Question about General Electric Dishwasher Timer
I would like to time my dishwasher and washing machine to swith on at night to use cheaper electricity. I have purchased a hi-load digital timer sku 195 057 from wickes. Is this suitable?
Elxtrolux front load wash/dry machine motor wont spin
Yes it is the timer Also check the lock button under the lid for obstruction or damage from opening the lid too soon the time before you did a wash .
May 14, 2012 | Electrolux EWDW6505GS Fully Integrated...
I have a Bosch SHU3036UC dishwasher. While sitting idle - during the day or over night, it fills up with fresh water. I shut off the water supply last night and this morning it was dry. Any ideas?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 12, 2011 | Bosch SHU3036UC Dishwasher
Fabric softener cup on Maytag Neptune washer is full of fabric softener after the cycle. Checked valves in output mode. Both the main and the bleach valve turn on and dispense water, but no water dispenses...
Hi. your problem is actually a rather complicated one.
Timer and selector switches The timer switch is usually the largest dial on the main control panel. It can be either a mechanical device much like a simple clock, or completely electronic with just a digital readout.
The timer runs the washing machine in a pre-determined pattern. It provides the electricity to all of the washing machine components at the correct time and for the correct length of time.
The Start switch is usually part of the timer knob. When you set the timer to the proper cycle, you either pull or push the timer knob to start the cycle.
The selector switches or knobs vary from machine to machine. Most washing machines have one or several switches or knobs on the control panel besides the Timer/Start switch. These let you adjust certain settings; for example, the water temperature, spin speed, timer cycle, and so on. Normally, the washing machine completes the cycle selected on the timer, regardless of how you set these switches and knobs.
Jul 14, 2009 | Maytag MAH2400A Front Load Washer
NOT SPINING ALL THE TIME, could it be clutch?farrulla@yahoo.com
if you have to reset the dial, it would be a worn out contact in the time.
purchase a rebuilt timer and all should be ok
if there is an issue with the clutch you will smell a burning smell as your clutch heats up from slipping.
i dont think it is the clutch, but more likely the timer. and possibly the lid swith
May 26, 2009 | Roper RAS8244KQ Top Load Washer
Sensing light comes on and then the timer stop going down
I do nto have a solution- just the exact same problem. My machine gets stuck on 76 when doing a "normal wash" . last night I hit cancel and drain, then went to "time saver" and ran the wash and it seemed to work fine. Funny that both of our amchines stop at 76. Any ideas?
Nov 18, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher won't cycle through to rinse/dry/stop
Your timer switch is most likely defective.
It probably needs to be replaced.
It is like a clock with switches at different times
If it is stuck at a particular time it will run there forever.
Before servicing disconnect power!!!!!!!!!!
You can remove inside door panel with about 6 phillips screws or so.
Timer is directly attached to the dial on your machine.
These cost about $100.00 or less.
Can also be found used online for cheaper.
Oct 26, 2008 | Kenmore 24 in. 17512 Built-in Dishwasher
Kenmore 22924 top load
timer most likely suspect ..not sure of timer cost sears price usually 110-160 may find local parts place with cheaper price for part number remove console end caps remove screws underneath roll console up and back number on timer beside fsp or just go to sears.com click on parts link type in washer model # look for timer
Sep 04, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag mav5200aww points in timer stuke (hot)
hi thanks for the question i would have your timer rebuilt from a appliance timer re builder much cheaper thanks the appliance doc
Aug 19, 2008 | Maytag Atlantis MAV6000 Top Load Washer
General Electric Dishwasher Timer Logo
93 people viewed this question
Top General Electric Hardware & Accessories Experts
Marvin
Marvin
Craig Butler
Craig Butler
ray gallant
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
