Question about Valor DTS660WT Car Video Player
Is valor its 705w compatible with clarion installation kit?
I have a clarion deck installed in my 2004 mazda 6 and i want to install a valor its 705w, will i need a different installation kit or will the clarion installation kit work with the valor?
How do i set up the sirius xm
This radio is SiriusXM *READY*. You will need to purchase and install the *optional* SiriusXM-Connect Vehicle Tuner kit (tuner, antenna, cables, hardware) specific to your radio - linked below:
SiriusXM Tuner:
SiriusXM SXV300v1 Connect Vehicle Tuner Kit for Satellite Radio
Manual (.pdf):
http://www.clarion.com/us/en/pdf/CZ702_Manual.pdf
Jun 11, 2015 | Clarion CZ702 Car CD/MP3 Player - 76 W RMS...
Tip
Clarion SIRCR Sirius Install Manual Download
Download Clarion SIRCR Sirius Vehicle Installation Kit Install Manual
Have you misplaced your Clarion SIRCR Sirius Vehicle Installation Manual?
Would you like a digital, searchable, pdf version of the Clarion SIRCR Sirius Vehicle Installation Guide?
Follow this link to download a pdf version of this manual.
I hope that helps.
__________________________________________
on May 03, 2010 | Car Audio & Video
2004 Honda CRF 250 R flat spot
Hi, Anonymous and the usual suspects are:
1. Installation of a different camshaft.
2. Different exhaust system or "STRAIGHT PIPES"
3. Faulty advance curve.
4. Multiple carburetors not in sync.
5. Improperly installed jet kit or wrong kit.
6. Carburetor internal malfunction.
7. Fuel mixture too rich.
8. Fuel mixture too lean.
9. Extremely dirty air filter.
For more information about your issue and valuable "FREE" downloads that you will need for viewing and printing please click on the blue links below. Good luck and have a wonderful day.
https://crfsonly.com/forum/viewtopic.php?t=11582
05 CRF250x flat spot
Honda 2004 CRF250X Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda 2004 CRF250X Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 14, 2014 | 2004 Honda CRF 250 R
Mazda 6 sport sedan break lights not working after hid light conversion
Instructions Open the rear deck lid on the Mazda 6.Carefully remove the plastic finishing cover from the license plate light housing, using a small flat-head screwdriver to release the locking tabs. Pull the cover downward and off of the deck lid, exposing the license plate bulb.
Remove the old light bulb from the license plate bulb socket by hand. Wrap your new one in a paper towel and do not touch the bulb with your bare fingers. Insert the new bulb into the light socket. Install the finishing cover onto the light housing and push it upward until it clicks and locks into place.
Repeat Steps 2 and 3 to complete the LED light conversion on the opposite side of the deck lid. Test the new bulbs by turning on the headlights on the Mazda 6.
Mercedes Parts.
May 25, 2012 | 2004 Mazda 6
I bought Alpine X-305s head unit for my 2004 Mazda 6. My Mazda has the standard AM/FM with CD player. It does not have the BOSE system. It does not have an additional CD changer. My question is: will I...
The usual items you will need is a wiring harness and an install kit. The wiring harness will allow you to hook the radio to it, and then just plug into the car. The install kit will have all the little mounts and trim rings you might need. Each of them cost around $15 each, unless you have some crazy set up. Your's doesn't sound like that. You can purchase these items at www.crutchfield.com and you can search for your specific vehicle. Hope this helps.
Aug 24, 2011 | Alpine Car Audio & Video
THE CLARION CX609 WONT FIT IN MY 2001 CROWN VIC. ANY SUGGESTIONS BESIDES BUYING A DIFFERENT RECEIVER. WILLING BUT REALLY DONT WANNA
That is going to be a touch install if memory serves as your vehicle is not double din. Much easier to sell that and get a single din radio and install kit.
Dec 25, 2010 | Clarion CX609 Car CD/ MP3 Player
I had a Clarion 6 Disc CAA-355 in my car which got wet and is no longer working. Can I buy the same model again. If so where from and for how much or is there another model that will be compatible with my...
Great Clarion Disk Changer, 6 CDs CDC-655Z:
CDC655z Multi-Disc Changer - 6 -disc direct load mechanism. - 1-Bit D/A converter. - 10 sec. read ahead memory to prevent interruptions caused by shock and vibrations. - Non-stop play. - Optical Digital Output. - 0º to +90º mounting angle.
Great Multi-disk player. Works only with Clarion audio source units.
Selling b/c my deck player broke- I can give you the deck- maybe you can fix it. The model is DXZ-535, comes with owner's manual and remote.
Feb 25, 2010 | Clarion Car Audio & Video
I need the wiring diagram for this deck (vrx745vd)
Go to www.clarion.com click united states...then type vrx745vd and look to your right...you can download..
May 10, 2009 | Clarion VRX745VD Car DVD Player
Valor DTS660WT Car Video Player Logo
59 people viewed this question
Top Valor Car Audio & Video Experts
David Payne
David Payne
hoyzee1
Tom Chichester
Are you a Valor Car Audio and Video Expert? Answer questions, earn points and help others
