My printer will not print. It is a Hewlett-Packard all in one psc 2175v model, it just comes on and makes a clicking sound and then it reads, scanner failure and recommends that I turn it off and then on again. I do this, but the problem still remains.
    Scholar:
  • 186 Answers
On some models there is a scanner head lock to keep the scanner head from moving around and breaking when transporting. Check to make sure it's not in the lock mode.
Posted on Apr 24, 2008
Canner Error 52 Hewlett Packard M1522nf
Please try the below listed steps that should resolve the issue.
  1. While the printer is ON, unplug the power cord from back of the printer.
  2. Also unplug any other cables connected to it. ( USB / Telephone, LAN cable etc )
  3. Wait for 3 minutes.
  4. Plug in the Printer Power Cord directly to wall outlet and then to the printer.
  5. Printer should power ON automatically, else press the ON button to do so.
  6. Now try making a Copy. It should work.
  7. After which connect all the cables / cords that were unplugged.
Jun 24, 2014 | HEWLETT-PACKARD Hewlett Packard 53A...
Will not print on command
Greetings welcome to Fixya.
Might I suggest downloading and installing the latest drivers for your HP Printer.
See my published guide entitled How to Install the latest drivers for Hewlett Packard Printer!!!
Be sure to connect the USB cable to both the computer and the Printer then turn on the Power. Try different USB ports on your computer/laptop.
Navigate to the Windows control panel and double click printers and faxes.
Click print test page on the bottom right of the box.
Also view the print que, right click on your printer and set it as the default printer.
Then in properties view the print que!
Also when you are printing in MS Word, click file print, then when the settings come up for the print ensure that your HP PSC 2410 All-In-One InkJet Printer is selected in the top most section of the box.
Tell me how it goes via comment!
Thanking you
damnor01
Mar 11, 2011 | HP PSC 2410 All-In-One InkJet Printer
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
We have a 4 in 1 printer by hewlett packard and we do not know how to stop the endless printing of an earlier print out. what do we need to do?????
  1. Click "Start"
  2. Step 2 Click "Run"
  3. Step 3 Type in "services.msc"
  4. Step 4 Click OK
  5. Step 5 Find Print Spooler in the list of services
  6. Step 6 Click "Stop"
  7. Step 7 Once the service has stopped, restart it by clicking on "Start"
thank you,
Lee
Mar 26, 2010 | HP PSC 2410 All-In-One InkJet Printer
HP psc 1350 all in one printer
Look on your desktop for HP director ( could be another name but will say HP). If you don't see it on your desk, click start, all programs, HP or Hewlett Packard. Click on this and a box will open letting you choose how to scan, where to save it ect. If you have trouble with it you may need the update, here,
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-46104-1&lc=en&dlc=en&cc=us&os=228&product=77361
If this helps plz rate this 'fixya', if you need more help post a comment & I'll be happy to walk you through it, I know how frustrating it can be. Thank you kindly
Feb 21, 2009 | HP PSC 1350 All-In-One Thermal Printer
Direct Printing
Solution Follow the steps below:
  1. Click Start , then Printers and Faxes .
  2. Right-click the system default printer and click Properties .
  3. On the General tab, right-click the default printer and click Copy .
  4. Click Cancel to exit.
  5. Click Start and then click Run .
  6. In the Run dialog box, type regedit and click OK . WARNING: Using Registry Editor incorrectly can cause serious problems that may require you to reinstall your operating system. Hewlett-Packard cannot guarantee that problems resulting from the incorrect use of the Registry Editor can be solved. Use Registry Editor at your own risk. It is strongly recommended that you make a backup copy of the Registry before you edit it. For information about how to edit the Registry, view the "Changing Keys And Values" help topic in Registry Editor (Regedit.exe) or the "Add and Delete Information in the Registry" and "Edit Registry Data" help topics in Regedit32.exe.
  7. In the Registry Editor window, click Edit , then click Find... , and search for the following key: HKEY_CURRENT_USER\Software\Hewlett-Packard\DigitalImaging\hpfccopy .
  8. Double-click Printer in the right pane.
  9. In the Edit String window, paste the printer name as it appears in the Registry under Value data (for example, hp photosmart 8400 series) .
  10. Click OK and close the Registry Editor.
  11. Press Copy on the scanner. The default printer connected to the system should normally print the scanned document.
Cause This issue occurs when the default printer or the list of printers is not recognized on the hpfccopy function in the Current User section of the Registry.
Mar 27, 2008 | HP Scanjet 4370
134 people viewed this question
k24674
jasbo
jasbo
