it gets clogged with debris. Pull the unit out and remove the three screws that mount the pump to the bottom of the dw.
take the hoses off and clean the drain motor out. It will fix this issue I have seen it more times then you could imagine. Good luck with your repair friend
May 19, 2011 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
How do you take the door apart so that you can clean the glass? We have taken out the 3 screws, but it will not come apart.
i just replaced the glass on a jenn air slide in, remove screw on each side, inside the door, near the hinge, lift door off hinges, remove 3 screws on bottom of door. Trim holding glass should now come off. Remember, hinges are spring loaded.
Dec 29, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air dishwasher will not drain
Hello there:
I am assuming it washes OK
First remove the kick plate.on the front bottom
Is the pump running when it should be draining?
Is The solenoid (Wash/drain) pulling down when it should be draining? (If visable)
Left hand side attached to the pump housing.
If yes then you probably have a blocked drain hose or house drain blockage.
Undo the drain hose at the sink, often stuff can collect where the hose fits over the drain fitting and cause a plug. and also the hose can get clogged on the inlet side of the pump too ok?
If OK. Try to drain it into a pail. Be sure to hold the hose there firmly and put a rag/towel over the top of the pail or you will have water everywhere.
and fully inspect the hose all the way up to the pump .
Hope his is very helpful for you
Best regards Michael
Dec 31, 2009 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Water enters dishwasher, soap door opens but soap
That's a normal path for the soap. It sounds like the water just sits in the bottom without being pumped through the spray arms. Does the pump motor run? Pop the door open in the middle of the washing cycle--you should see hot water dripping from everything and the soap picked up and circulated with the water. If this machine has seen a lot of use, the intake screen under the lower spray arm may be plugged and is accessed by removing the spray arm and working your way down to the bottom of the deck. Might be a problem for a service technician to take care of.
Jul 19, 2009 | Jenn-Air 24 in. JDB1080AWS Built-in...
Vacuum condenser light of sub zero 650 is on - how to clean it
We recommend vacuuming your condenser every 3 - 6 months. Cleaning the condenser is important for the overall operations of the unit including cooling functions. A dirty condenser may lead to warm temperatures in the refrigerator and freezer. It may also cause the unit to run excessively. It may contribute to condensation or frost inside of the compartments. If the condenser is not cleaned properly it may even cause premature failure of mechanical components in the unit. Condenser Cleaning - All Models Before cleaning the unit, shut the electricity off at the control panel. When you clean the condenser, wear gloves to avoid injury from the sharp condenser fins. Use a soft bristle brush and vacuum to remove dust and lint from the condenser. To avoid bending the condenser fins, be sure to vacuum in the direction of the fins, up and down. Clean the condenser every three to six months or sooner if you have pets. 600 Series Framed and Stainless Steel louvered grilles: First remove the grille screws located at the bottom of the grille. Tilt the top of the grille forward and release the springs from behind the grille, then lift off. Overlay Panel Grille: To remove, lift up then pull out at the bottom and down to release from its mounting bracket. Remove the two black screws in the lowest louver of the grille. Tilt the bottom of the grille out and away. It will release from the top of the grille. Model 601RG Stainless Steel Grille: Remove in a similar fashion as the overlay grille panel. 700 Series All Units: At the bottom of the unit, remove the four screws holding the kick plate/grille in place. It will then slide forward, giving you access to the condenser area. 400 Series 424/424FS At the bottom of the unit, remove the screws holding the kick plate. The condenser is located behind. 427/427R: Remove the four screws holding the kick plate/grille in place. It will then slide forward, giving you access to the condenser area. 430: First remove the screws located at the bottom of the grille. NOTE: These screws (Phillips head) are accessed with the door open. Tilt the top of the grille forward and release the springs from behind the grille, then lift off. 200 Series 245, 249, 315W Remove the kick plate at the bottom of the unit, giving you access to the condenser area.
May 30, 2009 | Sub-Zero 650 / O Bottom Freezer...
Door
With the door in the open position, looking down at it, you'll see a number of screwheads along three sides (the non-hinge sides). By unscrewing all of those you'll be able to lift the inner stainless steel plate away from the rest of the door, exposing the wiring. NOTE: lift the inner plate away easily as wires are attached to it. ALSO: I suggest keeping track of which screw goes to which hole as 2 of them are longer than the others.
Aug 23, 2008 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Jenn air double ovens
First, with the door closed, find the screws at the bottom of the door and remove. With an assistant, open the door and remove any side and inside screws you find. The door will separate into two halves. Be aware that most glass is not clipped in...they can fall and break. Remove the front panel from the door...the door may try to slam shut. To clean the glass, use a blue cleaner and a scrubby or very fine steel wool rubbing gently. Scratches are not allowed! Take pictures of what you're doing so you can replace. Be careful of brittle door insulation.
Oct 30, 2007 | Jenn-Air JJW8230D Electric Double Oven
Dishwashers Logo
85 people viewed this question
Top Jenn-Air Dishwashers Experts
Marvin
Marvin
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
