Question about KitchenAid 24 in. KUDI01ILBS Stainless Steel Built-in Dishwasher
Fills with water then won't cycle wash..... it just sits there with the panel lights on..... and then if you push cancel it drains fine?
  • Randell59 May 23, 2008
    I have the same problem and am looking for a way to fix it as well.
  • punchydrunk Oct 31, 2008
    mine is doing same exact thing. I think the motor is out.
  • 2,326 Answers
Check the info from this site to have an idea where the problem could be.
Posted on Apr 24, 2008
2 Suggested Answers
  • 264 Answers
SOURCE: Dishwasher won't start KUDIO1ILBS
How old is this dishwasher that you are using? Is this under warranty
My whirlpool gold dishwasher is only 2 years old. It will fill with water but it just sits and makes a clicking noise when its supposed to be washing. It drains fine when I push the cancel button.
sounds like there is either a loose wire or bad switch on the water flow pump, not the drain pump What is the model number of the unit that your working on?
Aug 22, 2015 | Whirlpool Dishwashers
Apr 24, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Motor keeps running. Water heats fine. Help
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out.
See this discussion.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/26-129-977852-/Bosch-Dishwasher-won-t-drain-SHE43RF2UC64
Apr 02, 2014 | Bosch 24-in Built-In Dishwasher Color:...
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Kenmore Dishwashers
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
During drain cycle it partially drains through hose but water pours out of the bottom front
It sounds like the drain hose may have a break in it. Use a Phillips screwdriver or a 1/4" nut driver and remove the lower toe panel that sits back and low to the ground in front. With that panel off fill the dishwasher then push cancel and see where the water is coming from. Let me know which hose it is and I can get you a part number if you wish
Apr 24, 2010 | Kenmore 16602 / 16604 / 16609 Built-in...
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Open Questions:
See all KitchenAid 24 in. KUDI01ILBS Stainless Steel Questions
KitchenAid 24 in. KUDI01ILBS Stainless Steel Built-in Dishwasher Logo
116 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
