Question about GE WPRB8050D Top Load Washer
GE WPRB8050 Profile Washer...control board problem??
The LED lights on the control board cycle randomly, some times not allowing the washer to be started. The lights blink and beep randomly all day, prompting us to unplug the unit when not in use. Tried unplugging and resetting electronics multiple times. The unit is progressively getting worse. Suspect control board failure, as otherwise unit operates fine. I would like to repair myself, are there instructions online on how to disassemble front control panel to access control board?
This sounds goofy but I saw it on another help site and it worked for me when my 8050 washer's controls crashed.
Unplug washer for 1 minute then plug back in.
Open and close the door rapidly six or more times within 30 seconds.
After I did this my machine worked normally.
Step one is in the owners manual but didn't work for me. It was only after opening and closing the door rapidly that the controller reset and worked properly.
Posted on Jul 31, 2015
Not draing
Posted on Jul 30, 2010
GE Profile model wpgt9350 washer randomly turns on.
It has happened now and again, but in most cases it was traced to the control circuit board. If under warranty, have a technician check it out.
Feb 27, 2014 | Washing Machines
Our GE Profile Model pdw7880j03ss Serial. Zg780219b Control panel will not allow heated dry and pre wash to be selected at same time. Also, when a cycle is chosen, panel automatically switches to sp
If you have the ability to disconnect the washer from the rear or kill the power from your main breaker box do so that it resets the control board.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jaime_a0afdb97baa63a3d
Nov 09, 2012 | Dishwashers
Faulty stop pause button on ge profile wpre8150
This is caused by a faulty control board. The button you referred to is part of the board and the control board manages all aspects of the wash cycle. You will need to replace the control board. Here is a link to the part you need.
Oct 13, 2012 | GE Profile WPRE8150K Top Load Washer
GE WPRE6150 -Shuts down
4 flashes = Overfill fault presure pipe blocked
Check for high water pressure to unit, usually an indication of a bad water inlet valve.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 07, 2011 | GE Profile WPRE6100G Top Load Washer
Ge profile wpre6150k1wt washer does not complete cycle. washer stops with tub full of water. Will not start again. tried unpluging to reset. this worked a couple of times but not working now
Hi
First make sure to test the lid switch assembly, you can jump it to test it. If the lid switch and motor is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 29, 2011 | GE Profile WPRE6150K Top Load Washer
Replaced motor in ge profile washer now nothing happens when plugged in
Make sure your wire harness is plugged into the motor securely and also inspect the pins on the motor to make sure they aren't bent and make sure the motors part number match up with the old motor along with the different wires if its the wrong motor which a parts house can by mistake order the wrong one it wont work. Also does this washer have the electronic control board with the lights at the top or a led screen? If so might not be the motor might be a bad control board. I will stand by if you have further questions.
Jan 07, 2011 | GE Profile WPRE6100G Top Load Washer
My ge profile harmony washer will turn on but will not allow me to start a cycle
try taking apart the control panel and unplugging the main and control board. Wait for 15-20 minutes and replug. Repairman said mine had static in the system and unplugging cleared it.
Jul 19, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Harmony washer will not move from problem notification screen.
Press and hold the my cycles button and the back button simultaneously for 3 seconds. This will reset the control panel and allow you to see any stored errors.
Feb 28, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE WPRB8050D Top Load Washer Logo
1,169 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
