Question about Toshiba Satellite L305-S5908 Notebook
My Toshiba Satellite's motherboard needs replacement. The Laptop is only one-and-a-half years old. Can it be replaced with a used motherboard, without having to go buy a new one?
  • 110 Answers
You will have to contact Toshiba's support for that. You can check your warranty here, and if it's ok, they should be able to repair it for you. Otherwise, manufacturers make their own custom motherboards, so it's highly unlikely you'll be able to replace it on your own.
Posted on Jul 28, 2010
3 Suggested Answers
kbdesign
  • 370 Answers
SOURCE: Motherboard died on my Toshiba Satellite A105 S4334
That is a tricky one. Guessing that you already have the new laptop, there is a usb adaptor that accepts SATA, IDE 3.5" and IDE 2.5" drives. You plug your drive into this adaptor, and plug the usb into your new computer. Now you can access all of the files on the old hard drive.
Posted on Mar 18, 2009
  • 11800 Answers
SOURCE: I have this toshiba satellite
A new replacement motherboard will cost about $200, the labor to install it at a repair shop (a complicated job that requires plenty of experience) another $100, depending on the country you live in.
So you have to choose between spending $300 on an old laptop or $500 on a new better one. I would chose the second.
Posted on Jul 21, 2011
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
My toshiba satellite 205 4 years old hangs up when attached to a power supply when it is drying up but still functions when you charge it then use after it's full, what might be the problem?
Welcome to Fixya.
You can flash the BIOS of this computer to rectify this problem. Just visit the link below and download the utility :
Support Toshiba BIOS
Make sure to disconnect ALL USB devices attached to your laptop before running the utility after download. If this does not resolve this issue,then there could be damage between the contact point of the AC adapter and the motherboard - if this is the case, then the motherboard needs to be replaced.
You can refer to the same website (above) and navigate for motherboard replacement options if there's a need to.
Thanks for using Fixya.
May 14, 2011 | Computers & Internet
The monitor on my Toshiba P25-S5093 does not have any display of any kind; all black. I have display using external monitor.
Does the display show anything before you enter windows? If yes, then press the key to transfer video back to your original screen once you enter windows. It should be the function key "Fn" + F5 - F8. looks for the icon which shows a monitor or says "CRT/LCD".
If it doesn't show anything before you enter windows I'm afraid your screen needs to be replaced. Good luck.
Mar 08, 2011 | Toshiba Satellite P25-S5093 Notebook
Whenever i use my laptop's powersupply, my laptop unit hangs. instead i could only use my laptop using the battery alone and not with the power supply provided. my laptops model is toshiba satellite...
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adpater. Make sure the apdapter outputs correct voltage. It's possible that the outup voltage is not correct and the laptop shuts down to prevent the damge. Test your laptop with anohter known good power adapter.
If the problem still exists, even after replacing the adapter, most likley it's the motherboard failure. Replace the motherboard.
Reference: Toshiba Satellite A205 Power Adapter
Jan 17, 2011 | Toshiba ADP-75SB AB AC Adapter - 90 Watt...
My old laptop toshiba m35x-s161 won't turn on the light on the power botton turns on and it makes some noise but nothing more happens
Sounds like there is a faulty connection between the power switch and the computer. Probably why its making a little noise.
Take in for repair and replace power button.
Jul 24, 2010 | Toshiba Satellite M35X-S161 Notebook
I need to buy one motherboard for toshiba satellite 1805- s254 i want answer to angel.armijo@gmail.com about price and shipping. thanks
I recommend that you do not buy an old board.
This laptop appears to be over 10 years old.
My expert advice. Buy another laptop. You will be happier in the end. Spend $200-$350 on www.ebay.com
There are many deals.
Best of Luck,
Sagacious1
Aug 07, 2009 | Toshiba Satellite 1805-S254 Notebook
Toshiba satellite m55-s135 won't power on even when plugged in
When the AC adapter is plugged to the wall, if it has an LED make sure it is on, remove the battery and connect the adapter to the laptop, does it power up?
Install the battery after charging, see if your laptop powers up.
If the laptop does not power up, the motherboard needs replacing.
I hope this helps to resolve your issue.
Good Luck.
Mar 15, 2009 | Toshiba Satellite M55-S135 Notebook
Toshiba Satellite A135-S4527 Charger problem
Get another laptop.
The A135 is a lemon.
Problem is either with the dc jack on the board or more than likely the motherboard is damaged.
I've repaired a number of A135's and 95% of the time motherboard had to be replaced.
Sorry for the bad news, but I hope this helps.
Mar 02, 2009 | Toshiba Satellite A135-S4527 Notebook
Laptop wont tuurn on
you may have blowin a fuse or the motherboard could be bad.
please rate my answer it is much apreceated
Feb 12, 2009 | Toshiba Satellite A135 Notebook
CMOS or RTC battery for this laptop : can it be replaced
Hi AshishB, Yes, Toshiba does refer to the CMOS battery in their literature as the real time clock battery. Your retailer is half right, the battery is on the motherboard but its attached via a connector and it can be replaced. Here are links to a couple of venders that sell the RTC battery for your laptop: - Http://www.sparepartswarehouse.com/Toshiba,Satellite,L15-S104,Laptop,Batteries-Backup-RTC.aspx - http://cgi.ebay.com/Toshiba-Laptop-motherboard-battery-cmos-L15-S104_W0QQitemZ170060189842QQihZ007QQcategoryZ3666QQrdZ1QQssPageNameZWD1VQQcmdZViewItem Let us know if you have any other questions and please don?t forget to rate the posting.
Jan 18, 2007 | Toshiba Satellite L15-S104 Notebook
Toshiba Satellite L305-S5908 Notebook Logo
255 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
