Question about Dakota 2786-6 Wristwatch
We replaced the battery and now cannot set the time.My husband loved this watch but is frustrated to the point of wanting to stomp on it. Please also tell us how to verify radio control connection.
  • linda431 Jul 29, 2010
    It has been more than 24 hours, so the radio control reset has had pplenty of time. Apparently he can set the digital time but is unable to get the analog hands to cooperate.
  • 3,083 Answers
One needs specific equpment to be able to trouble shoot this kind of watch. Most of the time, the problem will be related to dirt, dust, oxidation, and occasionally, battery corrosion. It can also be a cracked solder connection. If you are getting a display, then the problem will be with a push button switch. This could possibly be cleaned with electronic contact cleaner, just let it dry thoroughly after cleaning it.
To verify radio control, one actually needs at least an ocilloscope, that usually only a repair facility would have. However, there is a procedure for solution for setting the time from another Fixya expert, and here it is:
Best Solution posted on May 21, 2009
We replaced the battery and - noavatar_s.gif Dakota CS
Rank: Apprentice
Rating: 96%, 7 votes
When changing time zones, your watch must be manually set for the new time zone you will be entering. This watch is not designed to adjust for new time zones automatically. Instructions for changing time zones can be changed using the directions found on pages 2-4 in your instruction manual. When changing to and from DST, your watch should automatically adjust for this difference with the next 24 hours after the change. If your watch has not adjusted, you may be in an area that is not receiving signal. Check if your watch has received signal by using the directions found on page 1 of your instruction manual. If your watch has received signal in the past and no longer is receiving signal, your watch may need to be serviced or exchanged. Please contact Dakota Watch Company Customer Service by email at customerservice@dakotawatch.com, or by phone at 1-888-459-0404. ******************************** Good luck, and hope this helps.
Posted on Jul 29, 2010
    Okay. He can set the digital time but cannot coordinate the analog with the digital. The radio question is probably moot. How do we fix the hands?
  • 10,865 Answers
Hello. The radio control only sets the watch once each day so wait a full 24 hours after you put in the new battery and it should reset. J.
Posted on Jul 28, 2010
Watch not keeping time
The replacement battery may have to be replaced.
Jan 23, 2014 | Ebel 1911 Watches
Tip
How to shortcut watch battery.
There are plenty of watches around where you can find writing Shortcut battery and AC. Some writings explain how many times you have to shortcut and for how long as well. Make sure you read exactly what it says and do exactly what it says. Shortcut is needed to restore all watch settings and to make all functions work properly. Shortcut must be done right after replacing watch battery, before any settings. Please note - if you are not quick enough with battery replacement, all previous data from watch memory will be lost. Usual max time for battery replacement is 3 minutes. So, when you decide to replace battery, do it as fast as you can, just make sure do not damage the watch in a rush. When the new battery is in place and in right position, get an eyeglass or magnifying glass and carefully examine watch movement all way around. You should find brass/silver coloured contact with letters AC next to it or even on it. This is exact point for shortcut. Take fine pointed tweezers and touch with one pointed end battery's + and with another end AC contact and hold for 3 seconds. If writing in the watch says Shortcut twice, then do it twice for 3 seconds. When shortcut is done, your watch is ready for use and you can set the desired time, date, month and so on.Hope this will help for everyone who want's to save few quid on watch repairer charges.
on Jun 01, 2011 | Watches
Casio Telememo 30 I need to change my battery again. I did this once before and seem to remember having to short the watch using a hole in the movement inside the casing. I can't find a source for that...
There are plenty of watches around where you can find writing Shortcut battery and AC. Some writings explain how many times you have to shortcut and for how long as well. Make sure you read exactly what it says and do exactly what it says. Shortcut is needed to restore all watch settings and to make all functions work properly. Shortcut must be done right after replacing watch battery, before any settings. Please note - if you are not quick enough with battery replacement, all previous data from watch memory will be lost. Usual max time for battery replacement is 3 minutes. So, when you decide to replace battery, do it as fast as you can, just make sure do not damage the watch in a rush. When the new battery is in place and in right position, get an eyeglass or magnifying glass and carefully examine watch movement all way around. You should find brass/silver coloured contact with letters AC next to it or even on it. This is exact point for shortcut. Take fine pointed tweezers and touch with one pointed end battery's + and with another end AC contact and hold for 3 seconds. If writing in the watch says Shortcut twice, then do it twice for 3 seconds. When shortcut is done, your watch is ready for use and you can set the desired time, date, month and so on.Hope this will help for everyone who want's to save few quid on watch repairer charges.There are plenty of watches around where you can find writing Shortcut battery and AC. Some writings explain how many times you have to shortcut and for how long as well. Make sure you read exactly what it says and do exactly what it says. Shortcut is needed to restore all watch settings and to make all functions work properly. Shortcut must be done right after replacing watch battery, before any settings. Please note - if you are not quick enough with battery replacement, all previous data from watch memory will be lost. Usual max time for battery replacement is 3 minutes. So, when you decide to replace battery, do it as fast as you can, just make sure do not damage the watch in a rush. When the new battery is in place and in right position, get an eyeglass or magnifying glass and carefully examine watch movement all way around. You should find brass/silver coloured contact with letters AC next to it or even on it. This is exact point for shortcut. Take fine pointed tweezers and touch with one pointed end battery's + and with another end AC contact and hold for 3 seconds. If writing in the watch says Shortcut twice, then do it twice for 3 seconds. When shortcut is done, your watch is ready for use and you can set the desired time, date, month and so on.Hope this will help for everyone who want's to save few quid on watch repairer charges..And keep up the good work you are doing for the country...
Sep 30, 2013 | Casio DB360G-9A 30 Pages Telememo Watch
My husband bought me a elgin watch from walmart for christmas. I put it on and pulled the stem to set the time and when I pushed stem back in nothing happened. I also noticed that some of the...
Walmart has an over the counter replacement policy for up to one year. I would demand to see the manager because they are responsible for making things right, the last thing they want is a customer openly complaining about their products and exposing the general public to the bad service they have provided you, where this could have been taken of with an exchange.
Mar 23, 2011 | Elgin Watches
Stauer watch will not work after battery change.
I have no ideal how old your watch is nor where you had the battery changed. Ideally I would take back to whom changed the battery to see if it was a good battery. If your watch is older it may be time for an adjustment.
Contace Stauer for further assistance at link following:
http://www.stauer.com/customer_service.asp
Good luck.
Aug 21, 2010 | Bulova Watch
My husband's watch keeps resetting to 1/1/05 Eastern time. I've reset it a few times and its good for a few days then back to 1/1/05 Eastern. We live in the West and it's 2010 (so he can look at his watch...
Hi,the problem is either from a weak battery or a mechanical fault in the engine of the watch,
i think you should replace the battery,if the problem persists afterwards,then it's time to give him a wrist watch as a birthday gift.
Be cool.
Jun 13, 2010 | Casio Waveceptor WVA104HA-1AV Wrist Watch
The buckle fell off the band
Hi Kap2000
I know it's frustrating and I work in the industry the only thing I can suggest is to a Contact the manufacturer directly or try ebay for replacement bands? and Then rob the buckle off the new one to fit the old, so you still have the gift you gave to your husband?
Model numbers would be useful if you wanted to email me I can try and help out further? (however in australia!)
Jul 14, 2009 | Kenneth Cole 1213 Wrist Watch
Repair location in my area
Try AWCI.com for someone in your area. I recommend a good watchmaker even for a cell replacement, they will usually clean the case and band, do a consumption check, a min run voltage test and a water resistance test and new seals to keep watch fresh.
Jun 13, 2009 | Wittnauer Laureate 12R12 Wrist Watch
Directions for setting correct time with Smash Watch 05-0407
You need to reset your watch completely and to do that, you have to start from battery.
Extract watch battery completely and leave your watch without energy supply for an hour. This will erase any data kept in watch memory.
Then put the battery back in watch exactly the way it was and reset your watch using pushbuttons.
Don't forget to rate, please.
Jan 14, 2009 | Bulova Watch
Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
Mar 15, 2007 | Fossil University of Oklahoma LI2282 Sport...
Dakota 2786-6 Wristwatch Logo
Top Dakota Watches Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Dakota Watch Expert? Answer questions, earn points and help others
