Question about Toshiba Televison & Video
One of the mounting screw brackets (on inside of tv) model 40xv648u was stripped and I need a new one. How do I order one. I think my daughter's boy friend did it. I just need the bracket with the mount (threaded part attached) so i can replace it and hook up the wall mount bracket to it. He tried to put the wrong size bolt into the screw hole and stripped the bracket loose and ruined the thread. I will gladly pay for a new one. The part had these numbers on it... 46 42 if that helps any.
    New Friend:
The size is M8 x 25mm pitch 1.00. I just bought four of them at Ace Hardware for $.59 apiece.
Posted on Jan 29, 2014
  • Chris DeGreef
    Chris DeGreef Jan 29, 2014
eagle338
  • 4889 Answers
SOURCE: no screws for the tv to mount to the bracket
You will 4 m5x18mm and 4 m5x25mm machine screws. That should do the trick..
Posted on Mar 01, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
SOURCE: what is the wall mounting screw diameter for a Toshiba 40xv645u
dude, im having the same problem - 5/16" wouldnt thread. I'm guessing they are metric - on my way back to Home Depot...i'll let you know what i find out.
Posted on Oct 22, 2009
budmrtn
  • 11361 Answers
SOURCE: screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
Posted on Dec 23, 2009
  • 102 Answers
SOURCE: I was trying to wall mount a 32-inch flat screen.
If you get a slightly larger drill threader bit you may be able to rethread the hole to a slightly larger diameter.
Posted on Feb 01, 2010
How do secure this DW to the inside top of cabinet... there are no holes to skrew through!
This is sort of strange, you give no info on what kind, model brand anything.
I will try to help anyway though. most dishwashers come with TWO REMOVABLE BRACKETS that clip to the top.
A single short wood screw goes through the bracket into the underside of the counter top.
IF YOU HAVE A SOLID SURFACE OR GRANITE COUNTER TOP, you might have to side mount the dishwasher. You might have to order the side mount brackets from the manufacturer or a parts house. Some stainless models have a little removable plug on each side that will accept a wood screw that goes into the cabinets on each side.
If you need more information please give us the brand and model number of the dishwasher.
Sep 26, 2017 | Washing Machines
What size screws do I need to mount my Polaroid model no. Tlac 02255 to a wall bracket?
Dear Billy,
It is very difficult to determine what size screw for the TV bracket.
  • If you bought a wall bracket, it will definitely have different sizes of screws in it.
  • Follow the installation guide for what Size screw to use on the TV. It varies by manufacturers.
  • Get a Universal Bracket.
Good Luck!
JP
Jul 08, 2015 | Polaroid Televison & Video
Eu97273 is a request order for 12screws to put my 60inch element tv on its bracket of which you people shorted me when I bought your tv, I've been waiting 3weeks now and no screws have been shipped. W
You can usually find equivalent screws at the local hardware store or Home Depot or Lowes. And, the bracket company may be easier to get screws from than the tv. Also, try thrift stores where they have used mounting brackets and parts laying around.
Feb 11, 2015 | Televison & Video
My screen was damaged and I finally found a new screen for it. How do I get the molding off so I can replace the screen?
You need to remove the two strips one on top and one on bottom of the plastic frame on the front of your tv. They can be easily flip up with a small screw driver. After removing the strip, you will see screws that hold the frame to the TV set, remove all of them then take the metal strip off. remove the frame, the protective cover, then remove the screen. The mirror then need to be sit on the slot of the back cover then hold it with the 3 brackets on the top on the inside of the rear cover.
Sep 26, 2010 | Pioneer PRO-710HD 64" Rear Projection...
LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Jul 01, 2010 | Insignia LCDTV26 26 in. Television
I need info on how to switch the case out
There is no written instructions. I looked online but there isn't any.
Follow this instructions
1)with the game-boy screen facing you, there are 5 round things there.
3 up and 2 down the screen.
2) put your screw driver inside there and remove it. Do it to all of them.
3) there are screw(nuts) inside those round things. so remove the screws(5) with the screw driver.
4)Don't open the LCD yet. Turn to the back of your gameboy, there you see 6 srews(nuts). 2 up one middle(for the battery) and 3 down. Remove the screws.
5) after you remove all 6 screws, the middle screw is for the battery. open the cover now the screw is gone and remove the battery.
(please remove any screw you see where the was before)
6) Open your game-boy with knife or with anything possible for you then the screen.
remove any screw on the board inside of the game-boy.
slowly and carefully disconnect a cable that is connected to the motherboard( LCD cable)
7) remove the speaker and then transfer it to the new skin, remove all the buttons and transfer then, now put the motherboard to the new skin, remove the Screen(LCD) then transfer it to the new skin. put the LCD cable you disconnect from the motherboard back. put the motherboard screw back. put the LCD screw back.
8) Turn to the back of the game-boy and put the battery back and all crews back. Now you are set enjoy!!!. feel free to ask me any question.
Jan 24, 2010 | Nintendo Game Boy Advance SP Console
Philips tv mounting problems
did you ever find a solution for this? the same thing happened to me, and now philips wont repair the mounting hole. I am so mad and will never buy another Philips again!
Dec 26, 2009 | Philips 42PFL3704D LCD TV
I am trying to remove the stand on a LG Model : 52LB5D. I have removed the 4 screws on the back but can't remove stand. It feels like there is another screw or something holding it in.
If you are looking at the back of your tv there is the stand bracket with a screw on each side. remove those screws and nothing will happen. that is the problem i was having but if you look right above the ones you just took out and there is going to be a black screw. take those off from each side and it will fall off.
Dec 09, 2008 | Televison & Video
How do i attach a Wall Mount to the TV?
Hi, Ok, great.Look at the back panel and you can see four holes spaced 4" between the top and bottom, and 16" from side to side. these are for universal mount. http://www.bestbuyplasma.com/Plasma/tvmounts_land.asp I think this clears your problem regards sreejith "Please use caution if wall mounting this product. Follow all directions from the manufacturer of the wall mount and be sure to securely fasten the product to the mount. While the TV can be wall mounted, improper wall installation may void the warranty."
Jul 16, 2007 | Akai LCT3285TA 32 in. LCD Television
Attaching to wall mount
The 4 screws that are commnly used are short because they are ususally wide in diameter. Besides if they are too long then they might damage the boards on the TV.
Apr 13, 2007 | Akai LCT2716 27 in. LCD Television
Televison & Video Logo
105 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
