Question about Boss Rc 50
Why do i have no display and the tap tempo light and undo/redo light stays on. nothing else works
  • Boss Master
  • 5,603 Answers
This sounds like a pwer supply problem. Verify that you have the CORRECT power supply for the unit. Often these get swapped and incorrect one is connected and sometimes damage is done doing this.
Posted on Jul 30, 2010
Is there a way to replace the settings key pads?
These pads can be replaced ( providing Casio still have spare parts ) There are a lot of screws to undo to get inside the keyboard, then remove any PCB above the pad, replace and reassemble.
or
Contact your nearest Casio service centre
Oct 29, 2015 | Casio Music
LED failed
You can replace it. There are some types of LEDs: 3cm and 5cm. You should first identfy the K (catod) and the A (anode) to make a correct replacement. The K is marked with a slight cut. Dessolder the bad one from the board and replace and solder the new one.
Jun 18, 2012 | Music
SEtting tempo on metronome Zoom R24
The metronome speed is controlled by the Tempo setting. The metronome controls only adjust the volume of the metronome and if the metronome is heard on the input or output recording. The R24 manual is available here: http://www.zoom.co.jp/downloads/r24/manual/ . See page 20 for setting the Tempo. The Tempo button is below the Tempo label to the left of the LCD display on the right side of the Zoom R24.
I hope this helps.
Jun 01, 2012 | Samson Technology Zoom R24 Multitrack SD...
I bought the amp a few weeks ago and it worked perfectly for a couple of days and then for some reason the controlls just froze. the tap tempo light went out and the channel control light stayed the same...
Exercise your warranty IMMEDIATELY since you just bought it! If you bought this used, you LIKELY bought someone else's problem. The problem is likely in the digital effects area... probably a bad cable contact... but if under warranty DO NOT mess with it... return it for replacement or repair.
Sep 09, 2011 | Marshall Amplification Marshall MG30FX...
I have an Akai Miniak synth, and I get a very faint (but very noticeable) noise in the output that seems to cycle with the tempo of the light above the Tap Tempo button. Nothing I do reduces or eliminates...
If it is VERY faint, it is probably either digitizing noise or switching noise someplace in your system. You should keep your audio levels in the system high and reduce the gain at your recorder to improve the signal-to-noise ratio. The noise is also in the higher registers so EQ trimming of the highs MAY help a bit. Make sure all cables are BALANCED lines (TRS or XLR) between the units. Make sure all equipment is powered from the SAME receptacle or power conditioner. You haven't given us enough information regarding your setup and what you are using to record, etc.
Jul 25, 2011 | Akai Miniak Synthesizer Vocoder 37 Key...
The Simmons SD5K keeps spontaneously playing songs, even when all I want to do is play my own stuff with the metronome! I turn on the metronome, set the speed, hit the pads a few times, and the music...
Press the "click" button and then set the tempo you want, press the "click" button again this will stop the metronimoe but is also sets the tempo in memory. The next time you press the "click" button it will be ready to go.
Anytime you press the tempo + or - it thinks you are trying to use the "Tap Tempo Function".
Jun 07, 2011 | Simmons SD5K 7Piece Electronic Drum Kit
I have the Roland Boss Rc-20xl Loop Station, and I'm running off of batteries I have been since I got the pedal. In the middle of recording a phrase the pedal shut off and started resetting itself...
Hello!
I am not positive on this but I would try to clear all of the loops. Try holding the right pedal for about 5 seconds.
If that does not work, hold the right pedal for about seconds while you turn off the unit. Release the right pedal then turn the unit back on.
Hope that helps!
May 11, 2011 | Roland Boss RC20XL Phrase Recorder Pedal
BR8 Digital recording studio lights up, but it doesn't do anything else
I called Roland at the number that you provided and gave they following proceedure which will re-intialize the BR 1180 and ERASE everything that was created on the HD:
  1. Simultaneously hold down button beneath volume control at track 5 and Undo/Redo button at upper right
  2. Press power button while holding down buttons as above, until test menu comes up
  3. Turn selector dial untill initialize screen shows
  4. Prdess ENTER and initialization will start
  5. Once initialization is completed, power off unit and then power it back-up.
NOTE: This proceedure erases all data!
Apr 16, 2009 | Boss Micro BR Digital Recorder
RC-50: Importing wav. files from computer to loop station.
Hi I just got a RC 50 and I face the same problem but looking the content of the data in the Roland folder (after you connect the USB) , I notice the format of the label of each sound's and I understood the problem. So , here it is . Before you connect to USB , you have to choose a patch , let say n.16 OK, now the audio file that you want to import into the data folder must be named in this way "016_1.WAV" ,the 16 refer to the patch number and 1 is the phrase number (if you want to put the audio file into the phrase 1 ,or 2 if 2 ecc.) now disconnect the USB .At this point you just have to increase or decrease the patch number just one time and go back to 16 (it has to refresh the patch info) and you'll find your audio file ready to use in whatever phrase you put it.
have fun
Paolo
Jan 19, 2009 | Boss Rc 50
Boss Rc 50 Logo
53 people viewed this question
Top Boss Music Experts
Michial Gueffroy
shaun taylor
Robert Graf
Are you a Boss Music Expert? Answer questions, earn points and help others
