Remote control for dvd/vr
Used unit 1 year with no problems. Today I cannot use remote control. Changed batteries; no use. Can turn on and off unit directly only. Unit displays time and channel number. Any other button of remote yields "SET 1" on display. I cannot find anything in manual about this.
  • tonsil Apr 24, 2008
    Help! I am missing my soap opera!
As advised by a client of Fixya, I pressed 1 and enter at the same time and, hurrah!, everything worked. Let's hope it continues. Thank your!!!
Tonsil
Posted on Apr 26, 2008
Remote stopped functioning for dvd\vcr unit
When the remote control won't operate the DVD player recorder, check the batteries. Try replacing them and see if the remote works. If the batteries are fine, the code on the remote and the code on the DVD player recorder might not be the same. When aiming the remote at the unit a number will be displayed. To set the remote to the same number, which will be 1, 2, or 3, press down OK on the remote as the appropriate number at same time.
God bless you
Sep 27, 2012 | Samsung DVD-VR375 DVD Recorder/VCR
While going through the setup procedure the Set 3 was accidentally changed to Set 1. Any activation of the Control setting only makes the unit go to "Set 1" It appears to be locked up at that...
You can try resetting the remote itself (this is necessary whenever the batteries are replaced). Remove the batteries, as if to replace them, press any key on remote (to clear its buffer) then reinsert them. Next step, since your unit is 'Set 1' (or remote command mode 1 - DVD1/RC1) - you could (on the remote) press 1 and OK/ENTER together - hold them for 10 seconds, then release.
This should restore the remote to the unit. If it doesn't, a workshop service may be required to reset the unit internally, but at a cost. Try the remote battery reset first (even try using new batteries).
Apr 05, 2011 | Panasonic DMR-EH50S DVD Recorder
The remote for my kenwood vr-407 receiver always chooses to work, and then randomly chooses not to work, and then chooses to work again. sometimes opening the battery cover and rotating the batteries a...
Try this advice:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
"Dead" Remotes Can Be Saved
How to Re-Start Your "Dead" Remote Control
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the unit.
If it works, Great!
If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Find new or replacement remotes:
http://remotes.com/store/codes_original.html
or eBay: search for "(model) remotes", check the 'include description
Mar 22, 2011 | Kenwood VR-407 Receiver
Remote Control Code problem
I read through other problems on the web page and tried them
Finally I got one of them to work
Thanks
Feb 28, 2009 | JVC DR-DX5 DVD/HDD Recorder
Jvc av 35750 remote has to be very close to work
i removed the red plastic cover from the remote sensor on the tv. behind that, i found a sticker from one of the parts inside the tv had come loose and fallen to where it was partially blocking the sensor. I removed the sticker and everything works great now.
Jan 07, 2009 | Kenwood VR-309
Bush DVD 2038 DVD player
I contacted Bush custimer care and this is the reply I got:
We apologize for the inconvenience caused to you.
We would request you to kindly reset the remote control by following the steps mentioned below:
1. Remove the batteries and reinsert the batteries after 1 minute.
2. Press and hold the top, right and the bottom navigation button on the
remote control along with the number 1 button (as in 123) for 10sec.
It didn't work for me, but I have posted it on here, just in case it works from someone else
Feb 02, 2008 | Televison & Video
Remote no longer controlls recorder
Remote can be used to control more than 1 recorder, on the remote press enter and 1 simultaneously, this should switch the remote to control dvd 1.
Oct 23, 2007 | Panasonic DMR-E55 DVD Recorder
Philips DVD 750 VR
It may havee a problem with the button you need to press to switch from VCR to DVD, from what i understand and have seen this switch over is not automatic. On your remote you should have a control to switch from VCR to DVD. In addition on your unit there should be a button to switch from VCR to DVD. Try this and let me know how it turns out, if you are still having trouble we can setup a troubleshooting session.
Sep 10, 2007 | Philips DVP642 DVD Player
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
