Question about Apple Cinema Display 23" HD Monitor
The plastic stand to hold up the screen where do I get a new one from
I will let you have the stand off of my Apple Display 17" monitor.
for only $50 postage paid for.
Paul
6085149444
Posted on Oct 12, 2012
  • 110 Answers
Here's something to get you started. I've honestly never heard of that website though, so buyer beware.
Posted on Jul 28, 2010
My stainless steel sunbeam mixer fell and the plastic stand broke. The mixer is ok I can use it but is to heavy to hold. Thanks
My recommendation is to look for a dealer or repair shop that can sell you a new stand. If that doesn't work, try Ebay.
Feb 20, 2017 | Sunbeam Food Mixers
I lost the stand, the plastic part that slides on the back, which holds the monitor up. I need a replacement.
Unfortunately there is no parts to buy for that monitor. Only thing I would suggest is to maybe go on Ebay and look for a broken monitor because the stands are usually good and its just the screen most of the time that is bad.
Sep 22, 2010 | Hannspree HW191D LCD Monitor
Sony vaio desktop all in one back light not working
To fix your problem please follow the below given steps
Step1
Power on your computer and wait until there should be an image displaying on your LCD monitor. Look directly into the monitor from a distance of about 1 inch way. Cup your hands around your face to block out the light in the room and get a clearer view of the LCD screen. Check to see if there is a faint light visible in the screen, which will indicate that the cold cathode backlight has gone out, or no image at all, which will indicate a different problem.
Step 2 Check the manual that came with your desktopmag-glass_10x10.gif LCD monitor or navigate to the manufacturer's website and find the model of cold cathode bulb that the monitor uses as a backlight. Purchase a corresponding replacement bulb
Step3 Power off your computer and then remove the monitor cable from the port on the back of the computer case. Disconnect the monitor stand from the monitor either by pulling out the plastic latches or by removing the screws holding it to the monitor's casing.
Step4 Lay the monitor face down onto a stable work surface such as a desk or table. Take out the screws along the edges of the monitor's casing and set them aside. Lift the back side of the monitor case off of the monitor and set it aside. Check to see if your model of LCD monitor has the back light directly exposed on the lower end of the monitor or if it is hidden behind another plastic or metal piece.
Step5
Remove the screws holding the plastic or metal piece over the bulb if there is one present and set the piece aside. Check to see if your model of monitor keeps the bulb in a plastic casing or if it is soldered directly to the metal. Use a soldering tool to remove the solder or instead use a rotary cutting tool to cut into the clear plastic casing around the bulb if it is inside a case.
Step6
Slide the new bulb into the open spot on the monitor and either solder it in place or use a piece of tape to cover over the opening you made on the plastic casing with the rotary cutting tool. Place the metal or plastic cover back on if there was one and reattach the screws. Set the casing back onto the monitor and place the screws back in.
Step7 Put the stand back on the monitor and then reconnect it to your desktop computer. Power the computer on and wait for an image to appear on the screen to make sure the back light bulb was installed correctly.
Please rate me if this solution works for you
Thanks......Have a great time.
  • Step 2 Check the manual that came with your desktopmag-glass_10x10.gif LCD monitor or navigate to the manufacturer's website and find the model of cold cathode bulb that the monitor uses as a backlight. Purchase a corresponding replacement bulb.
  • Step 3 Power off your computer and then remove the monitor cable from the port on the back of the computer case. Disconnect the monitor stand from the monitor either by pulling out the plastic latches or by removing the screws holding it to the monitor's casing.
  • Step 4 Lay the monitor face down onto a stable work surface such as a desk or table. Take out the screws along the edges of the monitor's casing and set them aside. Lift the back side of the monitor case off of the monitor and set it aside. Check to see if your model of LCD monitor has the backlight directly exposed on the lower end of the monitor or if it is hidden behind another plastic or metal piece.
  • Step 5 Remove the screws holding the plastic or metal piece over the bulb if there is one present and set the piece aside. Check to see if your model of monitor keeps the bulb in a plastic casing or if it is soldered directly to the metal. Use a soldering tool to remove the solder or instead use a rotary cutting tool to cut into the clear plastic casing around the bulb if it is inside a case.
  • Step 6 Slide the new bulb into the open spot on the monitor and either solder it in place or use a piece of tape to cover over the opening you made on the plastic casing with the rotary cutting tool. Place the metal or plastic cover back on if there was one and reattach the screws. Set the casing back onto the monitor and place the screws back in.
  • Step 7 Put the stand back on the monitor and then reconnect it to your desktop computer. Power the computer on and wait for an image to appear on the screen to make sure the backlight bulb was installed correctly.
  • Read more: How to Diagnose & Repair Desktop LCD Backlight Problems | eHow.com http://www.ehow.com/how_5038642_diagnose-desktop-lcd-backlight-problems.html#ixzz0uJr4tmU8
    Jul 20, 2010 | Sony VAIO PCV-V200G PC Desktop
    The monitor comes on to desktop then goes blank, and flashes, if I tap or tilt the monitor it will come back , but then go blank again
    You have a bad connection on the signal input to the screen.
    This is probably the input socket on the monitor, but try a different cable first. If that does not help then it is the socket on the monitor.
    You will need to disassemble the monitor to check solder joints on the video in socket.
    If you are not comfortable with that process then it has to be a repair centre.
    I may be able to offer further advice if you want to tackle it youself.
    Mar 06, 2010 | Dell E151FP 15" Flat Panel LCD Monitor
    How do I open it to look inside?
    First, lay the tv/monitor on its screen on something level and soft as not to damage the screen. Remove any visible screws that seem to attach the base to the unit. Some models you have to look under the base for pins orso to push together to slide the base from the stand, only then you could reach the 1 screw holding the monitor to the stand....Once stand removed, remove any screws you see holding the monitor casing together, usually only a few screws since they are mostly held together by plastic "clips"...Once screws are removed, then gently insert a flat(screwdriver orso) inbetween the case?housing, repeat this all the way around the case/housing till completely loose....You will prob have a few wires or maybe a ground wire that you would have to remove before completely being able to seperate both sides(front case, back case)..Sometimes you might have to unscrew and remove the skinny washer/nut around the cable input orso..
    Nov 18, 2009 | X2Gen MG19MY 19" LCD Monitor
    Viewsonic vx800
    I have repaired several Viewsonic VX800 monitors. The symptoms include a power light that flickers or flashed on and off or a screen that flashes on briefly or stays off. The problem is bad electrolytic capacitors on the power supply board. These bad capacitors do not look bad and do not swell but they do develop a high ESR (Equivalent Series Resistance). You need a ESR meter to check them. But if you have these problems, you should assume the capacitors are bad and just go ahead and replace them.
    First you must open the monitor and gain access to the power supply board.
    1. Remove the stand: It is held with 6 screws on the back. Also on the back are 2 black screws that must also be removed.
    2. Remove the button bar from the front, bottom: It is pried off. This will expose the 2 screws holding the front plastic bezel.
    3. Remove the silver plastic bezel from the front: First remove the 2 screws holding it, then you can pry the rest off. This will expose the 2 screws holding the screen to the plastic back.
    4. Remove the screen and electronics from the plastic back: Remove the 2 screws holding it. The 2 speakers are glued to the plastic case. Cut the glue with a knife. The screen and electronics and speakers should lift out of the plastic back.
    5. Remove the metal cover to expose the electronics: There are 2 screws holding the VGA connector and 2 screws holding the DMI connector. There are 9 screws holding the cover. These must all be removed. There is a black plastic sheet glued to the lower edge of the cover. It must be lifted. The cover should now come off.
    6. Replace the bad capacitors. The power supply and signal processor are on the same board. It is marked VG800-2. The bad capacitors are surfaced mounted 100UF 25V. The bad capacitors are CM16, CM17, CM2 and CM165. The two most critical are CM16 and CM17, but they all read high ESR, so I just replace them all as long as I have them exposed.
    Reassemble in reverse order.
    Feb 10, 2009 | ViewSonic VG800 18" LCD Monitor
    AOC lm929 monitor
    AOC LM929 or Envision EN-7100 removal instructions:
    DANGER!!! UNPLUG and allow the monitor to discharge before servicing.
    with a small flat head screwdriver, insert into the edge and pop open the small plastic
    pieces that surround where the stand connects to the monitor. put plastic pieces aside.
    lay monitor on soft flat surface front side DOWN. with a phillips head screwdriver,
    remove 4 screws in the center that hold on the stand. put stand and screws aside.
    lay monitor on soft flat surface front side UP. insert flat head screwdriver into the
    side edge of the grey plastic and turn screw driver so the plastic surrounding the
    screen edge pops up exposing an area surrounding the screen. put plastic rectangle
    piece aside.
    slide out plastic buttons piece from the side and put aside.
    with a phillips head screwdriver, remove 8 screws (4 on top and 4 on bottom) that hold
    the screen assembly to the back housing. now lift screen assembly out of the plastic
    housing. put back plastic housing and screws aside AND lay the monitor screen with the
    FRONT side down on a flat soft surface.
    with a phillips head screwdriver, remove 2 screws that hold on the metal electronics
    cover. slide the cover down and remove. put the cover and screws aside.
    USE CAUTION!!! Some components may still contain a charge.
    check fuse... whatever...
    Aug 29, 2008 | Computers & Internet
    Dell Inspiron 6000 Laptop LCD Problem
    This is most likely going to be a loose connection. You will need to take the the plastic bezel that surrounds the screen off, the screws are hidden under the small rubber bumpers. Then take the screen loose, you will see he four screws holding the screen at the sides. Tilt the screen forward and you will see the connection on the back. Make sure this connection is seated properly, you may need to apply some new tape on it if it has any. Then check any other connections while you're there. If the problem persists, then the cable may need replacing.
    Jul 31, 2008 | Dell Inspiron 6000 Notebook
    Vx800 flickers when cold
    Oct 18, 2007 | ViewSonic VX800 18" Flat Panel LCD Monitor
    Apple Cinema Display 23" HD Monitor Logo
    159 people viewed this question
    Top Apple Computers & Internet Experts
    marty morrison
    marty morrison
    Paul Carew
    Martin Buck
    Martin Buck
    Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
