I need directions on how to replace the carrier belt cable for an Hp DesignJet5000 it snapped and i need to replace it. Thanks
  • 3,037 Answers
The service manual for these units contain the complete instructions for replacing the belt. Please be aware of the tools needed to complete the change before starting. A link to the manual can be found at the following address http://www.freeprintermanuals.com/PM/HP%20DesignJet%205000%20Series%20Service%20manual.pdf
section 8-46 has the carriage belt replacement info
Let me know if you have problems with the link provided, it should work Benjamin
Posted on Jul 28, 2010
  • Benjamin Patri
    Benjamin Patri Jul 29, 2010
    Just for a quicker response on the fault/error codes.
    Here are the Sony blink codes for this tv chassis:
    Unit is dead and there are no blinks---Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open)
    Continuous Blink Once A Second, No Pausing As Discussed Above---
    No reply from the jungle IC301 (data bus is busy, shorted to ground or held high), IK video path is defective.
    ONE Blink--- not used for the self-diagnosis
    TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
    THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
    FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
    FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly.
    SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
    SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
    EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
    NINE blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
    TEN blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
    Intermittent problems ?? This is a great feature. You can also bring up these fault codes ON-SCREEN to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, Press the following buttons:
    Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC. We have repeated them in parentheses in the text for the "Blinks" described above so you can correlate between the diagnostic screen and the blink codes.
    So, now that you know about these self-diagnostics, how do you use them? Say that you have a set with a black screen. You see that the LED is blinking 4 times....This would tell you that you have no vertical and that is why the video is muted. If it was blinking 6 times, you would know that you have a horizontal fault.
Officejet d135 says bad black printhead- Replace the pentagon --
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Aug 26, 2009 | HP OfficeJet D135 All-In-One InkJet...
Replace ink comes up, just replaced that color, can't be empty
Aug 24, 2009 | HP Photosmart C6280 Printer
HP Deskjet F380 does not print. On screen message: "cartridge does not move". But d machie makes crankling sound when put on. Cartridge slowly moves from one end to d other twice and stops with a loud bang...
Aug 23, 2009 | HP DeskJet F380 All-In-One Printer
I have replaced and cleand the printheads
" Unplug the printer cable from the computer.
" Unistall the printer drivers from Device manager and also unistall the all the printer appications
" restart the computer
" try to download drivers from the website
" after installing drivers and software it will ask you to connect the printer.
" then you can connect the printer and and try to Print the test page.
Thanks
Thiru
Jun 17, 2009 | HP OfficeJet d145 InkJet Printer
Printhead alignment fails
PREM
May 26, 2009 | HP 7130xi All-In-One Machine Printer
Craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
May 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Cartridge carrier belt has snapped need to know if
You can replaced the belt, the best way to get a new one is to call a local pc shop. They may have one in stock and if they don't they can order one for you.
Apr 27, 2009 | HP DeskJet 990cxi InkJet Printer
Printer not responding all though active as
Thanks, GF
Apr 27, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp Photosmart c6180 all in one err oxc18a0206
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
PREM
Mar 22, 2009 | HP Photosmart C6180 All-In-One InkJet...
22 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
