Question about Horizon Exercise & Fitness
Lube Belt displays on digital display how to reset or where to lube the belt.
    President:
  • Horizon Master
  • 832 Answers
The message "LUBE" or "LUBE BELT" scrolls across the console display window. The treadmill will not operate while the message is displayed.
Reset the console by pressing the STOP and SPEED “+” or “^” for five seconds.
Posted on Jul 29, 2010
Where does one lube the belt on this treadmill?
Belt is the surface you walk/run on.lift it up in the Centre and spray lube on the board belt runs on
Jan 08, 2015 | Exercise & Fitness
Code 701 06 comes up
I have a T91 and first had the Lube Belt error. After lubing the belt and upon turning the unit on while holding the Stop (Not necessary according to instructions by horizon but I did it while powering up anyway) button down, the 701 06 was momentarily displayed. The unit then displayed the Lube Belt warning again. Lemme know if you hear anything, I am working on it.
Burt
Nov 17, 2013 | Horizon Exercise & Fitness
My Vision 9259 stopped midworkout.
please LUBE the deck belt see the video, lube the rollers bearing front and rear, test the drive belt for worn and replace. God bless you
Jun 08, 2013 | Dmm Vision Fitness T9500 Treadmill
Weslo cadence g40 stops for no reason
you must LUBE THE deck belt by aprox 150 miles. In according with the schedule maintenance,
Please LUBE the deck belt+rollers bearing.
see the video
If the problem persist time to replalce the OLD board deck belt.
God bless you
Jan 22, 2013 | Weslo Cadence G40 Treadmill
TRADEMILL START AFTER DISPLAY ERROR3 AND 5SEC OFF
1) LUBE the deck belt, you must do it every 1 week after use. Otherwise you will the same problem that you have right now. This is by lack of maintenance. Maybe you have WORN deck belt.
2) LubE THE rollers bearing with WD-40 NOT use for deck belt. deck belt is with 100% silicone lube.
3) Test the input voltage motor, if there are the motor need repair. see my personal TIPS for troubleshooting motor.
4) Test the output voltage board, for input voltage board, if there are NOT the board is faulty.
See the block diagram
God bless you
Nov 26, 2012 | Proform Sport 1000 Folding Treadmill...
Pro-Form EKG 53590
1)Adjust the REED switch, see the diagram, clean it, and tight the plug or connector very weel
2) LUBe the deck belt, this happen because the lack of maintenance every week of use. Use the 100% silicone lube. Maybe you have a WORN deck belt now.
3) LUBE the rollers bearing with wd-40 use small quantity.
4)Test the input voltage motor, if there are the motor need repair
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 25, 2012 | Proform Exercise & Fitness
Stops running, display flashing
1) LUBE THE deck belt, maybe you have WORN deck belt, time to replace
2) LUBE the rollers bearing too, very well
3) test the bearing from the main motor, time to repair.
God bless you
Nov 11, 2012 | Proform XP 580 Trainer Treadmill
I have an Image 17.5s that the display is flickering and although the belt runs when I walk on it, it wobbles. What can I do?
1) adjust the tension.
2) LUBE the deck belt . maybe you have a WORN deck belt.
3) LUBE the rollers bearing.
Try again, if the problem persist you must need replace the worn deck and belt too.
God bless you
Nov 12, 2012 | Image 17.5 S Treadmill
Belt stopped
1) lube the deck belt inmediately.
2) lube the rollers bearing too
3) measure the input voltage motor, if there are the motor need repair
4) measure the outputv voltage board, for input voltage motor, if there ARE not, the board is faulty.
see the block
God bless you
Jun 28, 2012 | Exercise & Fitness
Lubed belt but display still says lube belt and I cant do anything how do i clear the display I have the horizon gs950t
After lubrication you have to reset your treadmill settings. Then only the message will go off. To reset the tread mill do the following.
1. Hold the "Stop" button for three seconds to reset the treadmill and clear the current workout selection or screen. The console will reset but will save any accumulated data
2. Press and hold the "eTRAK" button for 10 seconds to reset the console date. This permanently deletes any previously accumulated data
3. Press and hold the "Stop" button while pressing the Speed "+" button. Hold for five seconds to reset the console after applying lubricant to the machine. Lubricant application is usually only necessary when you receive the "LUBE" error
ok
May 04, 2011 | Horizon Fitness Horizon T90 Treadmill -...
Exercise & Fitness Logo
1,466 people viewed this question
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
