Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a craftsman 139.18190 and I cannot get my remote to work. its gray with one black button? any suggestions?
    President:
  • 3,197 Answers
Try a new battery. If you have only one remote it could be your receiver that has quit or it could be that the remote has just failed. No way to tell for certain.
Posted on Jul 29, 2010
How to open sony rmvlz620
I have a Sony RM-VLZ620T IR Remote Control.
This remote consits of:
(Outside)
- Two pieces of black plastic cover.
- A red plastic cover on the front of the Remote (It covers the IR leds)
- One piece of gray rubber stripe with fixing patents(!) around on the sidewall of the remote.
(Inside)
- One piece rubber sheet with the buttons.
- One piece circuit board with battery fixer metalic springs.
1. Removing the gray stripe.
Be gently to avoid to tear apart the rubber fixing patents. (There are three kind) It's much easier if you start from the back of the remote near the arc and move forward one by one. Use a small screwdriver or a plastic tool.
2. Opening the cover (together with gray stripe removal)
There are 5 rectangle shaped "holes" (~7mmx2mm) on the both side of the upper black plastic part of the cover (2x5). Use a screwdriver to lift them up (away from the bottom part) one by one from the back to the front.
Hole positions:
1. Near the sony logo
2. Next to the 1,3 channel buttons.
3. Next to the heart and info buttons.
4. Next to the record and stop buttons.
5. Next to the set and power button.
Dec 30, 2013 | Sony RMVLZ620 Remote Control
I have a craftsman 315mhz 1/2 hp opener and both remotes stopped working. The light on the base unit is solid. I tried reprogramming the remotes both from the wall unit and from the opener. The overhead...
Sounds like your receiver has quit working. To program the remotes do this: Press and hold the button on the remote while you press and immediately release the smart/learn button. Do this for each remote. If this doesn't work your logic board is bad.
Jun 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
Chamberlin garage door opener has 3 terminals 1 2 3 2- photo eyes 1- pushbutton (doorbell type) 1-remote What is the correct connections?
1 WIRE WITH RED TRACE
2 WHITE WIRES WITH NO TRACE
3 WIRE WITH GRAY OR BLACK TRACE
ALSO THE WIRE TO THE WALL CONTROL MUST BE WIRED CORRECTLY - DOUBLE CHECK - IT TELLS YOU WHITE AND RED TRACE OR 1 & 2
YES THE POLARITY MATTERS ON THE WALL CONTROL EVEN IF IT LOOKS LIKE JUST A DOORBELL BUTTON.
HOPE THIS HELPS
Oct 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
Is the Craftsman 139.53681B remote compatible w/ 139.53753 remote
They have changed the radio frequency and the two will not work with each other.
Dec 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman GDO - Remotes not working
I think this is an easier way to program. Press and hold the button on the remote and then press and immediately release the smart/learn button on the rear of the motor unit. Do this for each remote you have.
Jul 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a DBW0777 1/2 hp Craftsman garage opner that was working fine until I tried to change codes to prevent a possible theft. I thought this model from 1994 had dip switiches but it has a remote...
Download a copy of the owners manual from www.managemyhome.com and look up remote programming. The process is pretty simple but you'll need a ladder to get up to the motor.
Report back so that we know how it worked out for you.
Jul 13, 2009 | Garden
Craftsman new 315MHz Garage door remote programming with old openers
The radio frequency has been changed so the two are not compatible.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener remote won't work
look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Apr 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
751 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
