Question about HP Office Equipment & Supplies
Paper jam on HP Laserjet 2840/ jam is from tray 2/replaced the pick-up roller and the seperation pad-new/ still have problem/ left edge of paper is damaged from the bottom up 6 inches. HP does not have a clue they want to sell me a new printer
  • 1 more comment
  • konastorm Jul 28, 2010
    does anyone have manual or tech paper on the paper path or trouble shooting this problem.
    Does anyone have the repair manual for an HP 2840 color laserjet printer
  • konastorm Jul 29, 2010
    Does anyone have the service and repair manual for this printer???
  • HP Master
  • 6,993 Answers
go to the below link, and you will find the service manual that you requested for. The Service manual is in PDF format, so you will have to wait a while for it to load completely.
http://www.partshere.com/Models/Q3948A/CLJ_2820_Removal_replacement.pdf
Good luck.
Posted on Jul 29, 2010
    when I type the address into IE it returns HTTP Forbidden and will not display the web page any suggestions I tried it in Mozilla and IE
    President:
  • 567 Answers
The Hewlett-Packard Color Laserjet 2840 is a high-end laser printer. It is part of HP's "all-in-one" series. This means that the HP 2840 can perform multiple functions including printing, scanningpaper jam on HP Laserjet - mag-glass_10x10.gif, copying and faxing. With all of these different features, you may be experiencing technical problems in any one of those areas. You can, however, troubleshoot some basic problems before having your printer repaired.
The HP 2840 is an all-in-one printer.
  • 2 more comments
  • Hilton Bristol Jul 29, 2010
  • Ensure that all cables are securely connected. First, make sure that the printer cable connecting your computer to your printer is connected securely. Then, make sure that the power cord is inserted into a wall outlet. Try your print job again after you have ensured that all cables are properly connected.
  • Step 2Clear a paper jam if your printer is not responding or you are receiving a "Paper Jam" error message on your printer. To clear a jam, first open the rear output door by pushing down on the two levers on each side of the door. Opening the rear door simply makes it easier to clear a jam. Open the top cover on the front of the printer by pressing the release button on the right side of the printer. Locate the paper jam and use two hands to gently remove the paper jam. Try your print, scan, fax or copy job again.
  • Clear stored or saved faxes if you are having trouble sending or receiving faxes. Old faxes may be stuck in the fax queue, which may be causing the printer to not respond. To remove stored faxes, press the "Menu" button on the printer and select "Fax Functions." Then select "Clear Saved Faxes." Wait for the queue to clear and try your fax job again.
  • Step 4Remove paper from the automatic document feeder (ADF) input tray if your scan job is coming out crooked. The ADF input tray can only hold up to 50 sheets at a time. If there are more than 50 sheets in the input tray, the output may appear skewed. Try your scan job again after removing the paper.
  • Adjust your computer monitor's display settings if your scanned image is not an accurate representation of the original image. This can be done in the "Control Panel" in Windows. Set the settings to the highest possible resolution and try your scan job again.
  • Step 6Perform a power cycle on your printer if the previous steps were unsuccessful. To do this, turn off your printer, then unplug it from the wall. Wait a few minutes and plug the printer back in. Try your print, scan, fax or copy job again.
  • Try these steps and let me know if it work,
    Here is some more information you can lookup http://h10025.www1.hp.com/ewfrf/wc/searc...
    • 242 Answers
    All you need to do is the check whether anything stuck or not on the tray, such issues are always resolved by small things you might need to check the paper tray and roller, there might be a very small thing (may be smaller then a needle or a bee).
    Check those things out, thought i am not much technical help here as you have already gone through many steps here.
    Thanks
    Jimmy
    Posted on Jul 28, 2010
    • HP Master
    • 1,606 Answers
    Past a point it is cheaper to replace. However sometimes the problems are simple.
    First is look at the paper. Does it look like it caught on something on an edge ? Or does it look like it was pressed into it? Also is this on every page regardless or just the odd page or just the top and bottom pages IE full or near empty paper tray? that will give a clue as to what we are looking for.
    If it is consistent then you probably have either something stuck inside the paper path or something damaged in the paper path. It could also be the tray or part of the surround where the paper comes out of the tray.
    If the paper damage is consistent then you know where to look. You just need to follow the paper through the printer and see what lines up with the marks on the paper. As a guess I would look at the set of rollers that look like a set of spaced wheels. These will be just before or just after the paper goes over the drum. (I'd have to dig out my manuals to give the proper name, can't think of it). I've had paper damage close to what you describe caused by those. Usually the paper tension is off for some reason and instead of riding over the rollers it gets pulled in and gets cut or ripped.
    Unable to pick up papaer on tray 2 error 13.00
    common faults for poor feeding on lj5200
    1, feed rollers are worn - replace
    2, sep pad is worn ( cant seperate pages correctly)- replace
    3, paper empty tray sensor actuator arm snapped - unable to raise cassettetray- replace arm
    4. paper feed roller fail to turn- feed unit clutch assy faulty- replace feed asseembly
    5.paper tray pass guide out of position (blocking feed path) - pin that holds in place has snapped- replace feed assembly
    Dec 13, 2013 | HP LaserJet 5200 Printer
    HP LaserJet 4 Plus printer, as the paper is starting to feed into the printer from the MP tray the paper on the left side pulls in crocked and therefore causes a paper jam. Pick up roller and seperation...
    There is something blocking the paper path.(Like a paper clip or something). Remove the toner cartridge first, then use a file folder or thin cardboard to push the object out of the way. Put the toner back in and try printing again. Good luck !
    Apr 03, 2013 | HP LaserJet 4 plus Printer
    I have an hp p3005 with the jam code 13.01.00. It has had the feed rollers and sep pads replaced. When it runs it appears to catch on the separation pad itself since it shows a small buckle in the middle...
    Replaced seperation pad?. separation pad work is to block multiple paper feeding,but in yourcase paper not at all feeding means paper pickup roller not picking up the papers.replace both 2 & 3 paper pickup rollers..
    See the snap shot,view from under.
    Pickup roller( red)
    Un lock to remove pick up roller(blue),observe the angle of the roller & same way insert new one other wise it wont fix..
    Bee care full while removing roller, paper sensor flag should not distubed(yellow)
    bee pateince dont do harsh..best of luck.
    Oct 11, 2011 | HP LaserJet P3005 Printer
    13.01.00 Jam in Tray 2 error when no jam exists
    Check Tay2 paper sensor flag, located at tray2 pick up roller, its its stucked shoot the fault
    Mar 24, 2011 | HP LaserJet P3005 Printer
    I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
    There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
    Jams in tray 2
    Table 7-10 Causes of tray 2 jams
    Cause Solution
    The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
    worn or damaged, replace the rollers.
    The pickup roller is worn or damaged. Replace the pickup roller.
    The tray 2 paper pickup assembly drive gears are damaged
    or the assembly is defective.
    Check the drive gears in the paper pickup drive assembly.
    Replace the pickup drive assembly if the gears are
    damaged. See Paper-pickup drive assembly.
    The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
    from the dc controller PCA (location J92).
    2 Measure the resistance between the cable connectors.
    3 If the measured resistance is not approximately
    160 ohms for the HP LaserJet 4200/4300, or 110 ohms
    for the HP LaserJet 4250/4350, replace the tray 2
    pickup solenoid.
    The tray 2 lifter-drive assembly or the stack position
    sensor (PS107) is defective.
    Replace the lifter-drive assembly. See Tray 2 lifter-drive
    assembly and/or Printer switches and sensors.
    The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
    Dirty, worn, or deformed pick-up roller, cassette separation
    roller, and cassette feed roller.
    Clean the rollers if they are dirty. Replace any worn or
    deformed rollers. The cassette separation roller and the
    cassette feed rollare are to be replaced together.
    Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
    gears are not rotating correctly, or are damaged or worn,
    replace the cassette pick-up drive unit.
    Dec 25, 2010 | HP LaserJet 4250 Printer
    Paper not pulling thru in tray 2 creating a jam message
    IF its pulling multiple pages its a seperation pad if its not pulling at all its the pick up rollers.
    Mar 26, 2009 | HP LaserJet 4050n Printer
    Printer will jam on mulitiple page print jobs gets a 13.1 error all rollers have been changed, jams just after the letter tray and only jams from legal tray 3 ???????
    OK you said you replaced the rollers. If you have not repalced the SEPERATION PAD, (located directly under your pick up roller....thats your problem. Easily done.
    Mar 12, 2009 | HP LaserJet 4650 Color Printer
    HP 2840 printer paper jam
    does the paper feed at all(1/2 way) no feed,if not pick-up paper most likely will be feed motor if 1/4,1/2 or 3/4 fed will be sensor at falt or 2nd tray conectors dirty or making false contact.
    Sep 08, 2008 | Office Equipment & Supplies
    Changing Roller/Seperation Pad in Tray 2
    1-Open tray
    2-lift left side of roller ( it is spring loaded and should lift easily)
    3-pinch rollers and remove
    4- take out whole tray and look inside underneath to see pick-up and feed rollers.
    Aug 30, 2007 | HP Color LaserJet 4650DTN Printer
    44 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
