Question about Homelite Leaf Vac Attack
Engine keeps flooding
Homelite backpack blower, model HBL26BPN.
Engine starts briefly and stops.
Cannot be re-started within 24 hrs.
Engine floods, even without priming.
Blower bought Januarry, 2010.
    Guru:
  • 632 Answers
Locate the gold screw on carb which controls air/fuel mixture and turn it anti-clock wise quite a few turns
it's most likely set too high and is just allowing too much fuel through and flooding the engine completely, If you Turn it totally anti-clockwise and start and it won't start you can gradually turn it clockwise until it starts and continues to run without flooding.
Posted on Jul 28, 2010
Hard stating flooding
Search Results
    Rider mower carburetor flooding - help ! - YouTube
    ? 1:30
    https://www.youtube.com/watch?v=ZYqtKvLXYtY
    Sep 29, 2010 - Uploaded by Joyce Boncal
    It won't start. ... Rider mower carburetor flooding - help ! .... ( HOW TO ADJUST VALVES) FIX HARD TO START Lawn Tractorwith OHV Briggs ...
    How to stop a Briggs crankcase from flooding with gas Order ...
    ? 11:34
    https://www.youtube.com/watch?v=VhEiLMtPR5M
    Aug 5, 2013 - Uploaded by doublewide6
    If your tractor keeps leaking gas into the crankcase see how you can fix the problem by ... The hard starting is caused by fuel filling the cylinder.
    Basic Troubleshooting - Lawn & Garden Tractors - Cub Cadet
    cubcadet.custhelp.com/.../basic-troubleshooting---lawn-%26-garden-tract...
    Sep 13, 2002 - Engine fails to start, Engine flooded, Crank engine with throttle in FAST... Engine runs erratic or stalls, Tractor running with CHOKE activated ...
Jan 25, 2016 | Garden
Have a 2004 nissan altima plugs getting wet with gas take them out and dry car starts but same problem after 5 6 hrs won't start again what's the problem
Your engine is flooding with fuel which is why you have wet plugs and why you are having problems starting the car. A flooded engine will not start.
It sounds like a recurring flooding problem rather than a one off and the injectors may be leaking. One way or another too much fuel is being delivered by the injectors.
Get the car into Nissan Service and have them check it over and identify the cause.
Here is some information on the flooding problem prepared by a professional master mechanic.
Flooded Engine
Jan 25, 2016 | Nissan Cars & Trucks
How do i adjust my idle crew
The idle screw isn't as important as the low/high setting on the carb. Start with one turn out on both low and high side settings.
Aug 30, 2014 | Homelite Garden
Ryobi ry08576
make sure your fuel is fresh and mix at 50:1
then remove the muffler and try to start it holding the throttle wide open... if it starts and runs fair suspect a flooded engine, plugged muffler
if not, suspect a carb adjustment issue and then a carb
Aug 14, 2014 | Ryobi Backpack Blower 25.4cc
McCulloch backpack leaf blower wont start and sprays gas out exhaust when trying to start
The machine is completly flooded, remove the spark plug, switch the ignition off, crank the engine until there is no further fuel spraying from the plug hole, leave for a few hours to dry out, replace a dry plug and try again with no choke and full throttle.
Mar 28, 2013 | McCulloch Garden
I have this exact blower and it doesn't seem to work anymore. It worked last week and when I try to start it up using the start up procedure it doesn't start. It has enough gas/mixture and is primed. I can...
Hi, this sounds like a wiring issue. If there is fuel supplied to the engine and the spark plug is good, you should be able to get it to fire. However if there is no spark due to a broken wire or faulty kill switch you will not receive a spark. Also, if you are certain that all systems are in order, you may have simply flooded the engine and the gas needs to evaporate from the various chambers. If it is flooded, you may also try starting in full throttle to compensate for the extra gas. This sometimes works. Good luck.
Nov 16, 2010 | Homelite Mighty Lite Blowervac
How do I adjust needle valves on a 25cc Homelite UT08111A Backpack leaf blower?
Set the lowend & highend needles to about 1 3/4 to 2 turns each. Choke the carb or prime it, until the carb is wet. Fire up the engine and let it warm up. Let's set the topend first since it's the easier of the two. Go to full throttle. Adjust the topend needle for peak RPM. Leave it wide open for about a minute to see if it changes any. Should the engine go lean, open the lowend needle slightly, if this dosen't work... you will have to adjust the needle valve inside the carb.( I will explain this later) If the topend runs OK, then slowly pull the throttle down until the engine begins to "four cycle" hold the throttle there. Adjust the lowend needle until the "four cycling" barely stops. Now lower the throttle more until it "four cycles" again, and adjust the lowend again. Keep doing this until you reach full idle. Now, from full idle begin to throttle up until the engine starts to bog or hesitate. Open up the lowend needle just enough to eliminate the bog or hesitation.
http://tech.flygsw.org/walbro_tuneup.htm
hope this helps :)
if it does please vote
Oct 23, 2009 | Homelite Consumer Products Backpack...
Gas is pooring out of the exhust
Needle valve in the carburetor is not stopping the flow of gas. It may need to be rebuilt. You also may have flooded the unit trying to start it.
I would have a shop do a compression test on the engine; it needs to be at least 100 psi to run.
Sep 30, 2009 | Homelite Consumer Products Backpack...
HB-180 Leaf blower won't start
if its flooded then it surly wont fire,not a 2-stroke. are you over priming or is there a malfunction. remove plug,put plug not a tester in the end of lead,ground, and pull. spark should be purple and consistent. if red/yellow/intermitent. change he plug. if the engine is only flodding on its own then the needle and seat could be stuck open in the carb, gas tank vent in fuel cap plugged and building tank pressure, or fuel mixed too rich. let me know what you find
Sep 02, 2009 | Homelite Consumer Products MightyLite...
Homelite Backpacker II leaf blower start fine then shuts off when I engage the throttle.  Seems like engine is flooding.  Just installed new spark plug, not sure what to do next.
have you checked air filter? the carb may need adjusting. locate the adjustment screw(s) , screw them all the way in then back out 1-1/2 turns. try to start the engine. then let me know what happens.
May 17, 2009 | Garden
Homelite Leaf Vac Attack Logo
242 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
