I got whirpool i need to change dogs but agitator wont get apart,how should i make them apart(Whirlpool 3951744 Agitator Assembly )if you plz duide me,much appreciated. Thnx
    President:
  • 1,937 Answers
See the following illustrated description:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136
Posted on Jul 29, 2010
I am trying to replace the agitator dogs on a Whirlpool Estate washing machine. I haveremoved the agitator assembly and am trying to take it apart. How do you get the agitator assembly apart when it...
NOT SURE HOW URS WORKS BUT SOME DO NOT REMOVE FROM THE TOP OR MIDDLE BUT INSTEAD HAVE A COUPLER ASSEMBLY AT THE BOTTOM THAT REPLACES THE CAM DOGS FUNCTION SEE PICS
May 08, 2014 | Estate TAWS850PQ
Whirlpool washer agitator not working
You most likely need to replace the dogs in the agitator, two piece agitator design. It should spin one way and catch the other on the teeth of the dogs. It will spin freely either way when the dogs are wore out. This is for the top half of the agitator, bottom is fitted to transmission shaft. You pop the top cover, remove the 7/16 bolt and both halves together to change dogs of agitator. Pull halves apart to change dogs. Fairly simple.
Jul 31, 2011 | Whirlpool Washing Machines
Agitator is not agitating. It slips How to repair or replace?
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 25, 2010 | Washing Machines
How can I fix the agitator on my washing machine?
Sep 14, 2010 | Kenmore Washing Machines
I need to know how to take the agitator apart. The agitator will not spin, so I need to see what is wrong with it.
If the problem is just the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. All these parts are commonly sold as part of their in-store inventory.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this is helpful to you.
May 26, 2010 | Washing Machines
Grinding noise and agitator wont turn
If this is a Whirlpool manufactured TOP LOADER, an agitator problem can have several causes. Most commonly, this is caused by a broken motor coupling. The following link explains how you can diagnose the problem and repair:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
I have included parts sources and instructions on how to replace any parts as well.
If this just a simple matter of the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
Last of all, the most expensive problem that can occur, is a failed gearcase (transmission). The gearcase averages between $80 and $160 to purchase. If you wish to replace the part yourself, it is not that difficult. The following link explains how:
http://www.fixya.com/support/r3576575-replacing_a_gearcase_on_whirlpool_manufa
The procedure is rather lengthy, but not as difficult as you would think. It can save you a lot in labor charges.
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If the model number is correct, the following part numbers you may need:
Motor Coupling 285753A
Agitator Cam Replacement Kit 285809
Agitator Dogs 80040
Gearcase 3360629
NOTE: If you replace the gearcase, replace the motor coupling as well.
If you have any questions, please post back and let me know. I hope this is helpful to you.
Apr 30, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Whirpool washer with a two stage agitator. Top part stop
This problem is commonly caused by worn agitator dogs on the agitator cam assembly. The following link explains what the dogs are and how to replace them:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The part number is included in the link provided. You can purchase replacements at appliancepartspros.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs. If the model number you listed this under is correct, the part number for the kit is AP3138838 and sells for about $11.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you have any questions about this repair, please let me know. I hope this helps you.
Oct 27, 2009 | Washing Machines
I have whirpool LSQ9549LWO agitator will not come apart so i can replace agitator dogs HELP thanks
I know this is a tough job. Try dripping something like liquid wrench down inside and tap with a wooden block.
Sep 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Whirpool agitator
The parts are called agitator dogs,the top half of the agitator should pull away from the bottom half.
Mar 03, 2008 | Washing Machines
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
