Question about Sony Cyber-shot DSC-W70 Digital Camera
Why is my camrea saying turn off and on again
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 29, 2010
Have a Vivitar digital camrea and it says the memory card is locked
SD memory has a lock on the side of the card. Otherwise look into the SD slot to see if there are something that shorts out two pins.
Apr 08, 2012 | Vivitar Cameras
Everytime i put my camrea on it says ''wright project'' how can i get it off
You declined to specify what model Olympus camera, so I'm assuming it uses SD/SDHC cards. I'm also assuming it actually says "write protect."
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 20, 2012 | Olympus Cameras
My camrea says "card protected"
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 11, 2010 | Cameras
When i turn the camrea on it says write pratected and it won't let me take picures or delete them.
Oct 14, 2010 | Cameras
I set the date and time then turn of the camrea then whe i turn it back on i have to set it again cannon 75
Please try to press the OK/Set button after setting the date & time. Probably you are not doing the same
May 19, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Have problem with my control
to see if your remote is working obvouisly put in new fresh batteries turn on the camrea on your phone or get a digital camrea and point the infa-red sensor at the camrea and press some buttons while looking at the screen of your phone/digi cam should see a white flashing lights as you press the button if nothing then the control is dead
Sep 10, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Camrea memory card issue.
In what position is the slide switch on the side of the card?
Aug 26, 2009 | Samsung Digimax S500 Digital Camera
My camrea
It may be that you are already using a drive that the camera is trying to open on, like if you are on a shared drive, most likely E or F. You should disconnect from whatever is occupying that space and the camera will apear when turned on.
hope this helps!
Sep 08, 2008 | Sanyo VPC-S7 Digital Camera
Cracked Camrea Screen
the acess code comes on anbd then it asks for me to turn the camera on and off
Aug 07, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Camrea wont take picture
mine does the sammeee thing...and noone knows how to fix it?! :(
Dec 17, 2007 | Sony Cyber-shot DSC-W80 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
20 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
