Question about Dell E207WFP LCD Monitor
On-off switch does not function
I cannot find a switch replacement part and need to find out where I can find a new switch
The power in my monitor did not function. After watching a video on youtube on how to open up a similar monitor i discovered the the power switch had broken on the inside. To solve the problem i drilled a hole in the front panel of the screen directly in front of the actual power button (the power button that you press on the monitor has a small light behind it, the actual button is alongside it) and now i use a match to switch it on and off. it works fine!
-Michael
Posted on Jan 05, 2011
  • 110 Answers
As in power switch? I don't think they make power switch replacements, you may need to either send it back to Dell (if it's still under warranty), or purchase a new monitor.
Posted on Jul 28, 2010
I have a jacuzzi hot tub that needs a 4 funtion switch that has went bad can I replace it?
Yes, the four function switch is easily replaced. Before you replace it make sure that when you press the functions button that the momentairy switch (jag switch) is sending the proper voltage to the coil on the four function switch. If so, take not of each wires location, draw a picture or take a photo if need, and replace it the same way you removed it. http://www.spaandpoolstore.com/2000-068.html
Sep 16, 2013 | Home
Tip
Flashlight Battery and Bulb Installation and...
FLASHLIGHT
BATTERY INSTALLATION FOR TORCH:
Open the Torch Battery Door located on the bottom of the Torch.
Insert 4 “A A” (1 .5V UM-3) (not included) batteries (alkaline
batteries are recommended) into the torch compartment. Be sure
the polarity (+ and
-) matches, as marked inside the battery
compartment.
FLASHLIGHT:
Slide the Torch Function Switch to the “FLASH” position, the Torch will light. To turn off, slide the Torch Function Switch to the “OFF’ position.
FLASH/BLINK FUNCTION:
Slide the Torch Function Switch to “FLASH/BLINK” position, tha Torch will light and thc bulbs on both sides of Torch will blink.
BULB REPLACEMENT:
Rotate the Torch Cover anticlockwise to hear “click”
then p
ull out the cover, remove the old bulb. Then pull
out the torch cup, remove the blinker’s
old bulbs and
reinstall new bulbs. Replace the torch cup, then reinstall
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
2001 PT Cruiser loss of turn signals and hazard lights after multi-function switch replacement. I replaced the multi-function switch after noticing the fogs lights staying on when not engaged. When the new...
Perhaps you need to start with fog light problem I am guessing we do not know for sure the switch was the cause, if you can remove them from the equation. When checking for shorts make sure you check light bulbs to,
Next, since the multi function switch was the next step in your problem solving, I suggest you remove the new switch check out all wires to the connector, be especially careful to make sure none of wires have pulled out or partially pulled out of the connector. Let me know when you finish this then we can move on to continuity testing.
My best guess is the connector as it is common to both your fog light and multi-function switch,
Above all don't let it get to you, these problems can be frustrating but they also can be interesting and fun especially with the right assistant
Aug 25, 2013 | 2001 Chrysler PT Cruiser
Both headlights quit working simotaneously
There are just (3) possible reasons for this:
(a) your headlight switch has failed, or
(b) your headlight relay has failed.
(c) Fuse 1 (25 Amps) has blown
The headlight relay and fuse 1 are located (I think) in a fuse/relay block under the hood.
The headlight switch is part of the "Multi-function Switch" on the steering column.
Here's how to replace the 2001 PT Cruiser multi-function switch:
Multi-Function Switch Removal & Installation
1. Open the hood.
2. Disconnect and isolate the battery negative cable.
3. Remove both upper and lower steering column shrouds.
4. Disconnect both posi-lock harness connectors at the rear of the multi-function switch.
5. Remove multi-function switch mounting screws and remove switch from vehicle.
To Install the new multi-function switch:
Note:
If replacing the multi-function switch, the combination flasher and windshield wiper/washer switch
must be transferred to the new multi-function switch.
1. Remove the two Torx(R) screws retaining the wiper/washer switch, place next to the new
multi-function switch and install two screws.
2. Place switch into place and install mounting screws. Torque multi-function switch to column
retaining screws to 27 inch-lbs. (3 Nm).
3. Connect both posi-lock harness connectors at the rear of the multi-function switch.
4. Install both upper and lower steering column shrouds.
5. Connect the battery negative cable.
6. Close hood.
7. Verify vehicle and system operation.
Mar 15, 2011 | 2001 Chrysler PT Cruiser
I had a mouse failure today and now i'm trying to replace it. The new microsoft wireless mouse will not function in the switch. model JC102CPA, Just Com Tech switch
If the mouse failed in the switch, and the new one wont work, have you tried both mice plugged into the computer direct, it may just be a fault with the switch, or you may need to plug the mouse into the computer direct for the first time
Sep 01, 2010 | JustCom JC-102CPA KVM Switch
I need to replace the mutifunction switch on my '02 GTP. Does anyone know the steps involved in doing this? I know I need to disable and remove the airbag on the steering wheel.
the multi function switch is held in by 2 screws that holds the turn swith arm. just loosen them up and it should come out in 1 full piece. just remove and replace with new switch.....
Jan 28, 2010 | 2002 Pontiac Grand Prix
How to replace my turn signal switch
Multi-function Switch Removal & Installation To Remove:
To Remove:
  1. Remove the steering column trim covers.
  2. Remove the wire harness from the retainers as needed.
  3. Slide the turn signal and multifunction switch connectors out from the bulk head connector.
  4. Remove the two mounting screws and remove the multi-function switch from the steering column.
To Install:
  1. Install the multi-function switch on the steering column.
    • Tighten the screws to 42 lb in (4.7 Nm).
  2. Slide the turn signal and multifunction switch connectors into the bulkhead connector.
  3. Install the harness in the original retainers.
  4. Install the steering column trim covers.
Jun 25, 2009 | 1996 GMC Sierra
Fan/stove light switch broke needs replacing
The original fan switch for the SEG196 (circa 1995) is a four terminal switch- two for the fan and two for the light . Note that the switch spade lugs for the red and blue wires (which when connected activate the fan) are larger than those for the white and brown wires (which when connected activate the oven light). This design presumably prevented miswiring of the switch at original assembly. Since the four terminal switch is nearly impossible to find (it was discontinued several years ago), an inexpensive fix is to replace the four wire switch with a two wire SPST toggle switch. However, this means that either the fan function or the light function can be preserved- not both. I elected to keep the fan function, and simply wired the red & blue wires to the two terminals of a heavy duty replacement SPST toggle switch. Be sure to fully insulate the remaining (in this case) white and brown wires with electrical tape or wire nuts before tucking them below the new switch. Total cost: $6.00 for switch. NOTE: TURN OFF POWER TO RANGE AT ELECTRICAL PANEL BEFORE ATTEMPTING REPAIR! beec3807-1ba5-40e7-a010-7e26d5fca5c0.jpg
Feb 18, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Need to replace the ETACS unit
ETACS
(Electronic Time and Alarm Control System)
as far as the rear defroster, it may be the switch, relay, or fuse.
i have all of the service info on mediafire.com , just click this LINK and download whatever you need. i would suggest these 2 sections for fixing your problem:
97-99Electrical.pdf
2gTech_Info_Man.pdf
Dec 21, 2008 | 1997 Mitsubishi Eclipse
FUCTION BOTTON
replace a new one tact switch! (function button) your tact switch is not working!
Sep 23, 2007 | Audio Players & Recorders
Dell E207WFP LCD Monitor Logo
506 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
