Question about EuroTech 24 in. EDW154E Built-in Dishwasher
Error message erro1 on eurotech dishwasher
Water wont drain
  • EuroTech Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwashererror message  erro1 on eurotech dishwasher - 2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Jul 30, 2010
What does the error code ER5 for a EDW154E Eurotech D/W mean?
e5 error is drain error. need to check all drain related items.
drain pump, drain hose, and of course garbage disposal knock out.
Jun 06, 2014 | EuroTech 24 in. EDW154E Built-in...
Error code e5
Eurotech Dishwashers are notorious for the E1 and E4 faults. The problem is with the solenoid they use for filling the dishwasher. The problem is something called the "Venturi Effect". The Venturi effect is the reduction in fluid pressure that results when a fluid flows through a constricted section of pipe. The fluid velocity must increase through the constriction to satisfy the equation of continuity. while its pressure must decrease due to conservation of energy. The gain in kinetic energy is balanced by a drop in pressure or a pressure gradient force. I know, a lot of big words. To put it simply, the orifice within the solenoid is smaller than the inlets and outlets. Even more simply put: Not enough water is getting into the dishwasher. It's a design flaw and I'm not certain there are many ways around it. Just make certain that you have a good water feed to the dishwasher (no kinks, valve on completley etc.). One thing you may try is reducing the feed pressure (i.e. slightly turn down the water valve supply to the dishwasher). Doing so may diminish the venturi effect by equalizing inlet pressure. It's worth a try.
Oct 01, 2017 | EuroTech Dishwashers
What is error 1 message mean?
What is error 1 When you start a dishwashing cycle, the dishwasher fills and then shows the error message when it should go into the wash mode
Dec 09, 2009 | EuroTech 24 in. EDW174E Built-in...
A E4 comes up water seems to be in bottom and there does not seem to be a drying mode...
E4 is overfill protection error . If that happens on drain, then it is a drain problem.
Try first tripping circuit breaker and dry water in the tub using a sponge.
Check the drain well and the filter.
Ensure drain hose at the back is not kinked.
Access pump hose , undo it and look for blockage.
Check the water level device. This is usually a float switch, on some model you also have a pressure switch.
Dec 02, 2009 | EuroTech Dishwashers
My eurotech dishwasher wont take water in
is this a new install? if so you must put about a gallon of water in the bottom of the unit and run as normal.the water should start to come into the unit. make sure the water valve is turned on also.
Aug 03, 2009 | EuroTech Dishwashers
I have a Eurotech EDW154E dishwasher. I keep getting an error code 4. The previous owners said there is a way to reset the machine. Any ideas?
Eurotech Dishwashers are notorious for the E1 and E4 faults. The problem is with the solenoid they use for filling the dishwasher. The problem is something called the "Venturi Effect". The Venturi Effect is the reduction in fluid pressure that results when a fluid flows through a constricted section of pipe. The fluid velocity must increase through the constriction to satisfy the equation of continuity. while its pressure must decrease due to conservation of energy. The gain in kinetic energy is balanced by a drop in pressure or a pressure gradient force. I know, a lot of big words. To put it simply, the orifice within the solenoid is smaller than the inlets and outlets. Even more simply put: Not enough water is getting into the dishwasher. It appears that Eurotech isn't like a simple washing machine that senses fluid level and then shuts off the solenoid. It seems that it's on a simple timer. Turn on the solenoid for X time then turn it off. If not enough water, send fault code. It's a design flaw and I'm not certain there are many ways around it. Just make certain that you have a good water feed to the dishwasher (no kinks, valve on completley etc.). One thing you may try is reducing the feed pressure (i.e. slightly turn down the water valve supply to the dishwasher). Doing so may diminish the venturi effect by equalizing inlet pressure, hence allowing more water into the dishwasher. It's worth a try.
Dec 12, 2008 | EuroTech 24 in. EDW154E Built-in...
Error messages on a EuroTech EDW154E dishwasher??
Dec 30, 2007 | EuroTech 24 in. EDW154E Built-in...
Err4 came on drain clogged..have fixed but cant get error to stop
hold the start button in for at least 3 seconds and it should reset
Dec 14, 2007 | Whirlpool 24 in. ADP5962 Free-standing...
EuroTech 24 in. EDW154E Built-in Dishwasher Logo
251 people viewed this question
Top EuroTech Dishwashers Experts
Tony Houde
Tony Houde
Tom Chichester
Dave Glabb
Are you an EuroTech Dishwasher Expert? Answer questions, earn points and help others
