My laptop has a problem of not start once i switched on the on button
  • 979 Answers
Hello Sir, Hi, if your laptop fails on power on, here are possible culprit.
  • definitely there is a power supply problem, these power supply modules are not really serviceable, you need to find a replacement, but if you cant find one, bring the power supply module to a reputable electronics service center, a TV tech. shop will do.
  • there is a possibility of battery problems, but you should see some LED lights on your laptop, to confirm battery is bad, have it replaced, or swap out a new battery,
  • there is a slim chance its the power switch, usually they don't response, if this is the case, replacement is needed, but this goes with the motherboard.
  • if everything else does not solve the problem, its the motherboard. if this is the case, there is not much more else to do, but replace the whole laptop, and but a new one, your dealer may help to contact the supplier if buy any chance may repair the laptop.
Posted on Jul 29, 2010
Acer Iconia Tablet A500 won't boot past the Acer logo screen
How do I perform a Factory Data Reset if my Acer ICONIA TAB A500 does not boot?
The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.
1.Power off the tablet.
2.Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3.With the Volume up button held, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4.Once the tablet vibrates, switch the touch screen lock switch on and off repeatedly while still holding the Volume up button.
5.Release the Volume up button and stop switching the touch screen lock switch once the "Erasing Userdata..." message appears in the upper left corner of the screen.
6.Once the factory reset has been completed your tablet will load to the Welcome screen. 7.Your Factory Data Reset has completed now follow the onscreen steps to setup your tablet.
Mar 06, 2014 | Acer Iconia Tab A50010S32u Notebook
Taking my laptop back to factory settings
This normally works on Toshiba Laptops that still have the restore sector active.
ALL DATA WILL BE ERASED ON YOUR HARD DRIVE IF YOU PROCEED. YOU WILL NEED TO ENSURE THAT YOU HAVE THE POWER ADAPTER PLUGGED IN. DO NOT SWITCH OFF OR RESTART YOUR COMPUTER DURING THIS PROCESS.
1) Hold down the power button for 10 (ten) seconds to switch off your machine.
Please note: Holding down the power button on the machine forces it to switch off. Any unsaved data will be lost.
2) Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook.
3) When the machine Starts beeping; release the 0 key.
4) When prompted by the warning screen; select Yes to continue with the system recovery.
5) Select Recovery of Factory Default Software; click Next.
6) Select Recover to out-of-box state. Click Next again.
7) Click Next to Start recovery.
Dec 28, 2013 | Toshiba Satellite Laptop with Intel Core...
I shutdown my samsung n150 netbook when it was in sleep mode. now i push the power button netbook not wokring but power button indicate the netbook is on. how can i wake my netbook from sleep mode
HI
TAKE OUT THE BATTERY FROM YOUR LAPTOP ONCE AND CONNECT DIRECTLY TO POWER SUPPLY AFTER YOUR LAPTOP GETS ON YOU CAN PUT YOUR BATTERY AND THEN ONCE AGAIN SHUT DOWN YOUR LAPTOP PROPERLY AND SWITCH ON THE LAPTOP.
IF THEN ALSO YOU ARE NOT ABLE TO SWITCH ON YOU CAN CONTACT ME IN THIS E-MAIL ravi.kirans2011@gmail.com
REGARDS,
RAVI
Aug 06, 2011 | Computers & Internet
Need to restore labtop to factory settings plz help
To reinstall your laptop to the factory settings / "out of the box" settings, please follow these steps. It worked for me, and should work for you.ALL DATA WILL BE ERASED ON YOUR HARD DRIVE IF YOU PROCEED. YOU WILL NEED TO ENSURE THAT YOU HAVE THE POWER ADAPTER PLUGGED IN. DO NOT SWITCH OFF OR RESTART YOUR COMPUTER DURING THIS PROCESS. * 1) Hold down the power button for 10 (ten) seconds to switch off your machine. This restores the laptop to factory new and you lose everything:Please note: Holding down the power button on the machine forces it to switch off. Any unsaved data will be lost. * 2) Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook. * 3) When the machine Starts beeping; release the 0 key. * 4) When prompted by the warning screen; select Yes to continue with the system recovery. * 5) Select Recovery of Factory Default Software; click Next. * 6) Select Recover to out-of-box state. Click Next again. * 7) Click Next to Start recovery.
Aug 03, 2011 | Toshiba Satellite L505-S5966 Notebook
How to mater reset
Mar 04, 2011 | Toshiba Satellite Pro L300 Notebook
Wi fi switched off how do i get it on again please
Dear Friend,
WiFi can be switched ON in two ways. First switch on hardware Switch (6) as shown in diagram.
If it is on then go to left corner of your display click on "Start"
Go to Settings>Network connections click
Click on "Wireless Network Connection" . You will see "Enabling "
Yes, your wifi is on again!
I hope this finds useful to you. See you again on FixYa!
Dec 24, 2010 | Acer Aspire 5500 5570-2609 Laptop
How i reset my laptop without the disk
5) Select Recovery of Factory Default Software; click "Next."
6) Select Recover to out-of-box state. Click "Next" again.
7) Click "Next" to Start recovery.
Hope this helps!
Sep 07, 2010 | Toshiba Satellite A215-S4747 Notebook
Im trying to find how to rebot my laptop back to factory its a toshiba satellite m35-s320
  • 2) Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook.
  • 3) When the machine Starts beeping; release the 0 key.
  • 4) When prompted by the warning screen; select Yes to continue with the system recovery.
  • 5) Select Recovery of Factory Default Software; click Next.
  • 6) Select Recover to out-of-box state. Click Next again.
  • 7) Click Next to Start recovery.
May 18, 2010 | Toshiba Satellite M35-S320 Notebook
Laptop not starting
you have problem with your keyboard replace your keyboard your problem will be solve
Apr 15, 2010 | Dell XPS M1330 Notebook
Hi!, thanks for helping me Toshiba laptop satellite a135-s7402, what's the key to run the recovery at start?
Thanks,
Viju
Apr 06, 2010 | Toshiba Satellite A135-S2326 Notebook
Computers & Internet Logo
22 people viewed this question
Alun Cox
David Payne
David Payne
